Question about GE (PSS26MSRSS) Side by Side Refrigerator
REFRIGERATOR SIDE DOES NOT GET COLD
THE FREEZER PART WORKS BUT THE REFRIGERATOR SIDE DOES NOT GET COLD MILK IS SPOILING. I CLEANED THE COILS AND GOT
A LOT OF DUST AND DIRT AWAY FROM THE FAN BUT IT STILL DOES
NOT SEEN TO BE GETTING COLD.
  • 1 more comment
  • doug compton Oct 06, 2008
    yes freezer fan is working and yes there was frost buildup
  • Anonymous Oct 11, 2008
    refrigerator side not cooling...odor in refrigerator
  • izoc Oct 17, 2008
    I have the same problem; temp in fridge side is 60, freezer is fine, no visible ice buildup on walls. Replaced something a year ago that had ice built up all over, something with the defrost in the freezer side. The fan is running. Is there a damper that prevents the cold from going into the refridgerator side? Could it possibly be the temp. set knob at top?
Check the gas of the Refrigerator...
Posted on Oct 06, 2008
  • 943 Answers
Hi. did you check to see if the fan in the freezer is working. check to see if any frost build up on freezer wall.check those thanks
Fridge warm, freezer cold. repair guy said its fine if milk is not spoiling. but set at 6 coldest temp is around 40
Can you feel air movement from the freezer to the refrigerator side through the cooling tubes when the evaporator fan is operating?
If not you might have some ice build up in the cooling tube that is not allowing the refregerator to get cold enough. Try a hair dryer to clean it.
Aug 19, 2011 | Frigidaire FRS26R4A Side by Side...
Hi my side by side wards refrigerator and freezer doesnt always get cold enough some times it will make ice and keep milk cold and other times wont make anything cold. it spoils milk one day and next day...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 07, 2011 | Refrigerators
GE Profile Performance: Fridge rose in temp to the point where milk is spoiling. Now Freezer is going up in temp as well. Ice is melting and food is no longer frozen. Ice forming on the back wall of...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Oct 30, 2010 | GE Profile Performance 25.2 cu. ft....
Freezer & refrigerator are not getting cold.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 24, 2010 | Maytag MSD2454G Side by Side Refrigerator
Whirlpool ED5PHAXSB side by side refrigerator not cooling...
There are a lot of possibilitys. You'll have to use the process of elimination.
But it could be the thermostat (make sure your setting is midway) The milk spoiling indicates it is too warm so bacteria is breeding
Get a refrigerator / freezer stand alone thermostat (about $5) That will give you accurate readings. The fridge shoud be between 35 and 40 F and the freezer 0 plus or minus 3 when set correctly
It could be your condensor fan is clogged or just that your coils need cleaning (underneath or behind) Use a vacuum with the brush end or chisel point. Dust can cut you efficiency by 20 or 30% by itself.
Assuming this is frost free model the defrost timer may be acting up in the freezer.
Forgive me for not knowing where the coils are and if it is frost free but I can't find a manual for this particular model. However the principles apply in any case.
May 09, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Freezer not freezing and refrigerator not cold
The most common problem is the condenser under the refrigerator is clogged with lint. Pull the unit away from the wall for clearance,tip it rearward, and have someone use a vaccum on the dust. Unplug the unit while working on it and remove what can slide around be careful not to damage the works underneath, as dirt is the whole problem.................. Get it clean as you can and reset to factory settings and leave it alone for 24 hours.
The FACT THAT IT IS STILL FREEZING MEANS THE WORKS ARE OK.!
If it still doesn't work correctly, you need freon added by aservice man, but I think cleaning is all you will need.
Jan 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator not cooling freezer working fine
Refrigerator suddenly not cold enough . Drip pan clean and dry. No dirt or dust.
Oct 05, 2008 | Randell 20072SC R-134a Refrigerator
8 yr. old GE Refrigerator/Freezer has started becoming too warm -milk spoiling
hi. thanks for the question. look at the freezer, is there frost build up on the freezer wall . is the fan running in the freezer. also pull fridge away from the wall ,clean all coils thanks the appliance doc
Oct 05, 2008 | GE Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
108 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
