Question about Avaya Lands Phones
Avaya Desk Phone Model 9630. Using the handset to listen in to a call while the advisor is using the headset.
  • rick101 Oct 06, 2008
    Please can you provide me with guidence on how I can use the handset of this phone to listen into a call while the advisor is using the headset to speak to someone.
You can not.
Posted on Oct 08, 2008
How do I auto answer using Plantronics Headset (Savi W740) on a Mitel 4250 Phone?
Plantronics makes an adjunct device that attaches to the telephone base (Velcro) and can lift the handset when the button on your headset is pressed. Unfortunately that's the only way to directly integrate the Plantronics (or any other brand) headsets with the Mitel 4XXX series phone. This handset lifter is actually bundled with some of the SAVI headsets, depending on the actual model you get. Separately it's about an additional $50 option. I recall the Plantronics part number is HL-10. Hope this helps.
Jun 19, 2014 | Mitel Lands Phones
I use the handset lifter for the phone I have (Polycom SE-225). When am sitting at my desk neat the phone, I speak anything above a low normal into the bluetooth headset, like when I am laughing or people...
Unfortunately no. The phone ringer has to be a certain volume for the lifter microphone to pick up the ringing vibrations. If you put it to low, you will not be alerted to the incoming calls. When you're at your desk and can see the incoming calls, maybe then you can lower the telephone ringer volume for some relief.
Good luck from Headsets Direct!
Jan 03, 2011 | Plantronics Voyager 500A Deskphone Adapter...
Issue using software to dial out
Press the Headset button that is right below the speaker button. Make sure that stays lit all the time.
Feb 18, 2010 | Avaya 5400 Series 5410 Phone
I need the pinout for the Avaya 2400 series telephone headset RJ-11 Jack.
I noticed that Avaya headset is different from the Avaya handset or any other standard headset: The outer two pins are switched.
Avaya-Headset-pinning is like this:
Look to the RJ11 and turn it until you see leads from top and from front, then from left to right you look at
1) mic 5V
2) speak
3) speak
4) mic gnd
RJ11 of Avaya-handset and any standard headset/handset from the supermarket:
1) mic gnd
2) speak
3) speak
4) mic 5V
Hope that helps.
Stefan
Nov 24, 2009 | Avaya 2420 Corded Phone
Handsfree not working
Make sure that the phone cord that comes out of the back of the CS50 base plugs into the Handset port of the avaya telephone, not the headset port.  Then make sure the coily cord that comes out of the telephone handset is plugged into the front of the CS50 base.
It takes 1.5 hours to charge to 80% capacity, and 3 hours for a full charge.  You will know it's charged fully because the yellow blinking light on the front of the base will now be solid.
May 15, 2009 | Plantronics CS-50 Professional Headset
Problem using headset - why the handset has to be off hook
Be sure the headset you have is compatible with the Merlin Magix and a 4424 L4D+ phone. You will need to program both the headset status and headset hangup buttons. Headset status will negate the need for lifting the handset. and the hangup button is used to disconnect the call.
Apr 09, 2009 | Avaya Merlin Magix 4424D+ Telephone
Have the 6408D+ phone. Got a Plantronics CS55 Wireless Headset.
You can use an handset lifter accessory, such as the HL1 or HL10 to pick up the handset every time you need to use the headset.
Dec 12, 2008 | Avaya Definity 6408D Corded Phone
Avaya 4610 ip phone--wireless handset?
CS60 from Plantronics. A bit expensive but perfect
Dec 29, 2007 | Avaya 4610
Avaya 6424D+M handset / headset
What equipment do you have? You might need an adaptor.
Is this fixed?
Dec 10, 2007 | Avaya Radio Communications
- JPL Monaural Headset not working
Lift the handset, you might need an adaptor.
Nov 09, 2007 | Avaya Radio Communications
Lands Phones Logo
76 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Shehu Pro
Shehu Pro
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
