Question about Crosley Washing Machines
WASHING MACHINE WONT SPIN
When empty both the spin cycle, and wash cycle will work. When there is a load in the machine it will not spin. I took the machine apart and I can turn the clutch backwards with my hand whenit is engaged. any ideas for the problem.
    Guru:
  • 558 Answers
How much you loading in the machine?
Since when this problem arised. How much old it is?
Is tt spins, but doesn't pump.
If your washer spins but doesn't pump the water out, the drain line is probably clogged.
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt.
Let me know in bit more detail so I can investigate further.
Posted on Oct 06, 2008
Why has my machine not drained or Spun.
Cant be 100% but could be overloaded, turn off, set dial / program to spin and try again, may need several goes to empty.
Jan 13, 2016 | Washing Machines
Zanussi zwf12070wi machine indicates cycle is
flashing red start/pause button, wont spin or drain
Jul 13, 2010 | Zanussi ZWF12070 Front Load Washer
My Mx511 wont woork on spin cycle
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 04, 2010 | Washing Machines
Maytag Neptune washing machine - wont drain & spin
heatman101
May 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Washing Machine Out of Balance Even When Empty
the machine is not level... put a level across front back sides to check adjust legs leveling bolts as needed.... also is the machine installed on a carpet floor??? if yes put a sheet of plywood under machine so it wont "bounce" on floor.
May 15, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
My washing machine wont spin with clothes in it
Hi, you will find either the drive belt has stretched slightly so when the unit is under a load the motor pulley slips on the belt. The belt should have some sort of tensioning or you would need it replaced.
The other reason it will not spin is if the motor brushes are worn and need replacing.
Hope this helps.
Mar 22, 2010 | Washing Machines
Wont spin
Probably down to the water not emptying from the machine in the empty cycle and the machine won't spin because there's still water in the drum. If this is the case, the root of the problem is almost certainly a blocked filter, restricting the draining of the water and not allowing it all to pump out in time during the empty cycle. You probably need to find and clean your filter.
Feb 02, 2010 | Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washing Machines Logo
434 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Karl H
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
