Question about Fahrenheat Electric Convector Baseboard Heater, 240 Volt
Instalation I want to install a Fahrenheat Model 2546.... and i have 3 cables coming out of the wall have the white, black and the ground. But in the heat side i only had the ground and a red. Can someone tell me how to install this!!! Thank you Rubie
  • Deputywilson Nov 12, 2008
    Just wanting to wire a F2546 Fahrenheat electric heater. I've done a lot of my own wireing, but most often use 12/3 for 240V. If I understand correctly, this application uses 12/2.
    Scholar:
  • 68 Answers
First this diy stuff with electricity is scary. You describe the wiring as 3 wire 110, I understand the heater to be 240, the heat side of what? The heat side you say you only had the ground and a red.
You have to be more clear about the heater connections, what voltage, what amperage, what number of conductors you have, what distance to the breaker, what the breaker size is, and much more to do this correctly. As to it being wired with 12/2 that is possible if it were 110 volt and required that much amperage capability, along with a chassis ground, making the wire 12/2 with ground, but that is not 240 that is 120 volt.
Write me at wbwill@sbcglobal.net or look me up at allexperts.com and we will go from there.
But wiring up heaters when there are this many questions is leaving a huge chance for something to go wrong.
Write me back or hire an electrician, one way or the other, it needs to be safe, tested, and checked when completed.
Will or wbwill
Posted on Nov 15, 2008
I have the Fahrenheat Model FUH 724 heater. The manual states that it can be wired as a 240v 7500W unit but the directions and the unit itself only allow for three wires to be connected Black, White, and...
1st you will belucky if you actually have 240 v, most
homes are usually 220v. In youyr case you need to start at the breaker panel.
This is an example:
You have a Double Pole Single Throw breaker. Black
Wire is hot and goes into one side of breaker,if you havea red wire that goes into the other have of the
breaker.
The white wire ties in the nuetral bar and the bare wire into the ground bus bar. At the unit you hook up the red and the black wire which will supply the 240
Volts, you could tie the white and the ground wires together into the grounding terminal
Jan 01, 2010 | Fahrenheat Ceiling-Mount Industrial Heater...
I am trying to install a fahrenheat f2543 heater with a fta2a double pole thermostat. there is a 12/2 wire coming into where the heater is being installed. how do i connect the red and black to the white...
Hi, this is very easy for you to do.The 12/2 Romex wire coming in is the power which you know. What you do need to know, is the voltage coming in? Sometimes they will use 12/2 Romex with ground for 220, 240, operation. You need to know if the T-stat is Line voltage 220, or 240 volt. You have to have the same voltage for both for it to control. Reguardless of the voltage, lets say it is in the 220 and up range. You take one of the 12/2 wires, white or black and hook it to the black or red on the T-stat and the white to the other one, red or black. Thats it, you are done! If the T-stat is 2-pole I am sure it is a high, Line votage T-stat. Best of Luck,
Shastalaker7
Nov 09, 2009 | Fahrenheat Built-In Baseboard Thermostat...
I am trying to replace a electric baseboard heater that is 220 volts and I am unsure about the wiring. the heater has a red and black wire and there is a white and black wire coming out of the wall.How do...
if ur are replacing the heater and it was originally 220/240 ur wiring should b ok but to b sure trace the line wire back to breaker panel and look at breaker the white and the black should b hooked up to separate breakers if the white is hooked up to a ground bar usually on the inside side of the panel and the black hooked up to breaker ur line is 110/120 and will cause problems when hooked up. if the lines r 220/240 than red can hook up to white and black to black
Sep 25, 2009 | QMark FBE15002 electric baseboard heater...
Wiring a ceiling fan w/light
To add to red54's comments:
This is what I believe you have:
- one source in the ceiling box (black & white)
- one donwline circuit in ceiling box going to another wall/ceiling box (black&white)
- on switch wire in ceiling box coming from your wall switch (black & white) -- this is the white wire which will be hot when the switch is truned on
Here's how it should be connected:
- all 3 blacks in ceiling box connected together -- no other wires in this bundle
- white wire (which is hot when switched) coming from switch connects to the black/blackwhite fan wires
- connect all reamining white wires together in bundle
- connect all ground wires together
It's that simple. Trick is figuring out, of the three cables in the ceiling box, which is source, which is downline, which is switch.
Maybe red54's procedure can help you figure that out.
May 09, 2009 | Hunter 22890 52'' Low Profile Plus Antique...
Whirlpool Electric Cooktop Wiring
sound like you have a three wire setup on you house most commonly the black wire is the L1 wire or one of the hot wires and the red is the L2 wire and is also one of the hot wire in this instance your white wire would be your neutral/ground wire this would connect to the copper wire on your cook top depending on the model it would have a red wire a black wire and the copper wire but some may also have a white wire also if this is the case on a three wire setup you would attach the copper and white wires together also if needed you can goto the maufactures website and download an instalation guide.
Mar 25, 2009 | Whirlpool GJC3034 Electric Cooktop
Not sure hooked up correctly
The black and white wires should both go to the breaker. Not just the black wire. If you hook only the black wire to the breaker then you are only feeding the unit with 110 instead of 220. Both wires need to be hot.
Jan 20, 2009 | Fahrenheat Electric Convector Baseboard...
How to hard wire 240 volt wall heater
Black is 120v hot
Red is 120v hot
Black and Red go to opposite legs to get 240v between them.
White is 0v neutral
copper is Ground
Dec 27, 2008 | Fahrenheat (FFH1614) Wall Mounted Panel...
Wiring problem
those wires dont go to the down draft. those colors are to hook up the stove. do you have the instalation instructions?
Nov 09, 2008 | Jenn-Air JED8430 Electric Cooktop
Install and hot wire heater
You can be assured that the element is 240 volt. The fan motor is also rated at 240 volt. the wires you have black - black are the connections you make to the line. Use a 12/2 with ground. Use a double pole 20 breaker in your panelbox. The green wire is the equipment ground - connect this to the bare wire from the 12/2. On the 12/2 cable - there will be two colors, one black and one white. Wrap a couple of turns of black tape on the white wire both at the heater location and on the white in the panelbox. connect the 12/2 to your 2 pole breaker, the black wire and the taped white to the breaker.
Sep 05, 2007 | Fahrenheat FFH1615 Heater
Fahrenheat Electric Convector Baseboard Heater, 240 Volt Logo
186 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
