Question about Sony Playstation 3 (PS3) Console
It recently was dropped by accident ad a few of the silver metal pieces inside broke put. It won't turn on and we get the red light. We need it fixed for a good price.
It will more than likely cost more to fix than to replace. is it still under warranty? take back just dont tell them that it was dropped, tell them it just working one day. later go, redwings go obama,
Posted on Oct 07, 2008
2001 buick century won't start due to security
here you go have you replaced a key recently,if not then you need to start from begining put key in car allow to start and die leave key in on postion for 10 then try again if it wont start then you will need to get new ignition cylinder and then have it coded to your key must be done by lock smith.
May 22, 2012 | 1998-2002 Park Avenue Door Lock & Alarm...
I have a Craftsman Lawn mower model # 917-376950 ; and do not have an owners manual. The mower will start but it will only stay running if I continually push the priming button. Please tell me what the...
there is a large silver screw directly below the air filter. unscrew it and look inside the cavity. there will be a spring visible. fish it out gently with a paper clip or similar. there will be a red plastic piece attached to the spring. this is the main jet. clean the little hole in the center with a shot of carb cleaner or compressed air. put the assembly back in [red piece first], then carefully put the screw back in [this is metal going into plastic]. it should fire up and run fine. if not, you will need to replace the float bowl assembly
Aug 31, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Broken bit
drill it out , how big is the bit?
Mar 07, 2009 | 1981 Ford Bronco
My Epson Perfection 4990 indicator light is flashing red shortly after the scanner is turned on. The manual says that the light tube needs replacing. How do I do this or is it a professional repair?
I had the same problem and first checked the instructions in the Epson manual on the red flashing problem, read the following pdfs: Indicator light or problems
I saw the fluorescent lamp come on for a second before the indicator light started to flash red, so I knew that the lamp was ok and did not need to be replaced. Try this turn off the scanner and try unplugging the transparency lid from the back of the scanner, turn on the scanner and see if the light goes back to green. My issue turned out the be the mechanism inside the transparency lid, I kind of heard an awkward noise when I turned on the scanner, but thought it was coming from the base, I rlocked and unlocked the transportaion lock on both the base and lid, to see if that would fix it but it turned out it was coming from the lid, where there is also moving parts inside using a belt and wheels. On the end wheel closest to the front, the 2 little plastic pegs that hold down the square metal plate with wheel broke off, I could hear them inside when I lightly shook the lid, anyways I opened up the lid by removing the 5 screws and you need a screwdriver to put in each of the little openings around the edge to pry open the lid. I removed the belt and metal plate, watch out there is a spring attached to it, don;t forget how this part works when you put it back on, I found both of the little broken pegs and glued them back on with a strong plastic epoxy glue that I bought at Ace Hardware, I let that dry for 24 hours and then put the metal plate and wheel on then put the belt around the wheel, and now everything works fine.
Mar 06, 2009 | Epson Perfection 4990 Flatbed Scanner
Plastic casing around the bobbin
That piece is a sweep that helps keep the hook clean. It is not necessary for the machine to use, I have thrown away many of them. If you can get your hook put back in you should be ready to go.
good luck!
Jan 30, 2009 | Necchi 3101 Mechanical Sewing Machine
My needle broke and a piece of metal fell out of machine
Totally happened to me last week. I discovered that the metal piece that fell off and holds the needle has a small screw that holds it in place. It needs an Allen wrench (tiny one) to tighten it back into place. I just lucked into figuring it out.
Sep 11, 2007 | Brother XR-65t Mechanical Sewing Machine
Phone does not work properly
There is some pieces on the board inside your phone you broke off when you dropped it. It will need to be fixed by a technician. Hopefully you didnt brake the flex cable. Have them check the cable before doing anything else.
Aug 19, 2007 | Motorola Mobility MOTORIZR Z3 Cellular...
Opening up the scanner.
is there a power line to scanner
Sep 01, 2006 | Symbol Cobra LS1902 Handheld
Sony Playstation 3 (PS3) Console Logo
56 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
