Question about TalkSwitch TS-400 Phone
TS-480i IP Phone
Help,
We have this brand new fancy phone and know clue how to use it. Our IT person installed it but he is not fimilar with the phone itself. I would like to have someone come out and train me. I am in Anaheim, CA. Also, we have TelePacfic for our phone service and most of there features (Like 6-way conference calling) does not work with our phone.
The Overhead page, I have not yet figured out. We can't even make a simple 3-way conference call. It is very frustating. I have the TalkSwitch Attendant running on my computer, and that is about the only thing I really like, but at this point I do not think we will spend the $399 to purchse it after the 30 day trial, seeing as how the phone is not really allowing us to do what we set out to accomplish.
Help!
Jackie-Anaheim, CA
4 Suggested Answers
SOURCE: TalkSwitch 48 disconnects call after transfer
You are using the wrong option for transfer -- the one you are using is a conference which requires the person transferring the call to stay on the line. You need the option which permits a blind transfer or announced transfer. This issue is specifically discussed in the manual.
Posted on Mar 08, 2009
  • 32 Answers
SOURCE: Talkswitch caller ID from outside calls not working
Log into your TalkSwitch Management Software.
Go to Telephone Lines.
Under each incoming line make sure that Caller ID is checked.
Click File> Save
Hopefully this will fix it for you.
Posted on Jan 21, 2010
SOURCE: Talkwitch 240VS and TS400 phone
To setup the phone to automatically insert your external dial group (usually '0') before numbers, so you can save them in your phone book, and make calls from your missed / received call logs, you should check the TS400 manual.
For the TS350i you do this 1) press transfer/menu button 2) Press 4 - Call preferences menu 3) Press 8 - Access Code Prefix 4) Enter the number you use for outgoing calls (usually 0) 5) Press OK
Posted on Jul 27, 2010
Using AVAYA IPO 500 R6 V2 IN 1616 and 1608
Check the IPO software is installed correctly and see if the most up to date software is installed, current software version 6.1 for this model.
Uninstall previous version or current version. Then Reinstall the newest version.(6.1)
Should take of any problems you are having with the phone. Since you have replaced it once, the problem lies in the software not hardware.
Mar 16, 2011 | Avaya 1616 IP Phone
We have a Talkswitch system at our office. My Talkswitch 480i now seems to has lost its brains. When I power it down now, it does not seem to talk to the switch to obtain its configuration. It always...
The problem would seem like the phone is not finding the TalkSwitch system, or the configuration file for the phone does not exist. There are usually only 3 things that can cause this issue to occur:
1. Verify that the IP address for the TFTP Server, this must be your current public IP address. This can be found in the phone's menu under Networking -> TFTP Server -> Primary TFTP Server
2. Ensure that port 69 is open in the firewall at the TalkSwitch's side. Run the TS firewall test to confirm that it passes.
3. Confirm that you have the correct MAC address entered in for the Extension in the TalkSwitch software
Jan 05, 2011 | TalkSwitch TS-480i
I got error message on 2 Avaya 5610SW IP phone: one is showing: incompatible Disc and another shows:Call Barred Disc. I have no clue to issue. is there anyone can help me out?
Incompatible means that what you dialed is not recognized by the system.
Call barred means your phons is restricted from dialing whatever you are trying to dial (900 numbers etc)
Aug 11, 2010 | Avaya 5610 IP Phone
Is there anyway to change the name that is
It's part of the phone system, it's software. Find out who controls the phone system and get your name on it.
Nov 25, 2009 | TalkSwitch TS-9133i
I have recently moved to a new office which has the T7208.
This is probably not related to the phone itself but more likely related to the telephone system it connects to. You can configure an IP phone to connect to a telephone system at a external service provider but I would be surprised if their time was out by seven minutes so I'm guessing that you have an IP PBX in your office somewhere. It would have the names of the people at the different extensions. You probably have a support person who looks after your computers and operating systesms it is fairly normal in smaller offices for that person to also look after the telephones. I do this for two small businesses which have about 40 employees all togeather. Have a chat to your boss, someone should be responsabile for your phone system too. As time goes by it will just get worse and if it has a failure someone should know how it all works. Hope this hepls
Jul 23, 2009 | Nortel Business Series Terminal T7208 -...
Only one line works
check the ip phone cable and reset the ip phone all setting
Mar 31, 2009 | Polycom SoundPoint IP 320 SIP IP Phone
Hi My Panasonic IP phone got short cercuited, any repairer?
brand new --still under warranty
get a warranty replacement phone or a refund for your money
Nov 22, 2017 | Panasonic KX-TG5438F 5.8GHz Digital...
Number of Rings Before Pick-up
Log into your Management software.
Go to each phone line.
At the very bottom of the call handling section you should see routing options. Change these setting to the desired number of rings.
Hope this helps you.
Oct 22, 2008 | TalkSwitch TS-480i
I need help
If the phone displays the message "personalization code blocked", then the phone is blocked due to too many wrong unlocking attempts. I recommend you to contact the service provider or visit the site Unlocking4U.com and contact them about your issue to fix it.
Unlock Phone Unlock Codes Cell Phone Unlocking Service Online Unlocking 4
Dec 11, 2017 | Toshiba TS 10 Cellular Phone
TalkSwitch TS-400 Phone Logo
73 people viewed this question
Top TalkSwitch Lands Phones Experts
David Burbee
David Burbee
Are you a TalkSwitch Lands Phone Expert? Answer questions, earn points and help others
