Question about Sharp AR-153E Copier
L-1 error code.
Flashing L-1 error code, but movng the scan head locking switch from unlock-lock and back doesn't help.
Thanks
  • drbandd Oct 06, 2008
    Thank You!!
  • Sharp Master
  • 2,794 Answers
Turn the copier off and remove the scanner glass. Sometimes the ribbon cable underneath the scanner gets bound up on the scanner. Flatten it out and secure it with scotch tape. make sure that the loop has enough slack on it for the scanner to travel freely.
Posted on Oct 06, 2008
Its helps thanks
Posted on May 05, 2009
Error code (L1-00) on sharp AR-168D
When[L1-00] appears,the scan head locking switch is locked.Turn off the power,release the scan head locking switch,and turn the power back on.
Nov 03, 2011 | Sharp AR-168D Black and White Copier
F dl error flashing. washer is just clicking
door lock error
happens whenf the door cannot be unlocked. will try to lock the door about 6 times before code error shows..
1)door lock Assembly is broken or not attached to Door
2) inspect the door lock/switch mechanism
3)check the wireing harness connectorsfrom door lock/switch assembly and the ccu or central control unit
4) the door lock assembly has failed, u must replace the part or call for service.. hope this helps
Jan 28, 2010 | Kenmore Elite 45986 Front Load Washer
Error code du
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked.
It will try to unlock the door 6 times before displaying the error.
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
If it is a cabrio:
dU flashes if the following conditions occur:
Excessive force on door lid is preventing lock bolt from retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an unlocked state.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
TEST #8 Door Lid Lock
Perform the following checks if washer fails to lock (or unlock).
1. Perform Manual: Door Switch and Manual: Door Lid Lock tests.
2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies.
3. Visually check that the P12 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1.
4. Check the lid lock motor winding and switches by removing P12 from the machine/ motor control and checking the
resistance values....
Component/Resistance Unlocked/Resistance Locked/Contacts Measured/Contacts Measured:
Motor Winding/35 ±5 O/35 ±5 O/P12-2/P12-3/
Lock Switch - Home/0 O/Open Circuit/P12-1/P12-4
Lock Switch - Lock/Open Circuit/0 O/P12-1/P12-7
Lock Switch - Lid/Lid Closed = 0 OLid Open = Open Circuit/Lid Closed = 0 O Lid Open = Open Circuit/P12-1/P12-5
If resistance values are good, go to step 5. If switch measurements do not match the values shown in the table for unlocked (or locked) conditions, a problem
exists in the door lid lock. Replace the door lid lock.
5. If the Manual: Door Switch or Manual: Door Lid Lock in step 1 failed, then the machine/motor control has failed: Unplug washer or disconnect power.
Replace machine/motor control assembly. Perform the Manual: Door Switch and Manual: Door Lid Lock in step 1 to verify repair.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!
Jul 16, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
DU is flashing and when I press the Pause/Cancel button this does not clear the problem
Door Unlock Error
If it is a cabrio:
Jun 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
I have 2 model al-1540cs copiers that are producing blank copies. The scanner doesn't seem to be moving and is in the unlocked position. I am getting no error messages, the paper is facing in the right...
When [L1-00] appears, the scan head
locking switch is locked. Turn off the
power, release the scan head locking
switch, WAIT 10 SECONDS and turn the power back on.
Dec 04, 2008 | Sharp AL-1540CS All-In-One Laser Printer
Flashing "L1" error
A letter "L"  and a number "1"  appear alternately = The scan head locking switch is locked. Unlock the scan head locking switch.
Hope this helps. Good luck.
Jul 29, 2008 | Sharp AL-1217 Copier
Where is the scan head locking switch
hi dear
Release the scan head locking switch.
The scan head locking switch is under the document glass.
If the switch is locked ( ), the machine will not operate. Unlock the switch
oke
cropp
Mar 19, 2008 | Sharp SHP AL1655CS Printer, Scanner,...
Getting an error L flashing then 1
Background:
The L1 is indicating a scanner lock.
Easy way to fix it:
1. Turn machine off.
2. Turn scan locking switch to unlock. This is a clear plastic knob. (it is located on the left hand side of the machine under the document glass in the copy exit area - check your manual for a picture of it around page 9 or so).
3. Turn machine back on.
4. Try a copy.
5. If you still get an L1 then it might need service because the scanning bar is jammed. They will ask you to try some service codes first to verify that it is indeed jammed. Call 1800 237-4277 for further support.
Followup:
This also is a fix if you are getting blank copies.
Mar 18, 2008 | Sharp AL-1641CS Laser Digital Copier
Sharp AR-153E Copier Logo
222 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
