Question about Sharp 25N-M100 25" TV
Cannel -3 When I connect my DVD player to My Sharp 25" TV , It pays normal for about 3-5 minuts and quits for a period of time. When I try again the same problem. Other channels are received with out problem. Problem is with channel-3 input. Did any body went through the same experience?
    Sergeant:
    Champion:
  • 334 Answers
Well is it older dvd player and are u playing newer dvds u will get a drop out buy new player samsung upconverting 1080 p player ok 79 bucks circut city
Posted on Oct 06, 2008
DVD is playing but no sound is coming out. Where do you put the video cords from the player to the TV. We have an older Sharp tv
What is the model of your DVD Player? and does your old Sharp TV have jack plugs in the back to accept audio leads.
Normally you would connect a Scart lead from the DVD player to the back of your Sharp TV.
If your Sharp TV is so old that it does not have a Scart Socket then you may have to use an RF lead running from the RF out Socket from your DVD player to your Sharp TV!
Jun 22, 2011 | Televison & Video
I am trying to connect a DVD player to a RCA F25216BC 25" TV - the TV only has an F type Coax connector and does not have a CH 3 or 4 switch - I put the input from the wall to the DVD player and out to the...
Your TV must be equipped with AV inputs (RCA jacks - yellow, white, red)
in order to connect this unit. If your TV does not have AV inputs, you will need a RF Modulator to connect the DVD recorder to your TV's
antenna/cable input. RF Modulators are available at
major electronics retailers such as Radio Shack or Wal-Mart and allow the 3 RCA outs from the recorder to connect to the RF modulator RCA inputs and then you can connect a coaxial cable from the modulator to the TV RF input and select channel 3 or 4 on the TV. The DVD recorder will not pass thru signals to the TV using coaxial cable as far as DVD are concerned.
Aug 22, 2010 | RCA F25216BC 25" TV
I need to know what channel to switch to in order to connect my dvd player. it`s an akai 25 inch tv, model cts 2550, serial # 39zta51280x. thanks for any help. louie
It is a general question just try my idea to connect to the DVD player channel.
In the remote you may find any of the below button, press it.
1. DTH 2. DVD 3. VIDEO
If not just call the customer care help line to assist through online..
(Before that remember one thing you have to connect the dvd player wire in the TV to activate the DVD channel)
Thank you.
May 08, 2010 | Akai CTS2550 25" TV
LC-26DA5U 26 in. HDTV-Ready LCD Television: i connect a hdmi cable 2 my hd cable box - the pic...
The cable box needs to be set to send different signals when using hd tv and standard tv. Usually a good setting would be 720p in hd and 480p in standard. The tv is working fine it is the cable box sending the signal. If you have another hdmi source such as a dvd player you may hook that up to show the tv is working just fine.
May 07, 2010 | Sharp LC-26DA5U 26 in. HD-Ready LCD...
I have a new samsung blu-ray player... but manual does not list remote code to make the new remote compatible with my Sylvania TV... any ideas??
try connect to the tv AV1/2 scart connector, with a full scart cable (top quatily),and use tv AV1/2 cannel to test
Jan 02, 2010 | Samsung BD-P1590 Blu-Ray Player
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Technically challenged...need DVD to show on TV screen
hey 1st of all you gotta make sure that your son made tha right connections with the av cable (this is the cable with three different coloured pins) from your DVD to your tv. if this doesnt solve your problem then make sure you are using the correct av channel on your tv set that will allow you 2 play your DVD player because sometimes you cant play your DVD on thhe same av cannel you watch normal tv
Jan 01, 2009 | Pioneer DVR-520H DVD Recorder
Sharp Model 27SC370
Same problem here. TV would turn off but would not turn on after a period of time (until waiting a minute or two) then able to start again. Intermittent problem too.
Jan 20, 2008 | Sharp 13VT-R100 13 in. TV/VCR Combo
Sharp 17" TV
It's the Closed Captioning function I think. I've had the problem with my Sharp TV (and other TV's that have Closed Captioning function). Look at the menu or the manual to see how to turn off Closed Captioning. It might be marked as "CC".
Oct 06, 2007 | Sharp 25N-M100 25" TV
Sharp 25N-M100 25" TV Logo
79 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
