Question about GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1631WB003
My microwave runs but won't heat anything. What could be wrong and how much might it cost to get it repaired? Would I be better off just buying a new one?
  • 1 more comment
  • tcarp Oct 11, 2008
    Same microwave, same problem. However it will heat if run for a long duration (20 minutes).
  • Anonymous Apr 13, 2009
    My microwave makes a buzzing sound, won't heat and has a burning plastic sound. It has a manufacture date of 2000. Wonder if it would be cheaper to buy a new one or get this one fixed. Same model #.
  • Anonymous May 12, 2009
    I am having the same problem.
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Spacemaker XL 1400 Microwave
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Nov 28, 2007
  • 4 Answers
SOURCE: Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
Posted on Nov 29, 2007
  • 96 Answers
SOURCE: ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Posted on Jan 22, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Broken handle on GE Spacemaker XL1800 microwave
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 07, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Replacement light bulb for GE spacemaker microwave
That model number doesn't look quite right, but nevertheless:
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Sep 16, 2008
What causes a ge spacemaker above the range microwave to quit heating and makes a deeper pitched noise?
This louder, 60 cycle hum is usually caused by a bad magnetron. The unit will not heat when this happens. Repair cost can exceed $100.
Dec 29, 2017 | GE Spacemaker JVM1540 Microwave Oven
I have a GE Profile Spacemaker 2.0, MOD Number: JVM2070SK02 Last week the thing stopped heating anything. Sounds fine, but won't heat. Any tips?
okay thats sounds like you have to take your microwave to a repair man.the HV capacitor can be open or the magnetron is bad these 2 components i mention are responsible for the heating of your microwave if they go bad..then your microwave wont heat.good luck.
Sep 23, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE jvm1631wb003 not heating has a funny machine smell
Most likely the magnatron has gone out and it runs around 90 bucks. If something is funny smelling then by all means don't use it unless you want a fire. If it were me I would replace the oven instead of throwing money nto a repair on a used microvave, they simply don't last as long as they used to. It won't hurt to take the cover off and inspect it for burnt wires that may have grounded out, if none found I would replace the unit.
Jul 01, 2011 | GE Microwave Ovens
G.E. spacemaker microwave stopped heating,made louder than normal sound,smelled odd.
The magnetron has failed, "heats food" to repair the unit will approach the cost of a new microwave oven.
May 19, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Model number JVM1441who4 Everything on it works but it will not heat anything. Can you help me?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101
Mar 23, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a 1993 GE spacemaker microwave/range hood combo. Everything works except that for most of the day it did not heat the food. The turntable still worked and the oven still appeared to be running. Then...
In short yes it can happen again.
Intermittent operation can be caused by a door interlock micro switch, a weak capacitor, an intermittent wiring connection from heat or poor connection, a marginally performing diode or a sticking Magnetron. Except for the Magnetron all other repairs would be worth the expense.
Repair costs and parts for most everything else will be between $65 and $100.00 depending on the part(s) replaced. Replacing the Magnetron would cost more than 50 % of the total unit replacement cost.
Jan 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave XL1400- No heat
The problem could be anything from a defective control circuit board or a burned out magnetron tube. Either fix is quite expensive and you'll have to evaluate whether you think the repair is worth the cost vs buying a new microwave.
Bear in mind that a fixed microwave is still a used microwave. So to get an apples-to-apples comparison you have to ask yourself, would I pay $XXX (substitute XXX's with actual repair cost) for my used microwave?
Oct 10, 2009 | Microwave Ovens
Everything works except heat
this is something you should probably call a repair technician for, due to the danger of the componentry.
Usually in ther case of this problem, even a technician will advise you to replace the unit, in the minds of cost effectiveness and safety...
Mar 21, 2009 | GE JE1540 Microwave Oven
2 1/4 year old GE Spacemaker XL 1850 Microwave doesn't heat
Check this website:
http://www.partselect.com/microwave+no-heat+repair.htm
It sounds like it is either the power diode, the high voltage capacitor or the magnetron. If it is the magnetron, it may not be worth fixing as these can cost well over $100.
Do you hear a buzzing sound?
Dec 13, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
251 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
