Question about Panasonic WORKiO DP-C262 Printer
Error code u28
I have just changed the drum unit (black) as requested on the screen However, error code u28 keeps on flashing despite me addressing the initial problem. Any answers?
It ask me to change the black drum unit. I changed a new one. But the error message is still over there.
If you have any suggestion, send E-MAIL to zwu@groupekwa.com
Thanks.
Posted on Oct 14, 2008
I can"t get in my yahoo account despite my IP and my password
ip adress should be irrelevant , you need to put in your full email address and passwaord , if that doesnt work you can request a authorising code if you added a mobile number , you will get a call or sms of a code . use that to log in and change your password .also request a password to another email address associated with your account . failing all these options conctact yahoo
Mar 28, 2014 | Computers & Internet
Error 163 on oki c5500 printer
163 Toner Sensor Error, Color: Black An error has been detected in your printer's Toner Sensor.
1 Machine Check Exception A problem has been detected in the printer hardware
2 DSI Exception The printers main logic has attempted to look up an invalid address.
3 ISI Exception The printers main logic has attempted to read the next instruction, which has failed to execute for some reason.
4 Alignment Exception The printers main logic cannot access the memory for some reason.
5 Program Exception The printers main logic has issued an exception code.
6 Floating-point Unavailable Exception A floating-point instruction is executed when the MSR floating point enable bit is set to Disable.
7 Instruction Address Breakpoint Exception The printers main logic has attempted to look up an invalid address.
20 CU ROM Hash Check Error 1 CU ROM hash check error has been found. Check reproducibility if possible.
21 CU ROM Hash Check Error 2 The printers CPU has a checksum error in it's memory.
23 CU ROM Hash Check Error (resident) Seek service if restarting the printer does not correct the problem.
25 CU ROM Hash Check Error (DIMM2) Seek service if restarting the printer does not correct the problem.
30 CU Slot1 DIMM RAM Check Error An error has been detected in operation checks on the RAM in slot 1
31 CU Slot2 DIMM RAM Check Error An error has been detected in operation checks on the RAM in slot 2
35 Slot1 RAM Spec Error Check the specification and install in slot 1 RAMs supported by the product
40 CU EEPROM Error The EEPROM mounted on the CU board needs to be replaced
41 CU Flash Error The CU Flash needs to be replaced
43 Flash File System Version Mismatch Seek Service if restarting the printer and initialising the flash memory does not correct the problem
42 Flash File System Error Seek Service if restarting the printer and initialising the flash memory does not correct the problem
43 PS Flash File System Error An Flash Memory error has occured and the printer needs to be serviced if restarting the printer does not correct the problem
51 CU Fan Error The CU cooling fan needs to be replaced if restarting the printer does not correct the problem
70 Postscript Failure An error has been detected in your printer's Postscript Core.
72 Engine Communication Error A communications error has occurred between CU and PU boards.
73 H/W Overrun Detect An error has been detected in your printer's hardware input area.
74 F/W Overrun Detect Occurs when the firmware is unable to set video data in response to video DMA's data request.
75 VIC Limiter An error has been detected in your printer's
80 Parameter I/O Error An error has been detected in your printer's Input/Output area.
81 Parameter Consistency Check Error The EEPROM and flash memory reformatted and initialized.
102 Engine RAM Error An error has been detected in your printer's engine RAM.
103 Engine SRAM Error An error has been detected in your printer's engine SRAM.
104 Engine EEPROM Error An error has been detected in your printer's engine reading/writing the EEPROM at power-up.
105 Engine EEPROM Missing Error An error has been detected in your printer's Engine
106 Engine Control Error An error has been detected in your printer's Engine Controller.
122 Power Supply Fan Motor Error An error has been detected in your printer's Power Supply Fan Motor.
123 Humidity Sensor An error. has been detected in your printer's Humidity Sensor
124 Temperature Sensor An error has been detected in your printer's Temperature Sensor.
127 Fuser Unit Fan Error An error has been detected in your printer's Fuser Unit Fan Error.
131 LED Head Missing, Color: Yellow When yellow LED head connection cannot be detected
132 LED Head Missing, Color: Magenta When magenta LED head connection cannot be detected
133 LED Head Missing, Color: Cyan When cyan LED head connection cannot be detected.
134 LED Head Missing, Color: Black When black LED head connection cannot be detected.
140 Drum Up/Down, Color: Yellow An error has been detected in your printer's Yellow Drum
141 Drum Up/Down, Color: Magenta An error has been detected in your printer's Magenta Drum.
142 Drum Up/Down, Color: Cyan An error has been detected in your printer's Cyan Drum.
150 Drum Fuse cut NG, Color: Yellow An error has been detected in your printer's Drum Fuse.
152 Drum Fuse cut NG, Color: Cyan An error has been detected in your printer's Drum Fuse.
153 Drum Fuse cut NG, Color: Black An error has been detected in your printer's Drum Fuse.
155 Fuser Unit Fuse cut NG An error has been detected in your printer's Fuser Unit.
154 Belt Unit Fuse cut NG An error has been detected in your printer's Belt Unit.
160 Toner Sensor Error, Color: Yellow An error has been detected in your printer's Toner Sensor.
161 Toner Sensor Error, Color: Magenta An error has been detected in your printer's Toner Sensor.
162 Toner Sensor Error, Color: Cyan An error has been detected in your printer's Toner Sensor.
170 Upper Thermistor, State: Short An error has been detected in your printer's Upper Thermistor.
171 Upper Thermistor, State: Open Restart the printer. If the problem continues the printer will need to be serviced
172 Upper Heat Temp, State: High An error has been detected in your printer's Upper Heat Temp.
173 Upper Heat Temp, State: Low Turn the printer off to let it cool down, then restart the printer.
181 I/F Error, Loc. Duplex An error has been detected in your printer's Duplexer.
182 I/F Error, Loc. Tray2 An error has been detected in your printer's Tray2.
187 I/F Error, Loc. Control Pnale An error has been detected in your printer's Control Panel.
190 System Memory Overflow An error has been detected in your printer's System Memory Overflow.
191 Page Memory Overflow An error has been detected in your printer's Page Memory Overflow.
200 PU F/W download Check Sum Error Error during PU flash download
201 PU F/W Flash Write Error An error has been detected in your printer's PU F/W Flash Write Error.
202 PU F/W Flash Data Missing An error has been detected in your printer's PU F/W download Check Sum Error.
203 Engine Page Sequences IMAGACK Error An error has been detected in your printer's Engine Page Sequences IMAGACK Error.
204 EnginePageSequences IMGSET Error An error has been detected in your printer's Engine Page Sequences IMGSET Error.
2005 Oki Data Americas, Inc.
Sep 14, 2012 | OKI C5500n Printer
Flashing a dead nokia n97
Hi according to my experience your problem seems to the wrong selection of flash file.So, try to download it from here n97 or if this link doesn't works please use what you have download previously .There are many flash files with a higher version.Make sure that you should select the file of your correct phone type (RM-505 or 507).....Download the flash file what it is written on your phone.After you have done this please repeat the steps.Good luck
Jun 20, 2012 | Nokia Cell Phones
Xerox Phaser 7400 U28 error message
The Service manual says:
The Drum Phase Sensor for the named Imaging Unit indicates that the drum is out of position.
Initial Actions:
Reseat the indicated Imaging Unit.
Cycle the printer's power.
after these steps it gets a lot more detailed and you would need to be an experienced tech to understand everything and follow the steps within a timely manner, if reseating the cyan imaging unit doesn't fix the problem, then you will have to call for service.
Hope that helps
Christopher
May 20, 2012 | Xerox Phaser 7400/N Printer
I recently changed the Black drum unit for canon 32000 it has only worked for 3 days and again it has given me the error code 04b0 suggesting that i change the same again. What could be the problem this...
The error code is for a Black toner problem. The E000020 is for the drum/developersection, the 04 is for black, and the BO is for the drum unit approaching the end of its life. The quick way is to replace the black drum unit.
Hope this helps, thanks!
Nov 03, 2011 | Office Equipment & Supplies
Machine is asking for U28 replace black drums - I replaced black tone cartridge, the opc Drum Unit and the Toner Waste Container and the machine is still inoperative
on the back of the drum unit is a little "flag" that activates a sensor when you insert the drum to reset the drum counter. if the drum is replaced incorrectly or is from a poor supplier then the flag will be in the wrong position and when inserted will not reset the counter. try another black drum to reset the counter, do not discard the drum as the technician that visits in future can reset the flag for you.
Apr 17, 2010 | Panasonic DP-C263 Copier
Sony cyber-shot dsc-w50 problem
When “FLASH error” (Self-diagnosis Code E : 91 : ** ) occurs, to prevent any abnormal situation caused by high voltage, setting of the
flash is changed automatically to disabling charge and flash setting.
After fixing, this setting needs to be deactivated. Flash error code can be initialized by the operations on the Setup screen.
Method for Initializing the Flash Error Code
Initializes the setting to the default setting.
1 Select [OK] with v on the control button, then press z.
The message “Initialize all settings Ready?” appears.
2 Select [OK] with v, then press z.
The settings are reset to the default setting.
• Make sure that the power is not disconnected during resetting.
Jul 26, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Cyan Imaging Unit Failure, U28 Error Code
the only thing I can suggest is to check the contacts that the imaging unit goes into, and i can also be the imaging unit itself. If i am not mistaken, you should be able to swap imaging units from another color just to see if the error goes away. But if this does not help, you will need to get it serviced. we have fixed these before, and its not a quick fix.
Apr 21, 2009 | Xerox Phaser 7300DN Laser Printer
Canon IRC3100 colour copier machine error code
Canon iRC-3100 Color Copier is giving Error code E-000021-0001. can anybody help me?
Aug 01, 2008 | Office Equipment & Supplies
Whirlpool Duet HT WFW9200SQ/A
Plug off the wall. Close the wall faucet and check the hose & small screens on it. Open the faucet to see if the flow and pressure is good (keep bucket handy). Refit carefully, try machine. Code is nt seen anywhere as you said.
Jan 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Panasonic WORKiO DP-C262 Printer Logo
217 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
