Question about Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR DX Nikkor Lens
Vibration Reduction not working
I have the lens about 4 months and was not too impressed with it until I seen VR working on a friends camera. Now I realise mine was not working from the start. It is on a Nikon D80 and the unit is turned on.
  • debrahdallas Oct 29, 2008
    Camera still takes fuzzy photos even when vr is on.
  • Brian Williams May 11, 2010
    Lens settings - M/A, VR On, Normal (not Active) -- when you press the shutter release halfway and it focuses, you should hear a tick from the lens as VR engages and you may even hear the little gyros spinning. Do you hear this? At 200mm it's pretty obvious when VR engages because all the little jumpies stop.
  • 289 Answers
This feature is not an "end-all" to using a tripod for those razor sharp images. The VR may buy you one or two stops of light max. This may be enough in a pinch but invest in a tripod (a good one) for razor sharpness!
Posted on Apr 24, 2009
I bought a AF-S 55-200 VR about four months ago. Lately, the VR doesn't seem to work right. It jumps around and often produces worse results than not having it on at all. I have the kit lens that came...
If the lens is only four months old then it's still under Nikon's warranty, so there is absolutely no point in trying to repair this yourself. Faults like these are most likely to occur in the first few months of use.
Just send it to the nearest authorised Nikon service centre or if you live in the UK you can demand a refund or exchange from the retailer. Given the choice, I'd strongly recommend the second option.
Jul 19, 2011 | Nikon Nikkor 55-200mm f/4.5-5.6 G AF-S...
Nikon Nikkor 55-200mm f/4-5.6G ED IF AF-S DX VR Vs. Nikon Nikkor 55-200mm f/4-5.6G ED IF AF-S DX are they the same len or not? thanks, Ricky at rpotter@eatel.net
No. The VR lens has 15 elements in 11 groups, the other has 13 elements in 9 groups. This indicates that the two lenses have different optical designs. The main difference, however, is that the VR indicates "vibration reduction." This lens has motion sensors and tiny motors that move the lens elements to compensate for camera motion, producing clearer pictures when hand-holding the camera.
Oct 23, 2010 | Nikon Cameras
Image is too dark nikkon swm vr ed
Having received no response in over a month, I assume this is no longer a problem.
Aug 06, 2010 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED...
Lens error restart camera
your cam is out off order
if want it back needs to replace optical block
assembly that is the only way.
good luck..
Feb 26, 2010 | Canon PowerShot A590 IS Digital Camera
Stopped working will not focus just makes a noise
I have seen the focus gears fail on these. They come as a unit. It will need to be replaced, not a DIY
Sep 26, 2009 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED...
Nikon lens 55-200 nikon dx vr
So does mine, that is the VR releasing, it is normal.
Jun 24, 2009 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED...
Manual Focus won't work
Which camera are you using? If the body has AF/MF switch, put that also to MF.If this fails to help, take out the lens and try to change it to MF.
Feb 05, 2009 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED...
D50 with a new 18 -200 Nikon lens
Is the Auto/Manual Focus switch turned to Manual? This can easily be moved without realising that you have done so.
If not, get it checked out under Warranty. If you try to do anything yourself you will void the Warranty.
Good luck.
Oct 03, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Help
if the lens doesn't come out u r going to have to send it in to repairs.
Aug 08, 2006 | Casio QV-R51 Digital Camera
Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR DX Nikkor Lens Logo
232 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
