Question about Jensen VM9510 Car DVD Player
Blue screen I HAVE TRIED CONNECTING THE PINK WIRE TO A GROUND AND NOW TO A TOGGLE SWITCH. THE BLUE SCREEN WENT AWAY BUT CAME BACK ON AND WONT GO AWAY AGAIN
Just to the bypass code but if the teh battery is disconncected you have to do it again
Posted on Oct 07, 2008
DUAL XDVD9101 PARKING BRAKE BYPASS
STEP ONE. Ground the E-Brake wire.
No matter which method you use, you must ground the brake detection wire. I suggest you tap it into the ground wire on your wiring harness (ensures a good ground).
FACTORY RESET METHOD (not permanent)
1 Go to the Menu
2 Get to the Settings Menu
3 Select <yes> to Reset to Factory Settings.
Have recently heard complaints of this method not being permanent, as this is needed whenever they want to watch a DVD. Also, radio and screen angle presets are lost.
METHOD 2
AUDIO CD METHOD (Permanent)
1 Insert Audio CD
2 Press PLAY
3 Press STOP twice on remote
4 Enter 26604 on remote
5 Press ENTER
6 Take out Audio CD and Insert a DVD
METHOD 3
DVD METHOD (Permanent)
** Insert a DVD
** Let it play until you hear sound
** Press STOP twice on remote
** Enter 26604
** Press ENTER
The blue warning screen should immediately go away after pressing the last digit of "26604." Still press ENTER as a precaution.
The 3rd method seems to work with most of the duals
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 18, 2009 | XO Vision XOD1742BT Car DVD Player
Watch a dvd while driving pioneer AVH-P4000 DVD
Hi Dave
No ....go to a hardware store buy a toggle switch than get a single speaker wire (small wire) attach it to the red wire on the back of your pioneer deck (make sure to leave the red wire in back of deck as well) and attach it to the power on the toggle switch do the same with the black wire (ground wire) the black wire will go into the toggle switch under the power wire. finally install the parking break wire from the pioneer unit to the last slot on toggle switch and this should do the trick if not swap the ground spot for the brake spot on toggle switch >>>> MAKE SURE THE TOGGEL SWITCH HAS 3 HOOK UPS to do this correctly (your system will provide sound with the toggle switch off (Blue Screen) but when toggle switch is on you get video while driving) good luck
Mar 03, 2009 | Pioneer AVIC-D3 Car DVD Player
Navigaiton bypass/hack for Jensen vm9512hd w nav101
buy a 3pin toggle switch
add a wire to the red wire (12v) in back of unit
do the same with the ground (black)
now install theses wires to the toggle switch (toggle switch has pictures of ground and positive pins)
install the brake wire to the pin that is empty on the toggle switch
power everything including the new installed switch and DVD should show
if not just switch the brake wire with the ground wire on the toggle switch
but the navigation should work with the unit while your driving...........this is the real trick to solve your problem
good luck
Feb 27, 2009 | Car Audio & Video
Blue screen with alpine DVE-5207
there is a ground wire off of the back of the deck find it using intall manual the screen is blue because this wire isnt hooked up and set properly this is a safety switch so the driver cant operate the vehicle and try to watch a movie at the same time
Jan 26, 2009 | Car Audio & Video
Jensens UV9 By pass the brake
hook up the ground with the pink and when you are in am/fm mode hit the dvd set up button on the remote, input the no. 5, 4, 3, 2, 1, and 0 make sure it beeps after every no. has been pressed. then it should bring up the hidden menu select the hammer option and turn on the brake bypass option. your done.
i took this from the uv8 brake bypass. it works on the uv9.
Nov 12, 2008 | Car Audio & Video
BackGorund Change on a Jensen VM9311TS In-Dash DVD player
There is no e-brake override code. You have to hardwire it to bypass the e-brake. Take the peach-colored wire and ground it to metal inside the dash. Put a toggle switch inline on the wire and mount it somewhere you can reach it. When you get the blue screen when starting a movie, open the switch for 3-5 seconds, then close it again to reapply the ground. Your movie will start up, and you can then drive away with it playing.
Sep 24, 2008 | Car Audio & Video
Phase linear uv8 parking brake problem
for the uv8 to bypass the parking brake to watch dvds you have to take the pink wire and put one end to one of the screws on a two screw toggle switch connect the other end of the pink wire to the other screw and connect that to the black ground wire
Mar 12, 2008 | Phase Linear UDV9010 Car DVD Player
How do i bypass the parking brake switch in order for my video to play
hook the pink wire to a toggle switch and ground the switch to the chassis. when the unlawfull screen comes on then turn the switch on for a few seconds then back off for a few seconds then back on and the screen should go away. I done this with mine and it works. unfortunately you have to do this every time.
Feb 23, 2008 | Audiovox VM9311TS
Bypass brake for a jensen vm9311
Don't pay for it....Just read it:
The code is a permanent way of disabling the brake override on the jensen units.
There are two ways of doing this:
Insert the DVD
After the disc loads and plays you will see a blue screen telling you "it is unlawful to drive with a movie blah blah blah"
1)Activate the brake sequence and disable the blue screen using the hand brake, the switch method or anything else to give the unit its three pulses to disable that freakin blue screen.
(What I did was I installed my radio entirely, then took the pink wire and touched for two seconds, removed for two seconds and then touched and held the negative pole of a mower battery laying on my passenger seat until the screen was no longer blue.)
2) Next, on the main remote press stop twice, then 1, 2, 6, 4.
You will now see a hidden menu that says:
Region Code
Brake Override (I know you're drooling by now)
Macrovision (Watch all the burned and pirated movies you want if this option is off)
Loader Version
Model Version
3) Using the right joystick on the unit, navigate to the options of your choice, click on them to toggle on, off or which region code you want.
This is what you want:
Region Code: 1
Brake Override ON
Macrovision: OFF
When your done, click SYS SETUP on the main remote TWICE to save the settings and bingo, your done!!! Hooray!!! You can now kill your whole family in the car while watching that adult movie while your driving.....
The other way of doing this is by not engaging the parking brake sequence, thus you're inputting the code blindly.
1) Insert the DVD and you'll get the blue screen.
(If you have more than one tv, the unit itself will have the blue screen but the additional tv's you have plugged in will NOT, they will show the dvd menu. Thus you will be able to see the hidden menu on the additional screens after inputting the code, but not on the main unit because of its blue screen.)
2) On the main remote, push stop twice and then 1, 2, 6, 4
3) Push the joystick on the unit SOUTH twice and then click it once.
4) Press SYS SETUP on the main remote twice to save your settings.
It may take a few tries but you'll get it. This method can be done if you don't want to bother temporarily activating the brake sequence, but if you only have the unit and no additional tv's, its #$%^&* damn hardbecause you can't see the settings your changing.
I tried to make this as clear as possible. If you have questions, private message me or post here.
This code DOES work.
Best of Luck!
By the way, this is for informational purposes only and I will not be responsible for anything bad/stupid/ignorant you do with your Jensen unit.
(Sorry Jack Sap, but this stuff should be free...)
Oct 13, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9510 Car DVD Player Logo
59 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
