Question about AEG Refrigerators
AEG Santo 1683-TK7 Led's and interior light flashes when door is opened
As rwsummers correctly points out replace this part as from uk i bought it from maplins £3.31 part no N74CN 1UF 275V de-solder the two points on rear of pcb and re-solder new part in place and reassemble turn on power and "voila" works like new. Thanks.
Posted on Apr 10, 2010
I guess this is a problem with many Santo models that use a similar circuit board. Change the 1 uf 250v capacitor as in the article http://www.elisanet.fi/mtj/santo/AEG-Santo-fix.html
A 400v working would be a better bet if you can source one. I had to use another 250v one as I have not been able to source a 440v in the Uk. I guess someone somewhere has one in stock. RS stock a 440v but you have to buy 25 at around £18 inc. postage. I only want one!!!
Posted on Oct 07, 2008
Door for freezer compartment for AEG refrigerator Santo 1450-7TK
Fixya does not sell freezer compartment doors. Check with a local appliance parts supplier.
Nov 07, 2016 | AEG Refrigerators
I have an AEG Santo 72348 ka fridge that is supposed to be self defrosting. Mine regularly freezes up inside. Any help ?
Usually this is a symptom of a faulty door seal or a very frequently opened fridge they extra moisture load from the environmental air.
Feb 18, 2013 | AEG Refrigerators
Finding a refrigerater seal for an old aeg santo 1605
HI DAN.wow still going hain.well u'll be lucky to find one.i think yours is a screw on seal.try matching it to a universal fridge door seal.and cut to size.no other way.:) good luck.ali
Jul 04, 2012 | AEG Refrigerators
AEG Fault code E202 On opening the door of my microwave combi oven the interior light flashes accompanied by what sounds like a relay chattering and the display flashing between the normal display and...
I would suspect a bad door switch or door switch mount, or possibly a bad electrolytic capacitor on the control circuit board.
See:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
Beyond that, I could only speculate, since I don't have experience or information on AEG products.
Jan 09, 2010 | Electrolux Microwave Ovens
Aeg santo 1688 fridge power/light flashes when door open
Check if the bulb is loose in its socket, you may be able to twist it to tighten it, turn off the power first though.
Oct 13, 2008 | AEG Refrigerators
AEG Santo Fridge 3774-6KA
Check the damper between the fridge and freezer. It may be broken or frozen open. If this happens and you have a water reservoir in the fridge then it could freeze and crack - leak and then flood your house... Shut off the water supply until you get the problem fixed.
Jan 20, 2008 | AEG Santo 7085 KG Side by Side...
AEG Santo 3778-8 KA Temperature Problem
hi tracy, think its possibly better getting a repair guy in as this fault is not streight forward. possibly a fault in the defrost circuit, or freezer fan not functioning, or possibly a leak in the system. all theese areas need testing equiptment.
Sep 19, 2007 | AEG Santo 7085 KG Side by Side...
What does the flashing (warning?) light mean
Did you ever get any advice for this problem? Please repost if not.
Oct 22, 2006 | AEG Santo 3888 KG8 Bottom Freezer...
Refrigerators Logo
560 people viewed this question
Top AEG Refrigerators Experts
Oscar Netto
Oscar Netto
ashburton
Jim Goldsmith
Jim Goldsmith
Are you an AEG Refrigerator Expert? Answer questions, earn points and help others
