Question about RCA E13309 13-Inch Diagonal XL-100 Color Television Television
1987 RCA TV
Tv works great, teriffic picture but no sound.. tried the mute button,
still no sound. all other works on the remote, on-off-channel. but not the sound...
    Sergeant:
    Champion:
  • 334 Answers
Most like the amp on speakers wwent bad best u can do add seprate samsng sterio suround system or ect form dish cable box to sterio direct for tv sound or rca outs on tv if those sstill work
Posted on Oct 06, 2008
Just bought an RCL3210 TV. The odd thing is that the Channel up/down key on the remote control does not change the channel. Also, the up/down channel key on the TV itself also does not respond. When you...
You need to find how to CLEAR the auto channel settings. Sounds like the TV is set to SKIP all channels. Look for a MENU and then look for an AUTO setting that will walk through all channels and set those where you have reception as the "list" that the remote and the Up/Down buttons on the tv will choose.
PS: GREAT writeup on your problem and the things you have tried.
May 08, 2017 | RCA Televison & Video
Rca remote to set crt tvofsony
These are the steps and codes for yout to set your RCA remote to your Sony TV.
1. Set the "Mode Switch" to TV.
2. Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
3. Enter the 5 digit Code.
Codes: 10000 10834 11100
But then if it still doesn't work, you can still try doing these steps.
1.Set the "Mode Switch" to the desired mode such as TV for a Television.
3. Enter the code "991" followed by the "device number", in your case you are programming it to a sony tv so use 1.
4. You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
5.You can try out each code by pressing one or more function keys such as power, volume or digit keys.
6. When you've found the setup code that works for your device, press the "Select" key.
Jun 13, 2010 | RCA DIRECTV Satellite Remote Control
CANT CONTROL THE TV FROM REMOTE CONTROL,TV SEEMS TO CONTROL IT SELF VERY FAST AND ALWAYS MUTE.CAN I REPLAC THE CONTROL PEICE ON TOP TO STOP THIS! NEED HELP PLEASE.
I fixed mine. It was one of the channel buttons on the top of the tv. You will need to figure out which one it is. It has five prongs that are soldered into the board three on one side two on the other. I clipped the two prongs side on the channel down switch and mine works great now. It will run the channels up on the tv but works normal with the remote. If the channels are running up it would be the up switch for example. You will need to remove the back to get the switch panel to slide foward to service. Disconnect power for about six hours before you mess with it as it holds power around the picture tube that will bite you.
Nov 17, 2009 | RCA F36650 36" TV
Can't select front input without remote
I had the same problem, had a universal DirecTV remote that was able to control the volume/mute, power and channels (both TV and DirecTV), but the input button didn't work. There was no av/tv button on the front of the tv, and the autoregistration of channels didn't pickup the gamecube on the AV channel. What solved it was simply to press "00". I couldn't believe it, but it was that simple. Hope this helps you like it helped me, since the tv was not going to be of much use since we were using the RCA inputs, not the coax. Didn't want to try to conver the RCA to coax either.
Apr 04, 2009 | RCA F27440 27" TV
Picture but no sound
press mute button on tv remote
Oct 20, 2008 | Zenith B27A11Z 27" TV
How do I program a 1987 rca tv, lost the remote for it
if it is xl-100 "remote control" model (manu. 1987) I have a drop down door on front, there are names for buttons (5) at left:
auto pro,
step<
step > (arrows actually up/down)
add
erase
The other buttons to R are channel up & down, volume up & down & red Power, of course.
On the left, if you can "add" in some channels you scroll by, you may get more than 60.
(is this all moot, in 34 days, Feb 17)
My remote for another RCA does work some, for this "oldy."
Aug 25, 2008 | Televison & Video
Volumn not working
WHen I hit the mute button again to bring up the volumn the sound remains muted. I have tried all other channels, direct cable and even a dvd player connected. No sound. I unplugged all the boxes and tv and then plugged in again in a attempt to reset what might be wrong. Still no sound. solution 1 while operation mute button has got demaged or pressed more. 2 sound section might have gone defective in tv 3 no supply to sound section 4 or speaker defective or ic got demaged.
Aug 02, 2007 | RCA 27V520T 27" TV
RCA E13309 13-Inch Diagonal XL-100 Color Television Television Logo
333 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
