Question about HP LaserJet 5si Printer
Old printers... Hello! We have a several old HP Laserjet 5si printers, (6 that are in production, and I believe another 2 or 3 that are just too bad to use). They all have problems with them... the common one we see is paper jams. If they were a little faster and wouldn't jam up, then we would be pretty happy with these printers. I do know one of these has a page count of like a half a million... not sure about the others but I would assume the same amount of high count. But my question is... is it worth us to try to fix them? I've attempted myself and can't seem to get them working right. I thought maybe it would make sense to hire someone to come in one day and take a look at all of them and try to fix them. What things could they do? how much money are we looking at? Or is it just time to replace them with newer models?
  • mreeves89 Oct 06, 2008
    mspcrepair, thanks a lot for your help! I've always read about changing out rollers, but I've never done it before. Is it really simple enough that I should be able to figure it out, or do the rollers come with instructions or...?
    Thanks for the help!!
    oh... and one more thing. I've heard about "maintenance kits" but they are like $200 each. Is it worth getting maintenance kits?
    Novelist:
  • 169 Answers
Yes, absolutely! The paper jams you're experiencing are most likely not printer errors, but roller problems. The HP roller has a cat-tongue texture to it, which helps it grab one sheet at a time...as the printers age (and print) these surfaces get worn down, causing paper jams.
Printer rollers are a relatively inexpensive item to replace ...just a few bucks for a handful of them. Do a Google search for HP Laserjet (insert model) printer rollers and shop around. I've worked with hundreds of HPLJ's over the years, and almost 90% of the time, the jams are caused by the rollers.
The best part is ...they only take about 15 second to replace. Each HPLJ (depending on model) will have at least 2-4 rollers, so bear that in mind when shopping.
Hope this helps :)
Scott
Posted on Oct 06, 2008
  • Scott Merrill
    Scott Merrill Oct 06, 2008
    Yes, very simple. Remove the paper tray and reach your hand under the assembly (where the top of the paper tray would normally be) ...there should be one roller on each side (these are the pickup rollers). When you find them, just grab and pull inward (towards the center of the printer) ...depending on their age, you may need to give them a tug...don't worry, you won't break anything.
    After removal, you'll see that it's just a spindle that they sit on, so just replace the roller by sliding it back on until you feel a click or it goes in as far as it can. If you didn't do it right, the roller will fall off into the paper tray, so that's a good way to tell :)
    As stated, it's a much cheaper fix than having the units serviced or replaced ...and those HP LJ's will last forever with routine maintenance!
    Scott
  • Scott Merrill
    Maintenance kits are another story ...sometimes you can continue to print, even though the display says you need one ...some models, you have to replace it right away to continue (usually the fancier models).
    Once you get to needing a maintenance kit, I'd look at getting another printer (as they are about $200-$250 each), and you can pick up an office laserjet brand-new for not much more than that.
    Scott
    Genius:
  • 1,124 Answers
You can try to clean the printers with some air cleaner , this usually helps to fix the problem. But due the age of your printers you will save money getting a new ones instead of try to fix them.
HP 5Si printer, multiple images on one sheet HP 5Si, Windows XP, Networked Jetdirect card, 20MB memory, duplex option. Unit worked fine before. Power outage occurred, seemed to have knocked out the...
If this is a "ghost" image like whats on the top of the page is re-appearing on the middle and/or bottom. The fuser is defective and needs to be replaced. Part # RG5-4447
Jan 03, 2011 | HP LaserJet 5si Printer
I have lost a CD driver HP laserJet 1020 how can I fix it in my computer
Go to lexmark, click drvers-downloads , type laserjet 1020 into the box, choose your OS and download your files, or click HERE
Sep 30, 2010 | HP LaserJet 1020 Printer
LaserJet 5Si printing slow use to be able to hit the print key then the printer would fire away. seems like the printer pauses between pages then prints maybe 3 to 4 pages per minute
Could be software. I have seen the last several Adobe latest version documents take several seconds to print. I have also seen increased print times with MS office 2003 Powerpoint documents.If it is a single page MS Word or Excel document and u are printing several copies of it, you should turn off the collate feature for printing of that document
Dec 05, 2009 | HP LaserJet 5si Printer
57 service error message. Wht does that mean? We
A fan failure was detected.Printer fan or Duplex fan.
1. Check the fan’s connector and make sure the fan is not blocked.
2. Replace the fan.
On older style printers this is often caused by a bad main motor. (Older style printer being printers with halogen heating elements in the fuser - 4, 4+, 5, 4si, 5si, etc).
Oct 19, 2009 | HP LaserJet 4 plus Printer
HP LaserJet 5si MX 56.1 ERROR PRESS SELECT KEY
Illegal input or bad accessory connector. 1. Turn the printer off, and then turn the printer on. 2. Check the printer’s configuration. 3. Verify accessory connection. You've got a printer that's over ten years old. That's prehistoric in dog years. Don't complain about quality it's time for a replacement printer. Meanwhile check the accessory connections. Something might be loose or corroded.
May 31, 2009 | HP LaserJet 5si mopier Printer
Hp 5si second pass roller instructions
To change the 2nd pass roller, you need to remove the PIU(paper input unit).
Get a tech that has done it before. All covers have to be removed. Paper trays removed. It's not something that can be explained in an email.
Sep 25, 2008 | HP LaserJet 5si Printer
HP Laserjet 1022
Try to clear dust from cylinders..
I had similar problem and I cleared dust from cylinders with ear sticks and destilled water.
good luck :))
Aug 12, 2008 | HP LaserJet 1022 Printer
Hp laser jet 5si
Can you be more specific in the problem?
Also, please specify "how" you are connecting to the printer (parallel, LAN, etc)
Nov 30, 2007 | HP LaserJet 5si Printer
HP LaserJet 5si Printer Logo
108 people viewed this question
Seeker5211
Seeker5211
