Mitsubishi ws-65713 green light wont stop flashing..reset wont fix. You said in another post that you could email repair instructions and service manual.
Thank you.
Mitsubishi WS-65713, 5 yrs old. Cannot turn on TV - Green light flashing, hit reset, also unplugged and plugged in... no luck, please help football is on today.
Thanks
KenMitsubishi WS-65713, 5 yrs old. Cannot turn on TV - Green light flashing, hit reset, also unplugged and plugged in... no luck, please help football is on today.
Thanks
Ken
AnonymousJan 25, 2009
Can someboady help me with my issue? I have the same issue with the green light blinking every time that I connect the power cable into the outlet. I even unplug the power cable from the outlet for 24hr and I get the same thing when I plung back in the TV power cable, my TV is a Mitsubishi WS-65713. Can somebody email me the pictures instructions to [email protected]? Please help!! Can someboady help me with my issue? I have the same issue with the green light blinking every time that I connect the power cable into the outlet. I even unplug the power cable from the outlet for 24hr and I get the same thing when I plung back in the TV power cable, my TV is a Mitsubishi WS-65713. Can somebody email me the pictures instructions to [email protected]? Please help!!
I have the same problem with the gren blinking light. maodel ws-65713 can someone assist with a solution I have the same problem with the gren blinking light. maodel ws-65713 can someone assist with a solution
I also have the same problem with model WS-65713. The green light is blinking and will not reset or go off with any action I take. Can someone advise me on this. I also have the same problem with model WS-65713. The green light is blinking and will not reset or go off with any action I take. Can someone advise me on this.
You can't post conmments that contain an email address.
I do not have the service manual but have instructions with pictures.
Will email them to you. If you have never soldered check look for
instructions on utube and with some practice you will be able to
de-solder and solder. A utube video that is great is at http://www.youtube.com/watch?v=I_NU2ruzyc4. Good luck.
Very common problem caused by failed DM capacitors. You can get the DM repair kit for your model from www.tvrepairworld.com the kit does come with instructions.
These Mits TV's tend to have power supply problems that are well documented on the web, when the symptom is as you describe. And this assumes no other unusual noises were heard before the TV went into shutdown.
The repairs are fairly straight forward if you are comfortable with electro-mechanical dis-assembly, soldering repair, and re-assembly.
Just do a search on Mitsubishi (your model number) and capacitors.
Unplug the unit for 5 minutes then plug it again. Turn it on. If it does not power up, press the SYSTEM RESET button on the front panel with a pointed object such as the point of a pencil or end tip of a paper clip. The green LED light will flash quickly for about a minute then stops. You may turn on the TV then. The changes you made most recently, before using SYSTEM RESET, may be lost. Changes you made previously, however, are not lost.
I just fixed the capacitors on my WS-65713. I can email you instructions with pictures if you wish. You will need to de-solder and solder on new capacitors but if you check out video instructions on utube you should be okay with some practice.
I had the same problem and just fixed it. You likely have 4 bad capacitors in your DM board. To fix you will have to take the DM board out of the TV, de-solder the ones on there and then solder on new capacitors. For those who would like instructions on this leave me your email and I will email them to you. I can't believe I was able to do this but thanks to Jaime for giving me the instructions and checking how to solder on Utube. No I had never soldered before guess it shows you can do it with some effort.
Please send me the instructions on how to remove and repair the dm board in my mitsubishi ws-65513 tv. The greenlight keeps blinking. thanks [email protected]
Thanks
Ken
