Ratio is stuck at 145%
My copier is stuck at 145% ratio at all times and the only way I can get it back to 100% is to manually do it each time I turn the copier on. How can I set my copier to copy at 100% at all times?
  • karenkilmer Oct 06, 2008
    canon ImageCLASS MF3110 copier
  • Tim Babcock
    Tim Babcock May 11, 2010
    What is the make and model of the copier?
  • 183 Answers
You need to tell me for which bran and model is about.
It looks like you have made a program recall that makes all copies to be a 145% . You should go to user tolls settings but i cant help you if you dont give me the brand and model
Posted on Jul 15, 2009
What is the maximum speed ford expedition 8 cylinder 232 hp 2001
Maximum speed is determined by engine rpm, divided by transmission gear ratio, divided by final drive ratio, times tire circumference (tire diameter times 3.14) However, the electronic governor limits the 2001 expedition to around 100 mph.
Dec 18, 2017 | Ford Cars & Trucks
Why i get H4 error on 5516
Heat roller abnormally low
temperature
When the temperature does not
reach 155°C within 55 sec after
turning on the power, or when it
falls under 145°C during printing,
or when it falls under 100°C
during pre-heating
May 28, 2014 | Sharp AR-5316 Advanced Digital Imager...
Fuel mix ratio for poulan counter vibe 3400 chain saw and for a homelite st-145 weed trimmer
Oil Mix Ratio: (last 5-10 years)
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
If me I would have the Poulan tweaked to run properly on 50:1 and use that in both. It will start easier and take much longer to carbon foul.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Apr 30, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
My trans is stuck in 3rd gear, the car runs fine. i can get it out of gear but it is very hard to do
it needs a new clutch and preassure plate assuming it it a stick shift
Nov 09, 2009 | 1992 Isuzu Rodeo
My HP Pavilon Zed 145 wont start up. Keep turning
Try to run on AC power with battery removed. If still problem persists, then its time for repairs!!
Sep 06, 2009 | HP Computers & Internet
I need free manual for Royal ER 145. Recently
Here Goes Program 2 position - enter 102420 att/total key - program 1 position enter o in the departments as non tas enter yy mm dd (09 04 23) hit charge key
enter time hhmm (1500) military time hit xtime depress amout tend key turn off and on and maybe will work for your child...Good luck......have fun
Apr 23, 2009 | Royal Office Equipment & Supplies
My ratio is stuck on 145%. I can change it manually but it doesn't stay very long until it changes back to 145%. My copier is a CANON IMAGE CLASS MF3110. Please let me know how I can change it back at...
Press the Enlarge/Reduce button until it says <Direct 100%> ratio then press SET.
Let me know if that works.
BTW here's a link to the User Guide:
MF3110 User Guide
If this has been helpful, please rate this solution. Thank you!
Oct 23, 2008 | Office Equipment & Supplies
Canon mp 145
..its instruction how to reset a canon pixma 145
May 09, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Printer screen is not working
hi first of all check for good cable connection to sockets then try this: http://h10032.www1.hp.com/ctg/Manual/bpy21245.pdf http://h10032.www1.hp.com/ctg/Manual/bpy21259.pdf next time please make sure to be more specific have a good 1
Apr 17, 2006 | HP Photosmart 145 Inkjet Printer refurb
jasbo
jasbo
