Question about Lexmark Wheelwriter 3500 Typewriter
Wheelwriter 3500 KYBD 099
We have an IBM Wheelwriter 3500 typewriter and it's not typing the right letter/number/symbol as the key I hit. There is a "KYBD 099" on the screen that I've never seen before.
I can't find the manual for it....can anyone help? PLEASE?!?!
THANKS!
  • 1 more comment
  • veco_in_mfg Oct 07, 2008
    Worked like a dream! THANK YOU SOOOOOOOOOOOOOOOO MUCH!
  • hank7481 Oct 09, 2008
    Only the "a" works correct. All of the other characters type something different than what I hit on the keyboard. I made sure the wheel is correctly aligned, and I checked that the keyboard cables are plugged in.
  • SadiesSide Oct 26, 2008
    Thank you! I read further down and the solution worked for me! Thanks again!
  • Lexmark Master
  • 3,594 Answers
Check the ywo keyboard connectors to be sure they are plugged in fully, if they are then press & hold the code key, press & rel the "L" key type 001 then release the code key.
This will put you into the english keyboard mode. To cure the problem you need a keyboard.
DickyO
Posted on Oct 06, 2008
  • Dick O Reilly Oct 28, 2008
    To HANK2471;
    You didn't say what kind of a T/W it is, if it's an IBM WW try code l or x depending the age of the machine.
    DickyO
When I couldn't find any other solution, I got a vacuum and cleaned out all of the inside, and then I tried changing the batteries. Would you believe then it worked? I don't think the batteries should affect the keyboard (would they?) ... so I'm left to believe that the good cleaning made the difference.
Posted on Oct 28, 2008
Keyboard error 099, When you write the letter are miss up
Your key board is going bad. Hold the code key down touch "L' type 001, release code key. This will get you by. You can try my tip under WW1000 or contact Geo. Beyers Co. @800-392-8085 for a KB rebuild. Tell them O'Reilly sent you.
DickyO
May 11, 2011 | Lexmark Wheelwriter 3500 Typewriter
IBM Wheelwriter 30, Series II has message KYBD 099
Tour keyboard is going bad. Hold the code down press lang (L) key release the "L" type 001, release the code key this should put you on U.S. keyboard mode. For a better repair you can try my tip under WW1000 or contact Geo Beyers Co. @ 800-392-8085 for a keyboard rebuild. Tell them O'Reilly sent you.
DickyO
Nov 10, 2010 | Lexmark Wheelwriter 2500 Typewriter
KyBD 099 what is it and how do get rid of it
Your keyboard is bad. To use it temporaly hold the code key, press "L" type 001 (code for us keyboard), release code key.
For a repair see my tip under WW1000 or contact Geo. Beyers Co. @ 800-392-8085 for a keyboard rebuild, tell them O'Reilly sent you.
DickyO
Sep 14, 2010 | Lexmark Wheelwriter 3500 Typewriter
IBM Wheelwriter 5. It was typing light so I
The plastic print solenoid cap is probably broken. We sell them with instructions and shipping for 20.00.
DickyO
Cleveland Business Machines
216-241-0027
Feb 25, 2010 | IBM Wheelwriter 30 Typewriter
Displays error code "kybd 099"
Try this, hold the code key, press and release "L" key type 001, release "L" key. If this works the keyboard is going bad & will need replacing.
DickyO
Feb 18, 2009 | Lexmark Wheelwriter 2500 Typewriter
WHEN TYPING THE WRONG LETTERS PRINT
Keyboard 99 is Laten supplemental. Try holding down the code key and pressing the x key it should reset the keyboard.
Jan 25, 2008 | IBM Wheelwriter 30 Typewriter
Stuck in a Mode
http://www.scantracker.com/KansasCityrepairs.html
These guys are repairers so they may have extra copies.
IBM's Typewriter's site also has manual for sale for less than $20.
The typewriter seems to have a bad ribbon cartridge or a bad typing wheel. Take each one out and try to see if it will type normal. If one does, then you know to replace it.
Zabrina
Jan 08, 2008 | Office Equipment & Supplies
Problem with striking
Sounds like a keyboard problem. Check the connectors to be sure they are fully pluged in, if this isn't the problem try putting a piece of foil over the rt hand keybourd connector contacts that are bussed together (seven I believe) replug the ketboard and test. BE SURE TO BUSS ONLY THE CONNECTORS THAT ARE BUSSED ON THE CONNECTOR!!
Dec 07, 2007 | IBM Wheelwriter 30 Typewriter
Lexmark Wheelwriter 3500 Typewriter Logo
416 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
