Question about Sony Playstation 3 (PS3) Console
PS3 audio problem
I just purchased a PS3 mainly for the Blu-ray player. I hooked up my PS3 to my Sony Receiver using the optical out on the blu-ray. When I watch a movie in surround sound the audio drops out for a few seconds and then come back on only to repeat this so that it is impossible to watch the movie. Seems that the signal gets interrupted and then regained. I set the Blu-ray up to output bitstream as when i set it to PCM I only get stereo single to the receiver. The PS3 only has one choice for my receiver because my receiver does not have a HDMI input. BTW the sound only seems to go out when there is load action type sounds. Need some help making sure I have the right setting.
  • 1 more comment
  • Corey Jones Oct 06, 2008
    Firmware on PS3 has been updated with no change and I have replaced the optical cable to make sure it's not the cable.
    My receiver works fine with all other DVD players just when I use the PS3 blu-ray disc. there are about five options to select from when I choose the settings in the PS3. They include dolby digital 5.1, Dolby Digital DTS, Linear PCM 48, and other Linear PCM options that are higher speed rates which i do not select. It appears that the Blu-ray can send signal a higher rates if selected. when I select the DD 5.1 and the DD DTS and enter I gat a message similar to " all signals may not be recieved properly" which I do not understand but select OK and then get the poor results.
    I had no intensions to buy a new receiver when I purchased the Blu-ray. How can I get it to work and get the standard DD5.1?
    Sergeant:
    Champion:
  • 334 Answers
Is ther firmware update yet for sony player is that off brand optical cable what setting is sterio on
Posted on Oct 06, 2008
  • 3 more comments
  • nick helpap
    nick helpap Oct 06, 2008
    cheak sterio settings what reciver uusing /? u said pcm d/bitstream what else does it have dolby digtal out ? or any other weird settings or just 2 main ones should use bit stream then pro logic on sterio could be sterio doing it cant handle hi end 192 kil digtal your sterio may only be 96 klz max digital u know may need higher end harmon kardon reciver on new egg 399 on sale with 192 khz samsopling rate ps3 hard core so for now use pcm then use prologic to make sound 5,1 ok till u can get better reciver cant use cheap off brand ones
  • nick helpap
    yes your got it now sterios fult need nerwer ones for blue ray with true dolby hd to handle that hi end bandwith use 48 for now sound great to u can upgrade sterio 400 on new egg harmon kardon super awosme 7.1 3 hdmi ins 1 out
  • nick helpap
    sterio cant take dts ect if thats not avb on sterio in 1st place way to hi of streams speaicl blue ray bestto upgrade it one with 192 khz samspling rate it can take k are best kenwood harmon kardons my fav sound quilty ect
  • nick helpap
    use 48 on ps3 out cant use dts or anyting fancy on low end reciver or just use dobly digital reg mode only try those ok u def missing out tho with ps 3 hi end games and blu ray u def wann upgrade soon
  • nick helpap
How to connect Panasonic BD60 Blu-ray disc player to 2 components
If there are red and white RCA jacks on the back of the BR player and on the receiver you should be able to get sound. The same as your VHS.
Dec 29, 2009 | Panasonic DMP-BD60K Blu-ray/DVD Player
No Audio
cant use both hdmi and opti outs try sum setting in blue ray but u nee dto plug all blue ray dish directto samsung hdmi then 1 master digital out form tv to sterio digital i n ok tell samsung your output also
Jan 20, 2008 | Sony STR-DG510 Receiver
No sound from fiber optic 2 jack hooked to a blu ray
IN THE RECEIVER YOU HAVE TO CHANGE THE TYPE OF SOURCE YOU ARE USING (EXAMPLE DIGITAL OPT) AND SOMETIME YOU MIGHT HAVE TO CHANGE IT ALSO IN THE BLU RAY PLAYER TO DIGITAL OPT
Dec 06, 2009 | Audio Players & Recorders
My new BluRay player has HDMI output for both sound and video. My Receiver, however, does not have the HDMI inputs. Can I use HDMI direct to TV, and use Optical connection to receiver for audio? Sony...
Yes, you can connect the HDMI Cable from the Blu-ray Player to the TV directly and then, connect the Digital Optical cable from the Blu-ray Player to the Receiver.
Oct 09, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Blu ray connect to my sc-pt660
as far as hooking up your blu ray player to the sc-pt660, the only real way to utilize the surround sound (with true surround sound) is through the optical audio out. You need to connect your blu ray player through hdmi to your tv and then connect your blu ray player to your surround sound using the optical audio out/in. I, personally have the sc-pt660 hooked up through component cables so I don't waste an HDMI input on my TV. Except for cd's, there is no reason for you to use the actual dvd player part of the surround sound considering you have a blu ray player. In conclusion, hooking your blu ray player and the sc-pt660 up to get better video simply isnt possible (your blu ray player alone gives the best possible resolution, 1080p). As far as audio goes, run an optical audio cable from your blu ray player to your sc-pt660 to get true surround sound.
Mar 23, 2009 | Panasonic SC-PT660 Theater System
No sound
I had the same problem on 3/21/09...I found it was the PS3 settings. I had to go into the visual settings (not sound) and change the linear sound to optic digital...but I also had to purchase a digital optical cable...plug everything into your tv instead of the receiver and then hook up the digital optical cable from your tv to the receiver. A it will work and b it is a better sound quality than that of the HDMI cable.
Mar 14, 2009 | Yamaha HTR-6130 Receiver
Connecting a sony blu ray 350 to denon 1601/ home theatre
Yes select audio optical out on your Blu Ray Player under Audio settings and make sure the Denon is set to Optical or Auto in. You should be set to go
Sep 27, 2008 | Denon AVR-1601 Receiver
Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
Hooking up a PS3 to my surround sound
you have to go to the set up menu and let the receiver know that you are inputting dvd audio to the digital in. (assigning). that way, when you switch the receiver to dvd, it will look for audio from the digital input. your receiver manual will guide you through that set-up.
if that does not work, the fiber optic cable could be bad. this is more common than people would expect.
another option is to just rca cables to the receiver from the ps3. there is an adapter that lets you do that.
good luck
mark
Dec 28, 2007 | Televison & Video
No Audio
What port do you have the HDMI from you BD player into on the 510. If you have it on the DVD port then fiber optic will do you no good, the DVD HDMI only supports digital coax, the Video2 HDMI only accepts fiber optic, and there is an extra fiber optic for the Sat input. If your BD player does not have digital coax out, or if you dont want to buy another cable, just move the HDMI from DVD to Video2 on the 510. I am willing to bet you have the BD player plugged into the DVD HDMI port and the fiber optic cable from you BD player to the Video2 fiber input.
Dec 18, 2007 | Sony STR-DG510 Receiver
Sony Playstation 3 (PS3) Console Logo
142 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
