Question about Roxio Easy CD & DVD Burning
CD Burning I am trying to burn a playlist but I keep getting this message "This playlist contains transitions between tracks. Track-At-Once burning would introduce 2 second gaps within these transitions, and has been disabled." and then nothing else happens. What is going on? it worked the last CD I created.
    Sergeant:
    Champion:
  • 334 Answers
I would try to dl latest nero.com use nero alot better did u try to go to roxio.com and download latest software verison k thx nick
Posted on Oct 06, 2008
How can I get track names on wave bose
When you make a cd if the names are not coming in when you add the tracks you can try a feature on most programs which is called get track names or something similar if this does not work you can type them in manually most burning programs have the ability to do this . I have all these features on my burning programs . You would have to import the tracks into a new play list and try what I said bottom line is at the least you should be able to add the track names manually then burn and they will show up on most radios or CD players . Hope this helped
Sep 03, 2014 | Bose & Wave& Music System
Tip
How to Play iTunes Music on Windows Media Player
There's a good chance when you buy music from the iTunes Store that the files that you download will be copy protected by Apple's FairPlay DRM system. It's a great system that protects the rights of the artist and publisher by making it difficult for the consumer to distribute copyrighted material. However, DRM can also be very restrictive by stopping you playing legally purchased music on your MP3 compatible hardware. So, what happens if you want to play your DRM'ed music on a non-iPod?
This tutorial will show you a way to produce DRM-free music that doesn't require any special software that you would normally need to buy. All you'll need is the iTunes software, and a blank CD (preferably a rewritable (CD-RW)).
Before we begin, check for any updates that are available for your iTunes installation, or download the latest version from the iTunes website。
Configuring iTunes to burn and rip an audio CD
CD Burner Settings: In order to set up the iTunes software to burn an audio CD, you first need to go into the settings menu and select the correct disc format. To do this, click on the Edit tab on the main menu and select Preferences from the menu list. On the preferences screen, select the Advanced tab, followed by the Burning tab. First, make sure your CD burner is selected from the drop-down menu alongside the CD Burner option. Next, Select audio CD as the disc format that is to be written by your CD drive.
CD Import Settings: While you are still in the preferences menu, click on the Importing tab to access the CD ripping settings. Verify that the On CD Insert option is set to Ask to Import CD. Next, set the Import Using option to a format of your choice; the MP3 Encoder is your best choice if you want to import audio CDs as MP3 files that play on virtually all compatible devices. Choose an encoding bitrate from the Setting option; 128Kbps is the normal setting that is good enough for the average listener. And finally, make sure the Automatically Retrieve CD Track Names From Internet and Create File Names With Track Numbers and both checked. Click the OK button to save your settings.
Making a custom playlist
To be able to burn your DRM copy protected songs to audio CD you will need to make a custom playlist (File > New Playlist). You can add music tracks to a playlist easily by dragging and dropping them from your music library to your newly created playlist. For instructions on how to achieve this, why not follow our tutorial on How to Create a Custom Playlist Using iTunes.
While creating a playlist, make sure that the total playing time (displayed at the bottom of the screen) doesn't exceed the capacity of the CD-R or CD-RW you are using; typically, the total playing time of a 700Mb CD is 80 minutes.
Burning an Audio CD Using a Playlist
Once you have created a playlist, simply left-click it (located under the playlists section in the left pane), and then click on the File tab on the main menu, followed by Burn Playlist to Disc. The CD drive tray should now automatically eject so you can insert a blank disc; ideally use a rewriteable disc ( CD-RW) so you can reuse it multiple times. Before iTunes starts burning the DRM protected songs, it will remind you that creating an audio CD is for your own personal use only; once you have read this notice, click on the Proceed button to start burning.
Ripping an audio CD
The final step in this tutorial is to import (rip) the songs that you burned onto audio CD, back to digital music files. We have already configured iTunes (step 1) to encode any audio CD that is inserted into the CD drive as MP3 files and so this stage of the process will be mostly automatic. To start ripping your audio CD, simply insert it into your CD drive and click the Yes button to start. For a more in-depth look at this process, read the tutorial on How to Import CD Tracks Using iTunes.
Once this stage is complete, all the files that have been imported into your music library will be free from DRM; you will be able to transfer them to any device that supports MP3 playback.
Note:The only downside in using this method is that if you have a lot of files that you need to convert, then it ends up a slow and tedious process. With this in mind, use a legal drm removal tool if you have a large quantity that you need to convert.
on Aug 25, 2010 | Computers & Internet
Laptop cd burning issues
You may try this disc creator, I always use it to burn music and video to CD/DVD, it works pretty well for me all the time.
May 18, 2013 | Audio Players & Recorders
I cant make recordings on my masterlink every time a record a few songs and try to burn a red book cd from the hard drive it says songs less than 5 seconds
Look at all the tracks in the playlist that you're trying to burn to CD - is there a track that you've perhaps forgotten about still in the playlist, one of less than 5 seconds?
When you press Create CD, you're telling the Alesis to create a CD from the WHOLE of the current playlist, not just the track you recorded most recently ...
Oct 13, 2011 | Alesis MasterLink ML-9600
Burning failed (1) track reservation not
Turn of anti-virus while burning disc - worked for me.
Jan 22, 2010 | CyberLink Power Producer 2 OEM for PC
I bought an Alesis Masterlink ML 9600 for my church but have come to realize that its operation manual is not the best written thing I've ever read. I have it connected for analog input from my audio...
Have you thought the posibillity that the track is too short so there is plenty of remaing "time"to write to the disk? Try putting some more tracks in the recording line. Don't forget that the mean time for recording on audio cd is about 74 minutes (or 99 tracks, whatever comes first).
Try this and in case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Jan 15, 2010 | Alesis MasterLink ML-9600
Tracks too short to to create CD from hard drive.
either have to delete the short tracks from playlist to burn...when i get mssg theres usually nothing there (hit new track 2x by accident, just silence) Or if u want what is on the short tracks, have to join it to longer track b4 or after it, making one longer track, and no more 1 sec track...to do: hold playlist edit and delete track button, will ask if want to join two tracks, say yes and its done...When u do this, the track you do this on will b joined to the previous track, it will give u mssg showing which two tracks about to join and what track name will b left...(for example do u want to join track 01 to track 02...resulting track name will b track 02)..can then burn once all short tracks either deleted or joined to larger tracks...
Apr 03, 2009 | Alesis MasterLink ML-9600
Downloading my music and then burning to a cd
Have you read the section of manual relating to 'Importing CDs' ?
Select a playlist, press 'playlist edit' - press HD/CD - insert CD, close drawer. Once Alesis has scanned disc, press 'track move' - display should read Move CDTrk -> Trknn where 'nn' is the next available track in playlist. Press Cursor Left to place cursor under CDTrk, press Down/No, and display should read Move CD->Playlist. If you now hit Yes it will copy all CD tracks to the active playlist (it'll prompt if the playlist isn#'t empty to make sure you want to add the CD to the tracks already in the playlist).
Once they are copied to the playlist, you can move them around if required, DSP them, then burn that playlist to a blank CD
Dec 02, 2008 | Alesis MasterLink ML-9600
Burning
Try to burn a know playlist, you have burn before. Its probably a problem with the nex playlist you are trying to burn.
Oct 06, 2008 | Roxio Easy CD & DVD Burning
BURNING ITUNES MUSIC TO CD
Itunes does have digital rights management, which restricts the number of times you can burn the tracks you've downloaded. It's one reason I prefer sites like mp3fiesta.com who don't believe that if you've paid for the track you should be restricted in using it.
To burn music from Itunes you first have to make a playlist of the tracks you want to burn. Select New Playlist on the left, and drag the tracks you want to burn into this new playlist. When you've done that, right click the playlist name and select "burn playlist to disk."
This will ONLY work a finite number of times (I believe currently it's either 3 or 5) after which burning will be disabled for a track, and if that track appears on a playlist you won't be able to burn that playlist either.
May 12, 2008 | Dell Inspiron 1501 Notebook
Roxio Easy CD & DVD Burning Logo
83 people viewed this question
Top Roxio Computers & Internet Experts
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
