Question about Honeywell Heating & Cooling
How do you change the filters in a Honeywell F300A-1625 Electronic Air Cleaner ?
  • 63 Answers
Here is a complete manual.
http://customer.honeywell.com/techlit/pdf/PackedLit/69-0756.pdf
Posted on Oct 06, 2008
    Genius:
  • 1,550 Answers
The link provides you the picture view of pre filter location .
Click the link below
Filter in Honeywell
No 5 displays pre filter
Thanks for using FIxya
SAM ANDERSON
    President:
  • 1,450 Answers
  • TripleTauto
    TripleTauto Oct 06, 2008
    click on service and the cleaning
    Genius:
  • 1,124 Answers
You have all the instructions here: http://www.cleanairwholesale.com/site/1272068/product/F300A1625
Download the Honeywell F300 Installation Guide - You will find the directions to replace the filters.
    Genius:
  • 3,422 Answers
Locate your furnace and the filter compartment. This compartment is normally covered by a strip of metal that slides in and out of place. Step2 Determine the size of the air filter that needs to be replaced. The sizes are noted on the side and usually appear as 16x24 inches and other similar sizes. Step3 Purchase a replacement filter in the size required for your system. There are a variety of filters to choose ranging from the inexpensive standard spun glass filters to pricier synthetic polyester fibers. Step4 Consider high efficiency filters if you live in warmer, dustier climates as they do more than just capture dust particles. The high efficiency filters can trap tiny particles of dust, pollen, mold and other irritants. Step5 Look at hepa filters and filters coated with chemicals to kill bacteria if allergies and other irritants are a concern for your family, . Step6 Use a black permanent marker when you change the filter. When you slide up the metal guard, note the direction of the air flow marked on the side of the old filter and draw arrows in the same direction on the metal guard. This way you will have no question which direction to insert the new filter. Step7 Replace high efficiency filters at least 4 times per year. Read the manufacturer's label as most recommend changing your air filter on a monthly basis. (High efficiency filters do have a longer life expectancy than the less expensive spun-fiber filters.
My Honeywell Type No. F50A Electronic Air Cleaner arced continuously even though I had cleaned it a few days prior. I shut the unit off and removed the air cleaner cells. Is it safe to run the furnace...
Yes you can run the furnace with out the electronic air cleaner for awhile.... It you are in a very dusty conditions than I would not run it very long a day or two....because you will not have any protection for dirty getting stuck on the evaporator coil or if you have a 90% gas furnace the secondary heat exchanger...and restricting air flow.... You can put in a 1" pleated air filter the same size as the total of the two cells in place of the cells till you can get the electronic working..... Sounds like either something big is caught across the cell plate or they are still wet and have not dryed out completely. Hope this helps.
Mar 02, 2011 | Honeywell (F50F1032) Air Purifier
Light not on in front of filter . Its a Honeywell Electronic air cleaner and I cant tell if its working because light is off.
Neon light on air cleaner does not come on
1. Make sure the furnace or air conditioner fan is running.
2. Make sure the access door is firmly closed.
3. Make sure the On-Off switch is in the On position.
4. On models without the Solid State Performance Indicator, if the electronic cell(s)
are wet, check again in two to three hours.
Link: Manual
May 15, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
I have an F50f electronic air cleaner. none of the
you need to change the power supply please contact your heating and cooling contractor for service on the unit.
Mar 03, 2010 | Honeywell (F50F1032) Air Purifier
After cleaning my electronic filter, it runs well for about a day. Then, it begins to continuously arc until I wipe the wires clean. Again, no arc for awhile, then, continuous arcing. Is there something I...
It is normal to hear occasional snapping from your Electronic Air Cleaner. This occurs when larger particles are caught by the ionizer wires. Continuous snapping is not normal however, and should be investigated as outlined below: Please note that the metal electronic cells may have some sharp edges; use care when handling the cells. Wear gloves to protect your hands from being cut if needed. Remove both electronic cells. Make sure that there is no hair, dirt, sand or any debris on the bottom inside the Electronic air cleaner. If there is, remove what you can by hand. If a lot of debris is left in bottom of the Air Cleaner, you may want to use a vacuum attachment to see if you can vacuum up what you can. Do not vacuum the Pre-filter or Post filter this may damage it. Close the access door, and then turn on the Electronic Air Cleaner and the system fan. If the snapping continues with the cells removed, contact your heating and cooling contractor for service on the unit and turn off the Electronic Air Cleaner’s power. If snapping does not continue, make sure the electronic cells are clean, dry and properly installed. Inspect the electronic cells for bent collector plates, broken wires between the plates, dirt on the insulators, and damaged collector contact tabs located on the top of the cells. Make sure the pre-filters are in good condition and are in the cabinet slot farthest from the furnace (The order of the Electronic Air Cleaner Filters are from the return duct to the furnace is: Pre-Filter, electronic cell, and then Post filter, if your Electronic Air Cleaner has one). If the snapping persists and you are unable to locate any physical cause, please contact your heating and cooling contractor for service on the unit and turn off power to the Electronic Air Cleaner.
Jan 25, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
F300e filter clicking
You may have a large particle of debris trapped or one of the cell plates is bent and too close to one another.
Jan 17, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
Honeywell F50e electronic air cleaner indicator light stays on
Could be a faulty sail switch in the air cleaner that keeps the air cleaner on even without air flow.
Dec 20, 2009 | Heating & Cooling
Electronic Air Cleaner problem
The presence of “white dust” is actually an indicator that your Electronic Air Cleaner is working properly. The Electronic Air Cleaner can only filter the particles that are passing through your system’s duct work. The staining particulate is generally lighter, and more able to be drawn through the return registers in your home, leaving the heavier, non-staining particulate behind. This heavier, non-staining particulate settles out of the air and is left behind on your furniture: because it is more visible, it may appear as though there is actually more dust in your home than there was prior to installing the air cleaner. To ensure that more particulate is able to reach the Electronic Air Cleaner to be filtered, you should make sure that the return registers are clean and not blocked by furniture.
Apr 29, 2009 | Honeywell (F50F1073) Air Purifier
I have a Honeywell electronic air cleaner hooked up with my heat pump... I have not used it for a long time because when I turn it on all it does it pop and snap.. I also forgot if the mesh metal filter...
replacement parts (cells, prefilters & postfilters)
All replacement parts for an air cleaner are available through a licensed heating and cooling contractor.
May 28, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
320 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
