Question about OKI Office Equipment & Supplies
PC CANNOT FIND PRINTER PORT - OKI Office Equipment & Supplies
    Genius:
  • 1,124 Answers
Go to Start >> Control Panel >> Printers
Select your printer, right click and go to >> Properties then go to >> Ports
Check which port is using your printer and correct (LPT1 or USB Virtual Port)
Posted on Oct 06, 2008
  • Coin1 Nov 24, 2010
    this was really simple, i had no idea, have been grappling with this issue for 2 months now. your solution was very helpful. thank you.
CLP-325 "The current printer port is not supported for the printer status"
Dear
Try to replace the usb cable. Also from pc program do the maintenance program run.
If still problem found check the printer with other pc or the pc usb port for other device if it works then replace the main PBA of the printer.
Thanks.
Apr 28, 2012 | Samsung CLP325 Laser Printer
Where is the printer port? have two audio then two usb then blue 15 pin port, power port on left hand side - a jack point at the rear and DVD and CD door
You are using Acer Aspire One Notebook. Notebooks generally doesn't have serial port (Printer port) as used by old printers. However Acer Aspire one notebook have USB port on which you can connect your USB printer. Serial ports are old and not support by new computers or notebooks.
Jul 05, 2011 | Acer Aspire One PC Notebook
Where do you hookup the printer to the one zx series
Where you hookup your printer to your PC will depend in part on what interface your printer uses to communicate with your PC.
Some of the possibilities are the parallel port, the USB port or a lan port.
Most printers these days use the USB port.
There appears to be four USB ports on the back of your machine.
HTH
Jun 16, 2011 | Gateway One ZX190 PC Desktop
How can I share my HP officejet 5610 all in one printer that is connected to my desktop that has windows XP with my windows vista laptop?
1. Unplug your USB cable from the back of the Windows XP PC and plug the USB cable directly into your Windows Vista PC.
2. The Windows Vista drivers for your printer should be automatically loaded and your printer will be installed on your Windows Vista PC. If this was successful, skip right to step 3.
If step 2 is not successful
i. Download the Windows Vista printer driver for your printer from
the manufacturers website.
1. If your printers manufacturer has not created a Vista driver
yet, retry step 2.
ii. Install the driver on your Windows Vista PC. During
installation, youll be prompted to connect the printer to your PC.
Choose the option to proceed with installation without connecting the printer.
3. After installation is complete, open the Printers icon in the Windows Vista Control Panel.
4. Right-click on your printer that was just installed and choose Properties.
5. Navigate to the Ports tab.
6. Click Add Port, then select Local Port, then click New Port.
7. For the Port Name, enter the exact network path and share name of your printer. (ex. - \\HOMEPC\Printer2) 8. Click OK and make sure that this new port is selected with a check in the checkbox.
9. Click Apply and then OK to close the printer properties.
10. You should now be able to print from your Windows Vista PC to a shared printer located on your Windows XP PC.
Jun 17, 2010 | HP Officejet 5610 All-In-One InkJet...
Don't know where i plug in my printer
I think you are new with the PC or Printers, if not, I am sorry to underestimate you, not actually, Well, I was just trying make you concentrate, This printer is to be connected to the PC via USB port using USB cable, here's the pic representation : usb-printer.gif The Flat terminal is to be connected to the PC and the Smaller terminal is to be connected to the Printer. Don't worry, It fits with the corresponding ports. printer-usb-port.jpg USB port on the printer looks similar with the above shown image. 67411-usb.jpg You have to connect in a similar way as shown above to the PC.. Good luck...
May 10, 2010 | E-Machines eMachines Desktop PC
Cant load driver in port lpt1
AN IEEE 1284 port is a parallel port protocol. Lpt1 is a physical port on the PC that attaches to the printer.
Basically, the PC is telling you that it expects the printer to be connected to the LPT1 port on the printer and that it is expecting the printer to be conversant with the IEEE1284 protocols.
Given what you have described, you should not be having a problem connecting the PC to the printer.
Please let me know what the exact failure is and the make and model of the printer that is causing the communication between the PC and printer to go "Toes Up."
Don
Dec 11, 2009 | HP OfficeJet T45xi All-In-One InkJet...
USB to Parallel connection (Panasonic KX-P1121)
I would recommend buying a Printer parallel port connection (PCI to LTP1), install it into the system, and use the printer parallel cable.
Sep 02, 2009 | Nikon COOLPRINT Thermal Printer
Trying to connect from USB laptop to parallel printer
You can't have a double hook up to it,When the parallel port is used the usb port is disabled and when you use the usb port the parallel port is disable.This is done to prevent damage to the printer.You can network the laptop with the pc and print that way though
Jun 04, 2009 | Brother MFC 7420 All-In-One Laser Printer
Laptop running vista and pc running XP can't get laptop to print on printer connected to PC laptop is wireless
share the printer first on the main pc (desktop)
get the sharename and full computer name of the main pc, its case sensitive.......
then, install the vista driver on the laptop. (note: you need vista drivers installed locally on the laptop because the main pc has a different operating system)
after installing the driver, go to the printers folder, right click the printer icon, go to properties, go to the ports tab, hit add port.
a new window will open giving you the option of local port.
select local port then click new port! on the space type in the information you got earlier... \\fullcomputername\sharename then click add
ex: \\rblb55\Printer1
this will add a port on the selections, make sure the one thats checked is the port that you just added. click apply or ok to close those windows.
then print............
Sep 06, 2008 | Office Equipment & Supplies
Zebra LP 2844 parallel communication problem
The printer is installed on the PC using a specific port. If it's installed on the USB port, it won't work on the parallel port. Do you have this printer installed 3 different times? Need more details such as how was it installed the first time? And if it's working on the other 2 ports, why does it have to work on the parallel?
Apr 15, 2008 | Zebra LP 2844 Thermal Printer
1,583 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
