Fitting new drive belt to tricity bendix aw405
Can find adjustment on motor to fit new belt
    New Friend:
  • 38 Answers
Most have no ajustment little tip put belt round the largest wheel then on the motor spindle put a flat blade screwdriver and leaver the belt on if you can turn the drum this helps
Posted on Oct 06, 2008
Tricity bendix tm 550 motor spring adjustment
If there is no provision for adjustment, the spring may have lost its tension and will have to be replaced.
Nov 18, 2016 | Tricity Bendix Dryers
How do I replace a belt on a tricity bendix TM221W tumble dryer - a video of this would help. thanks.
no video
unplug it
you have to take the top and back panel off
take photos of how the belt is fitted before removal
see what holds the belt on or stops it from coming off
undo what is required and fit the new belt
then reverse all the take apart steps till it is fitted
Tricity Bendix TM221W 91609308601 Tumble Dryer Functional parts Spare...
Dec 26, 2014 | Tricity Bendix Dryers
How to fit belt on a tricity bendix tm310w tumble dryer
round the pulley then around the tensioner then around the drum.
Jun 08, 2014 | Tricity Bendix TM310W Electric Dryer
How to take back off tricity bendix aw 1000 w
Tip the machine on it's side and fit it from underneath. It's a bit fiddley.
Dec 13, 2012 | Tricity Bendix AW1000W Front Load Washer
I have a tricity bendix 1100s need to fit new fan belt but do not know how or where it should be fitted help and also how do i get the bottom of of the machine in anticipation thankyou
If there is no removeable rear panel, then you have to remove the rear half of the cabinet to access the drum motor.
Again , if there is no rear panel, you cannot access it from underneath.
Should there be a removeable rear cover, then remove it, and you will see the motor and drum pulley.
Hope this helps.
Feb 11, 2010 | Electrolux Washing Machines
I am trying to fit a new belt to my Tricity Benix TM320w. I have fed it around the drum, looped it under the motor, but the belt is far too loose to turn the drum
There is a pulley to tension the belt that sits in a slot on the floor of the dryer. If you have the belt wrapped around both the motor and the pulley try going up and under the tensioner in the opposite direction. I've been on hundreds of house calls for this simple solution. Good luck, Dana P.S. You will have to hold the tensioner back in order to get the belt on, if you do not have to hold it back than you are going in the wrong direction. Also, one side of the belt is ribbed and not the other, make sure you've got the correct side down. Look at the motor wear marks on the old belt, that will tell you which side goes against the drum.
Sep 06, 2009 | Tricity Bendix TM321W Electric Dryer
Tricity Bendix Condensor Dryer
the belt needs to go over motor rod first this means you have to take cover off then release the spring that attached to the motor so there is some play with the belt ,then pull the belt around the drum,quiet tight but you can do it,then pull the motor spring back into position to tigthten the belt put back together.... job done
Jan 19, 2009 | Tricity Bendix TM310W Electric Dryer
I need to change the drive belt on a Tricity Bendix 1200 washing machine. I have got the top of and can see the hole at the bottom of the machine but can't reach where the belt fits.
the belt goes round the motor spindle at the bottom. tape belt to large pulley. tilt machine backwards and put belt over motor shaft and tape into position. start belt onto main pulley and turn it so belt eases on. it is a tight fit
Jul 22, 2008 | Washing Machines
Washing Machines Logo
118 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
