Question about Toys
I need a schematic for a Skee-Ball machine manual 990002
We have a Skee Ball machine that I need schematic's for. The back board and ball return does not work
I have a schematic for a Skee-ball Classic model H
Posted on Oct 18, 2008
How much money?
Posted on Nov 15, 2009
Not keeping correct score
A very common problem that is either a bad opto, if a newer machine, or a bad score microswitch. Start a game and drop the ball in the bottom hole to the top hole one at a time and look for your score. When you drop a ball and get the same score as the last hole then the micro(or opto) for that hole is bad.
Jan 31, 2014 | Video Game Consoles & Games
Tip
Playing skee-ball like a winner
Skee-ball is a bowling type arcade game where each player gets 11 balls that they have to roll up a ramp to try and get it into one of the holes at the end of the ramp. Each of the holes have a point value between 10 and 100 based on how easy they are to get the ball into.
Not all skee-ball machines are created equal so if you pick a machine to begin with you should stick to that machine. There can be small differences in the tilt or angle of the ramp that can really mess with your aim. You might think that changing machines will change you game but sticking it out and figuring out what is messing you up will actually make you a better skee-ball player.
Most people play and try to get the ball into one of the two 100 holes at the very top of the board but these two holes are the hardest to hit and if you miss in most cases result in no points. If you play with your friends you can make sure that you always get some points and maybe even the high score by always aiming for the 50 point hole in the top center of the board.
The reason that you should aim for the 50 point hole is because even if you miss this hole you have a very high chance of winning 10, 20, 30 or even 40 points. So while everyone else is failing to get the ball in to the 100 point hole you can rack up the points with this technique. But remember that in the end it is just a game and you are all out to have a good time.
on Oct 13, 2013 | Video Game Consoles & Games
Can I make a skee-ball machine at home?
A little searching online and you will find tons of people have made their own skee-ball machines for at home play. eHow has a few really good guides.
When and were was skee-ball invented?
According to Wikipedia skee-ball was invented in 1909 by J. Dickinson Este in Philadelphia Pennsylvania.
Can I get a skee-ball machine to play at home?
You can find mini skee-ball games for $30-$50 but a full size one like they have in the arcades are going to cost you a few thousand dollars. So if you have the funds then yes you can have a skee-ball at home.
How many balls do you use in a skee-ball game?
The standard number of balls used for one skee-ball game is 11.
Jan 31, 2013 | Video Game Consoles & Games
Can working out with a medicine ball improve my balance?
When using a medicine ball you need to work your core muscles harder; which in turn should improve balance. I was able to find a great tip from a personal trainer in regards to improving balance using a medicine ball - Stand up straight and hold a medicine ball above your head with both hands. Quickly bend your knees and swing the ball down and through your legs, so the ball almost scrapes the floor. Slow the ball down and reverse the motion, swinging the ball back up overhead as you straighten your knees and return to a standing position. Repeat 10-15 times. Do a second set of 10-15 if desired.
Aug 05, 2012 | Exercise & Fitness
Bernina 1530
You may just need to clean it. Many times when people use hand lotion or other things oil etc. it gets on the ball and interferes with the board. Try cleaning the ball with cottonball and alcohol. It really makes a difference.
Hope this helps.
Rick
Mar 17, 2009 | Bernina 1008
Toys Logo
1,236 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
