Question about Refrigerators
Water leaking from refrigerator only unit. (no freezer)
Hello rcearn,
I have the same problem. Water under the vegatable bins. I took them out and left them out, dried the bottom of the frig and I still get water there. Did you find a solution?
  • 99 Answers
The drain hole at the back certer of the fridge is blocked up,Stick a straw down to unblock,then pour a smal amount of hot water down to make shure it goes,check monthly,the water goes ontop of the commpressor then evaparates
Posted on Oct 12, 2008
Water leaks out onto the floor and into the refrigerator and freezes vegatables
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 27, 2011 | Refrigerators
The food in our freezer has been icing up quickly. Then recently noticed the vegatables in the Refrigerator bins were all frozen and ruined. On inspection of the freezer, we noticed a sheet of ice running...
i would say that the cold coil in back of freezer is covered with ice and the problem will get worse . the defrost system need repair . ck the defrost thermo and the defrost control . . the heater is usualy ok . your unit may use what is a p c control called aditive defrost control . but most common is the defrost termo . located on the evap coil in back of freezer plate. mm hope this helps feed back pls .
Jan 20, 2011 | Refrigerators
JDC2389GES side by side fridge Water is leaking inside the freezer and pooling at the bottom.
Hello and Welcome to FixYa!
Actually the leaking water is from the evaporator coil unit....(it is located at the back wall or underneath the freezer compartment). Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit....
The channel or tube is clogged and the water is leaking to the refrigerator/freezer unit, so you need to clear that blockage/contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the floor in the refrigerator/freezer compartment. This is all you need to do....
Best of Luck,
Your token of appreciation in form of rating would be highly obliged,
Concerned.
Aug 25, 2010 | Jenn-Air Refrigerators
Water leaking from behind ice chute door & freezes under ice bin
You will have to remove the unit and access the rear of freezer. Check that the filters are not plugged as well as drain.
Jul 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool Refrigerator ET21GM LEAKING water ALL OVER INSIDE
there is a drain under the coils in the freezer. it is frozen and the water has no place to go. hairdryer and a lot of patience. a hairdryer can melt a freezer /warning.
Jun 09, 2009 | Whirlpool ET1MTKXKQ White 20.9 Cu. Ft....
Old Kenmore refrigerator leak
common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Nov 16, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kitchenaid superba icemaker leaking/freezing in freezer section
Your water hose that connects to the back of the freezer may be loose. Move the fridge out away and in the back make sure it is tightend.
Let me know if it helped :)
Oct 20, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
191 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
