Question about Sharp AR-235 Copier
Ar 235 There is ink spots on the edge of the copy. What can I do to fix it?
  • Sharp Master
  • 2,794 Answers
Clean the scanner glass. If you see any toner spills inside of the copier, you might want to clean those.
If you look at the green drum and see toner on it after copying, it could be the cleaning blade under neath the drum isn't working properly.
If you know where the charge wires are, you can clean those off as well.
Posted on Oct 06, 2008
Our office has a Sharp AR-235 Digital Imager copy machine and a L1-00 error message has been popping up for the past few months. Just wondering what the problem is and how we can fix it? We had a...
L1-00 is the detection of the scanner in the home position.
Your scan rails may be dirty needing cleaned, maybe add some lubricant.
The scan home sensor may be intermittent, just not seeing the scanner head in the proper position.
You can try blowing it out with canned air, I am sure he cleaned that.
It is possible you have an intermittent connection between the scanner and processor board or a bad processor board.
If it is an off and on issue I would suspect the home sensor . Most of the time that problem is one where you go in and the issue is very obvious. Every now and then you have one that is difficult to nail down and can be a headache.
If you remove the glass and you dont find the scan assembly is hitting anything or is difficult to slide in certain spots, have him replace the scan home sensor and reseat all the connectors to the MCU board. The MCU is the Main Control Unit. Just a term used to describe the machine processing unit.
Feb 23, 2011 | Sharp AR-235 Copier
Sharp AR-235 shows error H4-00, would like to know how to fix without costing me.
Noy likely you can fix this without replacing the fuser lamp H4 means the fuser lamp is not getting to temp. It cold be a fuse on the fuser unit,too. Checking with an ohm meter is only way to know which,
Feb 07, 2011 | Sharp AR-235 Copier
ERROR F5-02 call for service code AR 235 MODEL
F5-02 = Copy Lamp Lighting Abnormality.
Possibilities are blown copy lamp, failure of lamp harness (cable) or the MCU board.
You may need to replace either the copy lamp unit or the MCU board.
To check the operation of the lamp..
Enter service mode 5-03
#, [interrup],C,[interrupt],5,[copy button],03,[start button].
The lamp should light up for a few seconds.
Hope this helps.
Jan 15, 2011 | Sharp AR-235 Copier
Sep 2010 ... What does error code L6-10 mean on a Sharp AR-235 ... my machine sharp a 235 say call for service u9-99 what dos it mean and how can i
Sep 04, 2010 | Sharp AR-235 Copier
Drivers for Sharp ar 235 printer for windows 7
sharp ar-235 cannot work with win7.apply win xp and install.
Jun 29, 2010 | Sharp AR-235 Copier
I need to obtain a meter reading for sharp ar-m236. How do I do that?
Simply press and hold the copy mode then you get the meter reading and toner percentage status
Apr 15, 2009 | Sharp AR-235 Copier
Sharp ar-235 doble image in the copy
1.Might be a fuser problem. Check the upper fuser roller not to have toner on it.
2.The quenching lamp, if any, might be burn out.
Oct 19, 2008 | Office Equipment & Supplies
Sharp AR-235 Copier Logo
57 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
