I have a sony TV model kv32fv15. TV was working fine when we shutdown. When we turned on after couple of hours it doesn't turn on.
    Problem Solver:
  • 3 Answers
Replace the deflection ic
Posted on Oct 06, 2008
I have a 50" Sony Bravia Projection TV. In the morning when my kids turn on the TV, everything works fine. But if they turn it off and then 30 minutestry to turn it back on, the sound comes on but with...
i see a couple possibilites. im not going to rule out a bad lamp. the lamp does come on sometimes. i have seen faulty lamps display this sympton. since it gives no error codes (blinks) and then does not shutdown. i feel this is a deeper cuircit board problem that a tech might need to troubleshoot. how long has it been since lamp been replaced
Oct 13, 2010 | Sony KDF-50E3000 Television
32 inch sony trinitron wega
It will most probably need an overhual of the power supply
Mar 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinitron kv32fv15 standby light continously blinks won't po
check IC301,with a ohm meter,shorted to ground,IK video path defective......can get parts at Mats Electronics # 1-800-628-1118.hope this helps
Feb 16, 2010 | Sony Televison & Video
My sony wega keeps cutting off then coming back .
a couple of years old can be a long time:
has the TV been on 24\7
It's the amount of hours that matters..
electrolytic capacitors typically last 3000 to 5000 hours....
Special "long life" caps last close to 7000
but the caps in most consumer electronics, even broadcast equipment 3-5K hours.
Jun 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV turns on with sound but blank black screen
This solution from troylove solved my problem. troylove11
Rank:wizard_s.gif Wiz
Rating: 85%, 1164 votes
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Jan 07, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Sony Wega 40" TV will not turn on, standby light blinks 6 times repeatedly
Hello,For model KV-40XBR800,
Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.
Good Luck
Oct 05, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No image but good quality speaker.
Sony has had a problem in older sets with-believe it or not- lack of humidity. I had one with the same problem. If it is under warentee take it back, if not-I know it sounds insane- put a large plastic garbage bag over the turned off set. Leave it that way for a couple of days. do not turn it on during this time. After a couple of days remove the bag and turn it on. If it works-that's the problem, if it doesn't- it's dying, and to expensive to fix. Surprised the heck outta' me when I tried it on my old Sony 19" set- it worked.
Jul 01, 2008 | Sony KP-46S25 TV
PS3 No signal to the TV
I'm having similar problems. I had my PS3 on pause, whent out for a couple hours, came back to find a weird fuzzy screen. My PS3 had froze, so I turned it off. I turned it on a couple minutes later, and the green light came on, however, my controllers would not connect, no image was popping up and it also wouldnt turn off unless I flicked the switch on the back. After contacting Sony, they told me it could be an overheating issue. If it has been less than a year, they will replace it, NOT FIX IT. Which is great and all, but unfortunately I am about to lose the countless hours I've put into assassins creed, skate, call of duty 4 and motorstorm.
HOWEVER. If your PS3 is still "functioning properly" except for no signal, turn the power off on the back, turn it back on, press and hold the power button on the front untill you hear the second beep, let go, give it a couple seconds, turn it off from the back and then back on, hold it till the second beep again. Good luck.
P.S. I recomend getting the extra cooling fan for it, and saving game data on another card (SD) incase crap like this happens.
Dec 26, 2007 | Sony Playstation 3 (PS3) Console
TV Turns off and on
How long since the last time the bulb was replaced? It sounds like the bulb is overheating and triggering a safety shutdown.
It's probably in need of nothing more than a good cleaning (open it up, clean off the boards with a can of air) and *may* be time to replace the bulb.
Nov 13, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
