Question about Hotpoint Aquarius WMA52 Front Load Washer
Washing machine WMA54 Hotpoint sticks on prewash
Hi - my product is a WMA54 but there was no option on the list.  My washing machine is 4 years old but I've never had a problem with it.  I recently moved home and now when I try to do a wash it goes through the cycle to rinse and spin then jumps back and 'locks' on prewash - the red light flashes.  If I press 'start' it does the same again. I can get it to spin on a spin only cycle.  Can anyone help please?  It is out of its warranty so is there a solution or is it time to say goodbye to it?
I realised that the washer was not filling properly with water!  So I pulled it out from the wall and noticed the cold water fill pipe had been squashed and had a kink in it so not enough water was getting through.  I remedied this by pulling the pipes through the under sink cupboard and securing them with gaffer tape,  Hey presto the machine now works again!  Hooray :D
Posted on Oct 08, 2008
  • Champion engineering Jul 02, 2014
    as the person above recomends check all your water connections and secondly clean your inlet filters they are normally situated on you inlet gates just behind the screw in pipe connections
Drum is not turning
Could be the brushes, only way to prove it is to remove the motor and check the brushes for wear.
If they are less than 3 or 4 mm long, then they need replacing. If brushes are o/k, then it is probably a control board fault.
Jun 03, 2010 | Hotpoint WMA54 Front Load Washer
How to change the belt on a hotpoint wma54 washing machine
there is a rear access panel in the center of the back,remove this cover and put the new belt on the motor pulley,then over the larger drum pulley,it takes some strength unless you release the motor tensioner and retighten after the belt is on
Mar 23, 2010 | Hotpoint WMA54 Front Load Washer
Where is the filter on the hotpoint wma54 washing machine?
Remove lower rear cover of washer, locate and remove large black hose fastened to drum, inside you will find the filter.
Please rate my solution.
Thanks.
Sep 22, 2009 | Hotpoint WMA54 Front Load Washer
Door lock
Switch off. Try some WD40 on the machine lock (not on door) and open & close door many times, to ease out the lock.
Jan 28, 2009 | Hotpoint WMA54 Front Load Washer
Where is the filter on wma54 hotpoint washing machine
It is in the pipe which runs from drum to pump at the drum end.
Dec 15, 2008 | Hotpoint WMA54 Front Load Washer
Hotpoint Aquarius WMA54 very noisy during spin
Hi, if your H/P is noisy on the spin cycle, just open the door and turn the drum a few times. If you feel some play, or kind of loud huming noise, then it is the bearings, very, very common on H/P WMA's.
Nov 13, 2008 | Hotpoint WMA54 Front Load Washer
Wma54
will help type this into a search engine it the user manual !http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WMA50_WMA52_WMM53_WMA54_WMA56_WMA58_WMM59_small.pdf
Feb 15, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint wma54 washing machine
sorry but not the job i would recommend to anyone not done or watched it done before its about the most difficult job to do on any machine, even though in my 20 years experience this is the easiest machine to do a drum bearing change on, most of the machine has to be stripped down, removing all the front panel / timer panel / door seal and drum front / drifting out the old bearings fitting the new ones and rebuilding the machine, not counting testing for and rectifying any damage the drum has done to the rest of the machine and surrounding parts, good luck if you attempt it, sorry
Sep 24, 2007 | Hotpoint WMA54 Front Load Washer
Machine sticks on prewash
pls change the poer supply board
Jun 01, 2006 | Hotpoint WMA35 Front Load Washer
Hotpoint Aquarius WMA52 Front Load Washer Logo
223 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
