Question about Husqvarna 23 Hp 48" Deck Yard Tractor
My husqvarna GTH2448T has to be choked to run
23hp husqvarna for the past 2 months or so I have had to choke my tractor about half choke to run with no miss and to have power. Now all of sudden it runs for maybe a half hour and quits running. If I choke it almost all the way it runs a few minets then stops again. On line it says that the carb is not ajustable and I see no adjustment on it. What am I not seeing. I clean the fuel lines and the filter is clean.
  • 163 Answers
Check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes.
Posted on Nov 30, 2008
Runs fine then all of a sudden it acts as if its being throttled down
fuel line issue to much choke fuel mixture carborerta needs maintenance
Aug 13, 2015 | Husqvarna Garden
Husqvarna YTH2448 wont stay running
clean or replace the carburetor. sometimes they are cheap enough that it is worth replacing over trying to clean it. if it starts and runs for a few seconds then it is a carb issue. if it takes time before it dies then it is something else
Sep 26, 2013 | Husqvarna YTH23V48 23HP Lawn Tractor 960...
My husqvarna lawn mower makes clinking or rattling noise when I let off clutch
It sounds like there is a piece missing from the drive belt. The drive belt would be the upper belt on the drive pulley at the bottom of the engine. Another thing it could be is a bad bearing in an idler pulley.
Sep 23, 2012 | Husqvarna YTH2348 960430035 23HP 48 Yard...
I need a drive belt dagram for a husqvarna yth2348 hydrostatic
Looking at the IPL(exploded parts list) will give you a good look at the route of the belt. Here is a link to use and find your model
Apr 20, 2012 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Spitting and sputtering
mine did the same, I found out that the high speed jet was clogged, I pulled the fuel line off the filtor(going to the carb), stuck the line into a mixture of half gas half carb cleaner, I fanned it up and in 2 or 3 minutes it started running well, hope this helps.
May 20, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
545 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
