Question about Whirlpool Calypso GVW9959K Top Load Washer
Some clothes not clean or even completely wet after wash cycle finished
When washing clothes, especially in the cold cycle (which I use frequently), there are some articles of clothing that are not clean and, in fact, some that are not even completely wet--there are completely dry spots on item. We have checked the water hoses and the filters into the machine and have cleaned them again to no avail. This machine has certainly not lived up to its hype-----many times clothes are very wrinkled and, no, I have not overloaded machine. When I wash sheets or even a lone tablecloth, items are twisted. Very, very disapointed.
  • Anonymous Oct 11, 2008
    my sheets come out the wash looking like i made a rope. I was wondering if the new machines without the center agitator aleviate this problem
  • 94 Answers
Ebay item number 200262803398 is a cheap PDF service manual for this model.
prem
Posted on Oct 14, 2008
Grey spots on our white clothes after wash
do you use affresh to clean your front loader? deposits of soap and other such things can be stuck around the inside tub of your washer. try this porduct out it works great on all front loaders use hot water with the affresh pellet with no clothes and run the machine through a cycle this also helps with any stagnant water smells also have you cleaned out your pump lately. * note remeber to put the pellet on the inside of the machine not in the soap dispenser
Apr 28, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Clothes as still wet when it is finish after washing is done
Hello Sassylips,
Clothes will always be wet after a wash but if you are saying that they are soaking wet rather than just damp from a frontloadre like yours then you may have an obstruction in the pump system.. That could be anything from a screen preceding the pump, some obstruction in the pump itself, a pinched or clogged drain line exitting the washer or restrictive flow in your home drain system. A simple check that can be done would be to take the drain line out of the house drain and put it in a barrel. Watch the flow of water when the washer cycles thru a standard wash and see if it appears to be a reasonable level. A trickle would indicate one of the problems I mentioned previously. Have you ever cleaned the drain screen? Those are a few potential issues that could cause your clothes to remain wetter than they should be after a wash cycle. Also, you might try washing a few articles of clothing and then check to see if they are as wet as larger loads when the cycle is complete... Hope these ideas help you identify the cause and are able to resolve your problem...
Regards
Nov 29, 2009 | Frigidaire ATF6000ES Front Load Washer
I am very unhappy with this machine and sorry I bought it! It uses so little water that sometimes when I take the clothes out after it is finished washing I can see dry spots on the clothes that never even...
How about putting the clothes in and pouring water over them with a jug before the washer starts its program ?.
It could also be that the water level switch is out of tolerance and needs replacing
Most machines have a pre-wash cycle as well
Oct 12, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Me and my kids are going nuts because everytime we wash something, it goes off balance the clothes are wet and it flashes ue ''uneven'' even if it is only 1 piece of clothing . I have adjusted all the legs...
if the cycle does not gets complete then its --
it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jul 25, 2009 | LG Washing Machines
After the wash cycle is complete the clothes are still wet.
Open the machine and remove the drain pump. Clean out any debris and try again.
Remove the front panel.
The pump should be directly in front of you. Open it and clean it.
This procedure will have to be done occasionally.
Mar 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dripping wet clothes
will be an UNBalanced load, maybe there was not enough clothes in the load so in that case the drum would not be able to distribute the load evenly so gave up on the spin, hence wet stuff!
Jan 27, 2009 | Haier Washing Machines
Not washing clothes
Sounds like you need a new timer.  Sorry.
Oct 14, 2007 | Zanussi IZ161S Front Load Washer
Goes through washing cycle but doesn't dissolve the tablets or cleans the clothes.
Clean out your outlet filter; this is to be done regularly once a month, depending on your usage. Re your tablets not disolving, try using front loading washing powder. Also refer to your manual..........
Jun 10, 2007 | Bosch Classixx WFL 2066 Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
156 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
