Still waiting for a solution from Abrsvcs
Sound ok just a line at centre of screen on left side.If switched to dvd function a blue line across centre of screen.
  • 4,234 Answers
I'm sorry. Based upon the lack of response on the original posting, I was not aware you were waiting. The only update there was a TFT rating. I will look up the specific parts tonight and update the original posting with the details and instructions.
Dan
Posted on Oct 06, 2008
Blue Lines streaking in from left side of 70 inch Sony HD TV
okay my friend your tv vertical circuit is begining to get faulty you could be having some bad caps or the vertical ic is defected have a tech check your tv for repairs.if you are not a tech you cannot repair the set by your self.good luck.
Jun 25, 2007 | Sony Grand WEGA KDF-70XBR950 70" Rear...
When switched on the screen has a blue background and a series of multi-colured vertical lines in the centre covering approx half the screen. can get o further than this.still has seven months of warranty...
sounds to me like a broken lcd screen. Check if it works on external monitor, if it does the problem is your screen. If it is the same on an external monitor then the fault is with the onboard graphics card. This should be fixed under warranty
Feb 18, 2011 | Acer Aspire One PC Notebook
The lower left hand corner of the screen is turning blue
catually is problum is related with blue lcd & blue polizer but first you clean the optical unit if the problum gon then ok other wise must chang blue lcd & blue polorize with uv filter plese contect to your nearst sony service centre
Feb 05, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
SAmsung has two white lines across screen with no picture
If the 2 white lines are in the centre of the screen it sounds like you have a fault called 'field collapse' . The 'x' or horizontal circuit on the tv deflects the beam across the screen which in your case is ok because the line runs across the screen ok. The 'y' or field circuit on the tv deflects the beam down the screen. Without a circuit diagram for your tv i cannot point to individual components.
Aug 07, 2009 | Samsung Televison & Video
My toshiba 2577db has a blue line across
easy the vertical chip is dead /and or two
caps right next to it , total cost of part 8.00
so dont let them charge you to much if
you take it in to a shop
Jun 28, 2009 | Televison & Video
WT-46809 Inputs show lines across screen
1. THE SYMPTOM IS BRIGHTER IMAGE ON THE SIDES AND DARKER IN THE MIDDLE. THE PROBLEM CAN BE WITH RED BLUE AND/OR GREEN. CHECK FOR PROPER CONNECTIONS TO THE "DAG COATING AND CONNECTIONS TO PIN 9 ON THE SOCKET OF THE AFFECTED CRT. MAKE SURE THESE GROUND POINTS ARE COMMON WITH CHASSIS GROUND.
Apr 25, 2008 | Mitsubishi WT-46809 46" Rear Projection...
26PFL5520D/50 DVT PROBLEM
If the lines across the screen are made up of coloured blocks, then the problem is likely to be a weak signal.
Digital channels are broadcast in groups called multiplexes. Sometimes one multiplex may have a weaker signal than others, and so you experience problems with up to 6 channels when all others are ok.
If it is only one or a few channels then just wait and see what happens, because it may be transmitter works.
If you have problems with all channels it could be a connection or antenna problem.
If the lines are just straight lines, then try resetting the TV as follows:
Switch on the TV
Press and hold the menu button on the side of the set. The settings menu will appear. Hold until the menu disappears again.
When you release the button, the TV will take up to about 90 seconds and then reset.
The TV will then show the original screen when the TV was new.
Press ok when shown.
Set language and country settings.
Move down the list and press ok to re-install all channels.
Feb 22, 2008 | Philips 26PF5521D 26 in. HD-Ready LCD...
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
