I have got 2 cables coming from my sat dish - Televison & Video
  • jedrush2 Oct 07, 2008
    thank you much appreciated thanks
  • 659 Answers
Well if you have two horns sticking out on the dish it means that those are your different angles 91 and 82 degrees I think thats right anyways those two cables should go into a box that splits the signal into one and then one cable from that would go from the box to your receiver.
if you are wanting you can also just hook up the 91 its the most used but you probably will be missing a few channels until it is set up properly.
if you only have one horn and two cables coming out of it it just means that you have the setup to run two receivers off that dish.
if you need more info please describe your setup a bit more for me.
Thanks hope this helped
Posted on Oct 07, 2008
I have a RCA tv in our rv connected to Dish Network. What are the channels and input for the rca tv? The model is L32HD41
Try ch 3 and sat or cable input on tv. use menu on original tv remote to set input as sat or cable.. then use dish remote for all other changes.
May 15, 2017 | RCA Televison & Video
Updating pansat2700a sat receiver
The problem is not clear, if the Pansat is stuck after updating, or you get no channels , then repeat the updating again.
Check all cables and antenna dish.
Sep 05, 2008 | Audio Players & Recorders
How do I set the T.V.? I have Dish Network. A message comes up stating "No Signal".
You need to have the input on the TV set to what ever the "Dish" cable uses. If the dish box uses HDMI then find which HDMI port it is plugged into on the TV and set the input to that.
Mar 03, 2015 | Televison & Video
I disconnected power from the tv to install carpet & im not sure if iam hooking it back up correctly
danny_burse
I am assuming when you say you disconnected power from the TV to install carpet, you disconnected the cables from the receiver to your TV. Depending upon your installation, you have a cable that comes from the dish located outside that is connected to a splitter and has 2 cables coming off the splitter. The 2 cables will connect to SAT 1 and SAT 2 on the back of the receiver. Your TV 2 connection either goes directly to your TV 2 or goes to a second separator, connected to the UHF/VHF connector. If you still have problems with the connections, please email me at ray.calo@dishnetwork.com and I will assist you further.
Ray Calo
DISH Network
Apr 21, 2011 | DISH Network 322 DTV Receiver
Blu Ray player and dish network sat box both connected to Sony HT-7100DH with HDMI cables. HT-7100DH is then connected to Sony HD TV with HDMI Cable. Blu Ray sound only works if the coax cable is...
Hey my nameis Mike Houston of DISH Network and I see there is a problem with the Sony hometheater system connecting with the DISH receiver. To get the full surroundsound you want there are two different options you can use, the first is to usethe HDMI and connect the RCA cable or you can use the Optical cable for sound.If you have any questions or concerns please e-mail me back; michael.houston@dishnetwork.com.
Jan 03, 2011 | Sony HT-7100DH System
Dish dvr reception keeps cutting out
Hi mikej10x! I will be more than glad to assist you in this concern. You mean, intermittent signal? If that is the concern mikej10x, lets isolate the problem, 1st check the sat in 1 and sat in2 if the cable is connected tight, as well as the separator, diplexers, all device that is connected to the line of sat in, then press the power button on the front panel of the receiver for 10secs, receiver will turn off and then turn on by itself, then attention 015 will pop up on the screen, then press the menu button right away once you see the attention 015, then main menu will show on the screen and once main menu is up, press 6,1,1 on the remote control and it will go to the point dish screen, select check switch on the upper right and it will go to installation summary screen, select test on the bottom of the screen and it will run a test up to 2 of 2 or depends on the sat you have, once its done it will show the installation summary, sat input 1 & 2, port1-119-ok, port2-110-ok, once you see that all sat is ok, select done and it will go to point dish, select done again and then cancel all the way out and it will pop up attention 015, let the progress finish until it download the programming guide. the picture will show. observe if problem still exist. if the problem still exist, call 1-800-333-3474 ask for tech support and once you talk to a live agent, ask for a service call, there is a problem on you sat dish system, it could be the lnbf, switch, or the separator or cable connection. or it needs to re aligned the dish.. but before you call, check first if there is no trees or leave blocking on the dish to the southern sky, no obstruction.. please feel free to get in touch if you have any query.
Sep 07, 2009 | DISH Network DVR-625 DTV Receiver /...
The TV loses the signal from the dish reciever. I've checked all connections. I have to turn the TV off and then back on to fix it.
since you have a dish reciever you could try connecting the dish box to the television with the AV cables.. (yellow, white and red cables) to the television. once that is done press the source button on the remote until it displays composite then you will have the picture from the sat box. Try it like this to see if it still loosing the signal..
Also you could try is turn off the sat box then back on and see if that fixes that problem if it does could be something wrong with the sat box.. also test a dvd player to see how that reacts.. if that plays good and you connect the sat box on that same connection then the sat box could be having some issues.
Jun 21, 2009 | Olevia 237T 37 in. LCD TV
HDTV Converter hookup with sat. and antenna
Hi there Phil...... this switch from analog to digital has lots of folks scratching their heads. Fortunately I have some great news for you. The signal coming from the Dish network does not need a converter as it is already digital.
May 29, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Have moved my Sky to another room. Cut existing sat cables and extended to new location. Can watch all stations OK. Can record OK. When recording I can't watch any other station. Any ideas what I've...
Originally used pre made "F" connector to "F" connector cables from B and Q.
Have changed above cables to the thicker black ones - same size as comes of sat dish.
This solved the problem - suspect attenuation problem by using inferior cables.
Jul 02, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
