I have a laptop comp i just got a desk top comp i have embarq broadband internet which comp do i pit the cd into to install and which comp do i hook up the embarq box to?
  • 1,124 Answers
You need a router to set both computer with the same internet connection.
Posted on Oct 06, 2008
  • 84 Answers
It sounds as though you will need to get router to allow the sharing of the Internet between the two computers. Using a router makes it much easier to share an Internet connection between multiple computers. You would connect the Embarq box to the router on the WAN port, and then connect your computers to the LAN ports of the router. You may also want to get a wireless router in the event your laptop has a Wi-Fi connection.
Cant open folders
repair your windows with the installation dvd or cd, or reinstall the windows
Mar 11, 2012 | Acer Aspire 5570-4820 Notebook
Dell Truemobile 2300 - cannot connect to internet
This is usually a router configuration issue. The router has to be configured to match your new broadband settings.
For example, your old DSL may have required some kind of login which was entered into the router. For most broadband cable connections, you set the router to get an IP address automatically.
Re-run the router Setup Wizard. You can download it here:
Jan 26, 2009 | Dell TrueMobile 2300 Router (000001)
Linksys wireless-g broadband router
1. On your computer, open IE and type
2. By default there is no username and the password is admin.
3. Once you're in, set Internet connection type to what your ISP requires to have. If you have cable ISP usually it is just set to Automatic configuration-DHCP. If you have DSL ISP, it usually uses PPPoE.
4. But verify it with your ISP.
5. Whatever changes you do on that page, do not forget to click "Save Settings" which can be found at the bottom of the page.
Nov 06, 2008 | Linksys Wireless-G Broadband Router
I read your post and wanted to know if you are able to access the internet if you connect the modem directly to one of your computers. I would like to make sure that we do not have a problem with the network. What errors are you seeing and what lights do you see on the modem and router? Please send your phone number via email or private message and I will review the network for you. Thank you for giving us the opportunity to help you.
Lamont L.
Embarq Customer Outreach
For additional support please visit or call 1-877-646-3282
Voice | Data | Internet | Wireless | Entertainment
Sep 10, 2008 | Belkin Computers & Internet
I'm a little confused how to install this router I just bought. Model #wrt54g2. do I put the cd into my desk top which is already connected to the internet or do I install the cd in the new laptop I just...
Hi sheena -Is your desk top hooked up throgh the router? If not, plug your modem into the wan port on the router. The router should have come with a couple of short cables, most likely blue and yellow. Use the blue to connect your modem to your router. You can check the manual just to be sure. Use the ethernet cable that had been connecting your desk top to your modem, and plug into one of the wired ports on the router. I imagine you'll be using wireless for your laptop. Make sure that it is on. Put the cd in your desk top and run from there. Follow the directions. If you need more help just add a comment and I'll be glad to assist you further. If this solves your probleb PLEASE rate this as fixed. Remember. Need help? Just holler Sheena.
May 04, 2008 | Computers & Internet
Can't get a connection back on my ISP (embarq).
If you have dial-up, go to tools>internet options>click "always dial my default connection" or if you have broadband click on "Never dial a connection" These settings are found in Microsoft Internet Explorer 5 or higher.
Apr 11, 2008 | Dell Microsoft Windows XP Home Edition
Asuming you are knowledgable about hooking up broadband i will guess that you know for a fact the its a good connection on the broadband routers side and there is actuall internet access and the problem is with your laptop.
If so then make sure you have the right installs.
get into your start menu at the bottom left> hover over settings>click on network connections and wait for the window to open. Right click on " LOCAL AREA CONNECTION" and select properties.
The little box should open showing a scrollable menu and say " Local area connection Properties" at the top. Make sure in the list of installed Items, you have at least the TCP/IP internet protocal installed and add version 6.
Also you can try cycling the power to your internet broadband router. Hook up the laptop, turn it on and log in, If you have a router that you are using to branch off your broadband to several computers, then unplug, wait 30 seconds and polug back in and it should register. If you are plugging directly into the Broadband router, cycle the power on it the same way.
Also make sure you are plugged into the right port on the router:)
Hope this helps.
Feb 15, 2008 | Computers & Internet
Belkin wireless G router will not allow connection to internet
check for the physical cables, check if they are connected properly, if yes, try to reset the router and reconfig it
Jan 05, 2008 | Computers & Internet
Computers & Internet Logo
93 people viewed this question
David Payne
David Payne
