Question about HP DeskJet 940c InkJet Printer
Can't get printer to print in color
I have an HP deskjetD1455 printer. It is four months old. I changed the cartridges on it. It will not print in color only black. Do I have to re-program it each time I change the cartridges? If so , how do I do this?
  • gordonjr Oct 08, 2008
    I jsut changed color ink cartridge and it will not print the color yellow
    Sergeant:
    Champion:
  • 334 Answers
Go in to control panel then printer then make sure its not on cheak box print coler in black white only ok 1st if not download latest driver ect from hp.com ok thx nikc
Posted on Oct 06, 2008
New Cartridges - not all color ink printing!
It sounds that the ink inside the cartridge has partly dried up.
This can happen to my printer when I don't use it for a couple of months too.
Hope this helps!
Feb 04, 2010 | HP PhotoSmart C4180 All-in-One Color...
Dell 922, 4 yrs old, did not change color cartridge, now prints blue highlight over all images and text. Have clicked "clean t fix horiz streaks" and wiped head. No change. Help!
If the cartridge was left in it during an extended period of time (we'll say three months or longer) without use, it can damage the print head in a way that is irreparable. At four years old, unfortunately, it is probably cheaper to replace the printer than to have the head professionally repaired. Dry ink is the great enemy of inkjet printers.
If you clicked the cleaner multiple times with no luck, the only thing besides replacing the printer I would suggest would be to try another print cartridge. Unfortunately, if this isn't the problem you've just wasted whatever the cartridge costs. BUT if this unit directly touches the cartridge to the paper to print, it should repair the problem.
Jan 03, 2010 | Dell 922 All-In-One InkJet Printer
HP deskjet 2460 will print black on test page but not on any other document. Have changed cartridges twice, aligned and cleaned several times. tried the holding on of button in with pencil and opening and...
Go to printer settings/options and navigate to the color tab. See if you can find a setting which allows the printer to use only color cartridge, change this setting to use both cartridges.
Aug 03, 2009 | HP Office Equipment & Supplies
Changed toner, replacement hp cartridges, all four at one time, colors are not mixing correctly. black prints good alone
you have to replace all the four cartridges at the same time,, black need not be replaced if it is working well.. thank you,., plz rate me,,
Jul 05, 2009 | HP Laserjet 2605 Printer
HP LaserJet 1600 printing 2 lines on paper, Uneven but straight.
If the line is one specific color, then change the corresponding toner cartridge. (You may be able to see the line on the drum in the toner cartridge.) If the line is a mix of colors, then it is probably either the transfer belt or the fuser. In either case, you could replace the whole printer for about the same cost as repair.
Apr 06, 2009 | HP Color LaserJet 2600n Printer
I haven't the manual for this printer color laserJet 2600n series,
HP Color LaserJet 2600n Printer - Installing Print Cartridges When a print cartridge approaches the end of useful life, the control panel displays a message recommending that to order a replacement. The printer can continue to print using the current print cartridge until the control panel displays a message instructing to replace the cartridge. The printer uses four colors and has a different print cartridge for each color: black (K), cyan (C), magenta (M), and yellow (Y). Replace a print cartridge when the printer control panel displays one of the following messages: Replace yellow cartridge, Replace magenta cartridge, Replace cyan cartridge, Replace black cartridge. The control panel display also indicates the color that should be replaced (unless a genuine HP cartridge is not currently installed). Change the print cartridge
  1. Turn off the printer.
  2. Open the front door. c00315320.gif CAUTION: Do not place anything on the transfer belt (ETB), which is located on the inside of the front door.
  4. Remove the new print cartridge from the bag. Place the used print cartridge in the bag for recycling. c00315322.gif
  5. Grasp both sides of the print cartridge by the blue handles and distribute the toner by gently rocking the print cartridge from front to back. CAUTION: Do not touch the shutter or the surface of the roller. c00315323.gif
  6. Remove the orange shipping locks and the orange shipping tape from the new print cartridge. Discard the shipping tape and shipping locks according to local regulations. c00315324.gif
  7. Align the print cartridge with the tracks inside the printer, and using the handles, insert the print cartridge until it is firmly seated. c00315325.gif
  9. Turn on the printer. After a short time, the control panel should display Ready.
    NOTE: If a cartridge is in the wrong slot or is the wrong type for the printer, the control panel will display one of the following messages: Incorrect yellow, Incorrect magenta, Incorrect cyan, Incorrect black.
  10. Installation is complete. Place the used print cartridge in the box in which the new cartridge arrived. See the enclosed recycling guide for recycling instructions.
  11. If a non-HP print cartridge is in the printer, check the printer control panel for further instructions.
    NOTE: When replacing or changing a black print cartridge, a cleaning page will automatically print. This helps prevent speckles on the front or back of printed documents. A cleaning page can also be generated using the control panel or the HP Toolbox.
Nov 03, 2008 | HP Color LaserJet 2600n Printer
Printing RAINBOW of colors!
Change the color cartridge and see what happens.
Aug 06, 2008 | HP Deskjet 6940 InkJet Printer
Cleaning or replacing printhead / hose
Buy them at a official EPSON service center or throw away the printer and buy a HP.
Actual EPSON printers uses 5 ml ink cartridges for each color and black. HP printers has the same volume cartridges but there are only 2, tricolor and black.
If a HP printing head becomes clogged (don't worry, it almost never happens), just throw away the cartridge and install another (the print head comes with the ink cartridge). If a EPSON print head becomes clogged you have no other choice than buying another printer because EPSON's print heads are expensive and become discontinued 12 months after the printer model was launched to the market.
Also, HP Printers are cheaper than those from EPSON and offers excellent print quality on any paper. Compare a 10 years old HP printer with actual EPSON's and the HP has the sharpest black printing. The color is another story.
Mar 13, 2008 | Epson Stylus CX5400 All-In-One InkJet...
HP DeskJet 940c InkJet Printer Logo
64 people viewed this question
Ben Johnson
