Question about Microsoft Windows XP Professional
Usb not detected
None of the usb devices are being detected
  • Microsoft Master
  • 2,794 Answers
Go to the control panel. Press the system button. Select device manager. Look at the Univeral Serial Bus controller at the bottom of the page and make sure there are no red "x" in there. If there are, you may need to add a usb driver from your computer. If that doesn't work, replace the USB card in your computer if your are working on a desktop workstation.
Posted on Oct 06, 2008
    Sergeant:
    Champion:
  • 334 Answers
U will need driver for *********** bord model ? what pc uusing
Unable to boot internal devices? bug?
Did you go into the bios settings and check the status of the hard drive? it would seem that is where the problem lies.
Jul 06, 2012 | ASUS Computers & Internet
Can not detech and write
there could be a problem with the usb check if you are able to use any other humb drive or flash drive on the sysem if none is getting detected then just go to device manager and uninstall all the usb drivers and then resart the system it will get installed automatically nothing to worry then you can again try and see if it gets detected in the system tray and als after it gets detected install the dvd software to use it to write/read
Oct 26, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
I have a 2GB Kingston USB, and never detected when i insert to the USB port, my problem is, how can I reformat the USB? I hope you can help me to solve this problem. thanks and more power.
Have you tried the other USB ports? If none works, try also a different USB device to the computer. It may be that the USB drive you have is the one defective. If another device isnt detected as well, try updating your chipset driver, and also reset your BIOS to default. If none would work, possible motherboard replacement will resolve the issue.
Sep 18, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Pen drive is not detecting
1. Connect your pen drive to some other USB ports present at the rear side of your desktop pc.
2. In case of laptop, try connecting to some other available usb ports and check
3. In still not detected, then test your pen drive in some other systems.
4. If still not working, then it implies that your pen drive got detects.
5. If your pen drive is original kingston then you can claim the warranty from the place where you got it.
I hope this information is helpful for you
Thanks
Mar 14, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
The usb do not work at all. ibm t42 23731WU many thanks !
If none of the usb ports are recognizing anything you hook up to them then that means the motherboard is bad. Easiest way to know, hook up a usb mouse or usb keyboard, those it should detect and install.
If it can't do that then you know for sure the motherboard is bad. If it does detect the keyboard and mouse then you know its the other devices that your hooking up that are faulty.
Aug 21, 2009 | IBM ThinkPad T42 Notebook
Kingston DT1000 pendrive was not detected in computer
hi there.
this is what i have just found on the internet it might help you out but not sure.
After plugging in the device. Go to device manager (In run type "devmgmt.msc") In Device manager go to "Universal serial bus controllers" It should list the storage devices that you have connected to your PC. Right click and then click "Uninstall. Remove the USB drive and restart your system.
Try connecting the device again, I think this should solve the problem.
for windows xp
first you need to go to Device Manager by double-clicking on the System icon in Control Panel, choosing the Hardware tab, and clicking Device Manager.
go to divice manager
usb hub controler it will be at last of the list then
right click on usb hub controler open it go to usb root hub right click & go to properties
then go to device and click ok
do it 4 to 5 time it will work 100%
i have tried it and it worked
Best of luck :)
hi do one thing go to my computer right device manager ther u to o universal serial bus right click on tht option go to update driver select yes this time only give automatic k . before doing this step plz insert mother board driver cd after tht u do all this procedure thn c ur pendriv vl be dedected k
if none of the above works try this link out.
Kingston DT 1000 pendrive was not detected in computer Google Search
Nov 20, 2017 | Transcend (589307) Media
USB connection does not work on SHARP AM 400
U need to make sure the USB cable is working. I've encounter a situation due to cable problem, when printing large file size copier hang...
Other than that, some OS require to install usb driver in order to detect the copier and install necessary driver...
Apr 06, 2009 | Office Equipment & Supplies
Wireless card suddenly cannot detect any signals
I would suspect ya adapter.. the ONLY way to sort it is to try it in another PC see if it works.. USB devices seem to be very flimsy and we get heaps of 'em in the shop.. 9 times outa 10 it's the USB device gone weird.. substitution is the only way to isolate the problem.
Jul 14, 2008 | Computers & Internet
USB Ports
I would go back to device manager and uninstall all drivers in the USB category. Reboot and Windows will re-detect all the USB ports, this should work. If it was an electronic problem then some ports would work and other wouldn't but not all since there is multiple USB controllers in most computers these days.
Jun 16, 2008 | Toshiba Satellite M35X-S114 Notebook
All sansas
Update your USB drivers?
You could try putting the Sansa's in MSC mode.
Depending on your Firmware there will be a USB option under settings (Under USB it might be on Auto just select MSC)
OR you will need to
1)have the player on (but not plugged in)
2)push the HOLD switch tot he right (towards the REC button [see orange in the hold slot]
3)HOLD DOWN the |<< rewind button (keep this held down)
4)plug the cable into the Sansa (assuming the other end is in the USB port)
Wait till you hear it detect it..
If it still does not..
CHECK the Device Manager to SEE if their are any unknown devices under USB unplug the Sansa
Delete the unknown and try steps 1 thru 4 again.
If you do not know how to get to Device Manager then you will need the help of someone who knows these types of things to show you or look this up on the internet.
Dec 09, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Microsoft Windows XP Professional Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
