Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
Rear tub and shaft
Thank you for your earlier response. My problem is now how do i go about finding this second rear tub(different size) I have no part #s to work with at all. where do I start?
this is my model number...110.42822203
Thanks
David
410 687 7286
410 258 1074 cell
    Sergeant:
    Champion:
  • 324 Answers
The tub comes with the shaft.
Posted on Oct 31, 2008
Can't find horn relay on 1998 Buick LeSabre
On most earlier Buicks it is on the radiator support unit, usually driver's side up pretty high. Small metal can size of your thumb with several wires attached.
Feb 12, 2015 | 1998 Buick LeSabre
Removing the Drum from an LG WM1832CW Front Load Washer
Well, I assume you have removed the bolt that holds the motor to the tub shaft. After you remove all the motor system then you would only have the tub's hub shaft out of the back of the outer tub thru the bearings and bearing seal. It should easily slide out. If not, I would support the outer tub half on two saw horses or equivalent and hit shaft as hard as you can with a rubber mallet. Remember to have a system to catch the inner tub when it falls out.
Jun 11, 2017 | LG Washing Machines
Help! changing drum bearing lg wm2277hw
The best way I can suggest through my own personal experience is to turn the tub upside down withthe spider shaft facing down. Hold the tub up in the air about a foot and drop the whole tub on to the ground letting the shaft hit the pavement. It may take a few times to do it but it has always worked forme.
Hope this helps.
Nov 05, 2011 | LG WM2277H Front Load Washer
How do you remove the rear tub bearings on a whirlpool duet front loader. tub is out of washer but can't get shaft out
you have to buy the whole tub or basket,each part is around 230 dollars.the basket part number is W10250573 and it's around 215 dollars,this is the part with the shaft on it,the rear outer tub part number is 285984 and it's around 225 dollars.
Apr 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a nissan xtrail 2004 model and have just had a front right wheel bearing replaced, now i'm told by the mechanic he wasn't able to remove the bearing so instead he had to replace the drive shaft, is...
It doesn't seem like it should have been all that bad with a 2004.Please tell me a couple things though.Are you in an extreme weather environment?Fairly hot summer,fairly cold winter,cars rusty within 5 years?Did he call it a drive shaft?If it is front wheel drive,it is more likely a CV axle,however,I am not familiar with the setup of 4 wheel drive vehicles.There may be different interpretations between the 2 countries but to me,a drive shaft connects the transmission to the rear axle.The axle is what the rear tires of a front wheel drive are held together by.A CV axle is what goes from the transmission to each of the front two tires,each tire having one CV axle and joint.I would get a second opinion.Good luck mate!
Aug 05, 2010 | Nissan Xterra Cars & Trucks
What size of u joints are in the rear drive shaft of a 1998 chevy 1500 ext cab Z71?
Because of the different drive shafts used on different optioned trucks go to your after-market...Napa etc store and give them your specs on your truck.....they will give you that info relating to their part # s for YOUR truck.
Aug 17, 2009 | 1998 Chevrolet K1500
I AM REPLACING THE BASKET ASSEMBLY ON MY KENMORE FRONT LOAD WASHE
The shaft on the spin basket assembly is not lubricated. The shaft is inserted through the sealed bearings located in the rear outer tub shell. Placing any grease on the shaft would end up in your wash and damage your clothes.
Apr 03, 2009 | Kenmore 42822 Front Load Washer
Rear bearing noise when in spin cycle Whirlpool GHW9100LW2
the reason some repair guys dont fix this problem is that it is so expansive to fix the bearing is molded into the tub so you have to buy a new tub assembly and when whirlpool bought out maytag they raised all the prices on everything it would be almost 300 for the tub assembly than it takes about 1 to 2 hours than if you need a new shaft assembly that is more than the tub so thats why they dont fix them
Feb 28, 2009 | Whirlpool GHW9100L Front Load Washer
Terrible noise on spin cycle, stainless drum is loose inside plastic tub, wore the front half of the plastic tub down due to friction. Took washer completely apart, found the spider arms cracked. It...
Just had the same problem 1 month ago. My Whirlpool Duet front load made that terrible noise. 2 of the 3 spider arms were cracked. I hade a new hole tub with the spider arm and the shaft , because it is 10 years limited waranty . But if it is not under waranty it costs about 270$ for that tub you can buy it from many appliance parts web sites on the net. Good luck, huge job to all remove that thing
Dec 03, 2008 | Washing Machines
Rear Tub and inner basket reassembly
If the shaft of the steel inner basket does not show any signs of wear such a grooves or scoring, the problem is probably with the tub shell you ordered. I have experienced this problem before on ONE occasion and had to reorder the rear tub shell. To answer your question, "No", you shouldn't have to force the shaft into the bearing, and I probably wouldn't recommend it. However, before you assume all is lost and have to resort to another order, try using some very fine sand paper or emery paper on the basket shaft to see if this will allow it to insert easier. I hope this doesn't sound discouraging.
Sep 19, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing Machines Logo
56 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
