Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Dark screen red arched lines
Is this what yours did? The picture is perfect, just see the red lines when dark background. Can or did you fix it yourself? Where did you buy the part? Thanks!!!!
  • 185 Answers
Turn down the red screen control slightly the box is located behind the grille 6 knobs on it look carefully for the screen making on it for red do not adjust any other control best done in a dark room with no source in a video input if the tv will not auto align you have the control backed off to far
Posted on Oct 08, 2008
Red arching lines showing up on screen promident when a dark background is present
Red picture tube needs screen voltage adjust. Open fornt or back of TV and look for a black square looking box with adjustment knobs. Look for red screen adj and slowly turn rt or lft until lines just disappear. If screen goes too bright tv will shut down, just turn back on again and retry
Dec 04, 2009 | Sony Televison & Video
Thin red arched lines, when screen is dark.
common problem with sony, focus and picture level need to be adjusted, should be done by a tech. (high voltage) in focus block.
Nov 24, 2009 | Sony KP-57WS500 57" Rear Projection...
Faint red lines in a curved arch like pattern
Is there a cheaper solution? $600 sounds like you just throw it away to me...
Aug 02, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Curved blue lines on screen.
You have a completely different problem. The screen voltage for the blue picture tube is slightly too high on your set. This will put fine lines in the background of the picture, called retrace lines. This is very common and easy to correct. Remove the front speaker cover and the access panel behind it. Look inside and you will see a black box with six controls, each control having a little white glue on it. This is the Focus/Screen block. Three controls are labeled Focus and three are labeled Screen. The screen control in the center is for green but I am not sure if the screen control on the left or right is for blue for your model. With the TV on, set it to VIDEO 1 but do not connect anything to the VIDEO 1 jacks. This will produce a pure dark picture, showing any faint lines in the background. Choose one of the screen controls and increase (turn clockwise) it slightly. If the blue lines do not get brighter it means you are turning the red screen control, so put it back where it was and choose the other screen control. When you find the blue screen control, decrease (turn counter-clockwise) it until just when the blue lines are gone. If you want you can check that the red and green screen controls are set to just below the point where their faint lines are visible. When done, replace the panels and your picture will be back to perfect.
Apr 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Dark Screen and red and blue lines
Those lines tell me that you may have a leaky electrolytic capacitor in your vertical circuit.
Feb 10, 2008 | Mitsubishi VS-60607 TV
Blue and red arched lines on screen when background dark
Sounds like you are describing retrace lines that could indicate that your CRTs or something in the drive circuits are bad.. Check the resistors on the CRT sockets to see if they are in tolerance. If they are try turning the red and blue screen adjustments down just a little this should take the lines away. You will however be needing service in the not to far future. Turning the screens down should help if the resistors check out. Let me know if you need anything further.
Jan 31, 2008 | Sony KP-48S35 48" Rear Projection...
White arched lines appearing on dark/black screens.
it sounds like you are seeing the vertical retrace for all three colors together (white). Its possible that all three screen adjustments (red, green, blue) are off, but I suspect a problem with the screen power supply.
there is also a recall on this set
Jan 23, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Very fine red lines across srceen
It is an adjustment, but it's an adjustment you may not want to do. It's the red screen control. It's located behind the front panel so the entire front panel has to be removed in order to access it-which will expose you to hazardous voltages. if you like, I can post detailed instructions on how to get that front panel off, it's kinda tricky.
Jun 13, 2007 | Sony KP-51WS500 51" Rear Projection...
Red Horizontal Lines
they gona get worse to dead circuit, a small capacitor (problably in the neck board) is bothering you, get a tech now that he can see the problem, gonna be cheaper now....good luck ps some times the picture say to the tech was going on
Aug 05, 2006 | Sony KP-51HW40 51" Rear Projection...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
82 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
