Question about Coby MP-200 MP3 Player
Coby 200 mr player 1 g
New player w newly installed battery. Will not turn on.
  • 2 more comments
  • true musical Nov 24, 2008
    the red light is on when charging but its been charging for 3 hours and it still dosent turn on
  • Anonymous Dec 15, 2008
    tried few batteries. just does not seem to recognize power.
    Won't turn on after I added songs to it
  • Anonymous Apr 25, 2009
    I lost my instruction book... how do I turn on the coby mp200?
  • 4 Answers
Your mp3 player won't be able to be fixed so you better just return it and either ask for your money back or get a new one
Posted on Jan 06, 2009
My coby remote does not work right with my coby dvd player model#dvd-528b
It might be possible that your batteries are weak. Install new batteries.
Nov 17, 2011 | Coby Televison & Video
When I plug in my mp3, i cant sync because wmp doesnt recognize the mp3 at all. I was trying to find software or driver download to help fix. please help!
Hi, Looking for Drivers.
In order to download the right driver for a Coby MP3 player, you'll need to go to the Coby website support page where you can download software drivers (See Resources). To find the driver you need, you first need to identify which device you're using. Select "MP3 & Portable" under where it says "Select a Product" on the first box on the left. In the second box, it will be "MP3 & MP4 players." The final box lists all of the MP3 and MP4 players that Coby produces. You'll need to find your MP3 player in this list. The designation will be letters and number such as "Mp200". It should be listed on the box. Once your MP3 player is selected, clicking on the "Submit" button at the bottom will cause the text "Available Downloads for Mp200" (or whatever your MP3 player is called) to appear towards the bottom of the screen. Underneath, there should be a link for "Driver," if there is one available for your player. Clicking on that will allow you to download it.
Installation
If you click "OK" on the download screen, your driver should install. It will likely be in a ".zip" format, which means another program is needed to "unzip" the file so that you can install it. An example of such a program is WinRAR (See Resources). This program needs to be installed first, before it can be used to unzip your driver file. After you've downloaded the program, opening the installation file will begin the installation process. Choose a directory for where the program will be installed. After installation is complete, you can go back to the ".zip" driver file. Double-clicking on the file will bring up a new window. You can now drag your driver files from inside the .zip folder to any folder on your computer that you wish. There will be a file marked "Setup" among the unzipped folders. Opening this file should allow you to install the drivers you need on your computer.
Also Coby mp3 player not recognized by the computer.
Why is my Coby player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the Coby mp3 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: Coby mp3 player can connect to your computer in MSC or MTP mode. Exceptions are Coby mp3 player Connect and Coby mp3 player Express which only use MTP mode. MTP mode is the recommended and default method for Coby Players when used with Windows OS.
The Coby player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Hope that helped..
Feb 21, 2011 | Coby MP-30523 MP3 Player
How can i installing coby manager and installing coby manager ( Mac OS X)
For the MP200 you can download and install Coby Media Manager.
Open the internet page and enter cobyusa.com in the address bar.
Next select Support in the page top.
In the support page, under Knowledge Base, select Coby Media Manager fix for MP822: this is the download page for the complete program.
Scroll down to see the download link for Mac OS X 10.4 or later and follow the steps for how to install.
When you've installed Coby Media Manager, you'll be able to setup your player, the MP200:
In Coby Media Manager select Tools > Device Manager...
Select MP200 from the Devices List ; Add>> ; OK for having this player setup as your Favorite.
Use the Help function (F1) for how to use the manager.
Sep 07, 2010 | Coby MP-200 MP3 Player
Installation
If you have deleted the program from your computer, you should be able to plug the Coby player (TURNED OFF) to the computer and re-install it.
If Coby Manager program is no longer on the Coby player (If you re-formatted the player), you can get a copy of the MANAGER here:
CobyMedia Manager fix for MP822 (Windows XP/2000/Vista)
Don't let it throw you that it says it's for the MP822 - it also works great for the MP610
1. Install Coby Media Manager from download
2. Open Media Manager
3. Plug your COBY player (THAT IS TURNED OFF) into the USB port - it will show up in the "DEVICE" tab
Apr 03, 2010 | Coby MP-610 MP3 Player
Coby mp605-2g
My Coby MP605-2G is not turning on
Sep 09, 2009 | Coby MP-705 Digital Media Player
No code for my universal remote.
I work for COBY tech support. Our customer service phone number is 1-800-727-3592.
I know this isn't what you want to hear, but unfortunately, there is no way to control a COBY dvd player with a universal remote. If you need a new remote, please call the number above so that we may give you the instructions for obtaining a replacement directly from COBY. The cost is $6.00.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. I hope I've earned a positive rating from you today.
Please let me know if I can be of further assistance.
Jul 01, 2009 | Coby MP-610 MP3 Player
My COBY mp3 froze in middle of singing a song
try to connect your mp3 to a PC. Check if the PC can detect your player as " hardware device" if does.
scan the newly found hard drive by "ESET nod32 anti virus" if you don't have this software you can download it freely on the web. Or simply select the newly found device and reformat it (right click your mouse and select "reformat")
Jan 15, 2009 | Coby MP-C7085 MP3 Player
Need help turning on cobymp200 mp3 player
ok if it is not coming on even if you hold down the button then it is the battery check it and you might find a plastic wraper on it it prevents the mp3 player from turning on
Jan 05, 2009 | Coby MP-200 MP3 Player
Coby MP-C848 MP3 Player
how do i get music on to my coby mp3 from the computer, my daughters works from the computer why doesnt mine
Jan 01, 2007 | Coby MPC-848 MP3 Player
Coby MP-200  MP3 Player Logo
209 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
