Question about HP Pavilion dv6000z Notebook
Hp/sceen/hard drive/motherboard my laptop have power but the screen is blank but hard drive is running and have to switch on and off for 6/10 times before it runs smooth
    Sergeant:
    Champion:
  • 334 Answers
Video onbord is going bad and screen and or connection to it on hp will need whole new mobther bord from ober heating using it on bed cant **** heat from botttem out back so it overheats kills parts
Posted on Oct 06, 2008
I have a hp 89810-001 laptop motherboard.
ok check to see if hard is good first with another computer first than try a new video card if drive is bad make sure that all power cables are right at the same time check to make sure that you have the right ram as well ok let me know ok jim
May 15, 2014 | Gateway HP 489810-001 G50 AMD CPU...
My hp laptop dv6305us screen is blank power light is on but screen is totally blank.
The DV6000 series of notebooks are known to have problematic motherboards. Try the below options:
1) Hold the power button down for 5 second and the machine should shutdown. Then power on again.
or
2) Flip the laptop over and switch the "lock" switch to "unlock". Then flip the release button to remove the battery for a few seconds. Put the battery back in and try to power the laptop on.
or
3) Power on the notebook like normal. Watch the Hard Drive activity light (the one that looks like 3 stacked plates), if the screen is blank and the activity light is solid or flashing, you know that the LCD screen is bad and needs to be replaced. If that light is not flashing then the problem is your motherboard and it needs to be replaced. Call HP and ask them if your model was part of a DV6000 series recall, if so your repair costs might be covered.
Regards,
Jacob
Mar 05, 2011 | HP Pavilion dv6305us Notebook
Computer has power, hear the fan and HD trying to run however nothing happens, blank screen. Plugged in external monitor and still black screen
HP laptops have several problems with GPU overheating. Could also be a bad stick of RAM or a bad hard drive. You will need to remove each one and try to power on after each is removed. If still wont light up the screen you probably have a motherboard problem with the video chip (AKA: GPU processor)
Jan 17, 2011 | HP Pavilion dv7-1240us Notebook
HP zv5430us laptop has no video. Blank
The laptop has a built-in video card and the video RAM uses part of the main RAM.
First, re-seat the RAM modules and if the laptop still does not boot up normally then remove the RAM and get it tested at your friendly computer repair shop.
If the RAM is OK then connect an external monitor to the laptop, power up the monitor first and then the laptop. The video data should divert to the external monitor automatically, if you do not get any video image on the monitor then the video card in the laptop is faulty and a motherboard replacement is required.
A replacement motherboard may not be a cost effective solution and If it was me, I would put my money on a new laptop. I would then remove the hard disk and insert it into an USB adapter case and use it as an external USB hard drive.
Mar 22, 2010 | HP Pavilion zv5430us (PR466UAA) PC...
Had trouble booting the computer over time. Sometimes power light would come on and nothing else. By unplugging, waiting 15sec it would power up. Over time this stopped working. Eventually power light...
Time to look for a new computer. That and take out your hard drive to copy your files over.
Sounds like motherboard problem. Probably not worth repair.
I've got an HP desktop with similar problems. It turned on one day just fine. The next day not. I don't even get the boot up screens. Disconnecting Hard Drive and CD/DVD components do not help. I should at least get some BIOS POST beeps and a Hard Drive Not Found or such. I do not. On occassion it will boot to a blank screen with white cursor in upper left. Most the time no screen at all. On rare occassion it comes right on and boots Windows. I guess it could be the power switch ... but I doubt that.
Nov 22, 2009 | E-Machines eMachines Desktop PC
Computer on, screen blank and wireless unresponsive
YUP... sound like a motherboard problem. Could be a short somewhere. Try taking the Battery out and also the hard drive and put them back again. I have fixed such problems before by doing just that. GOOD LUCK !!
Jul 06, 2009 | HP Pavilion dv9000z Notebook
Blank screen
Look very closely at the screen when its on, see if you can see a faint image in which case the ccfl tube in the screen will be dead. Also try the laptop on an external monitor.
Otherwise if you know what your doing, remove the battery, hard drive, optical drive, all but one stick of ram, modem/wireless card and try again. There is a small chance it will be the cpu or motherboard.
Jun 16, 2009 | Averatec 3200 Notebook
HP Pavilion laptop will not start up - screen is blank
HI,
Most likely is Motherboard, but sometimes re-seatting the CPU can solve the problem. also check the computer, has,nt been put into sleep/hibernation or standby mode.
First i,d remove the memory, and if it,s got 2 sticks of RAM, try with 1. Could be faulty Memory. Next would be to remove CPU, and re-seat with new thermal compound. failing this, you can assume motherboard fault.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 14, 2009 | HP Pavilion dv1000 Notebook
Hp ze2000 shuts down
Without more information I cannot be sure, but I would say that it could possibly be set to use an external monitor. There is a FN key command to switch between your LCD Screen and an external screen. Try that. If you have an external monitor that you can plug into the VGA connection, that should tell you for sure. Good luck.
Nov 12, 2008 | HP Pavilion ze2000 Notebook
Acer Aspire 5010.. Power on, but Blank screen/ hard drive light also not.
This could be a Power/Switch Problem.
Faulty Hard-Drive.
Solution:- Leave the laptop turned Of And charge the battery to Full Capacity. ( usually between 4-16 Hours ) depending on capacity.
This will also fully charge the CMOS ( memory battery )
then boot the laptop up, and see if this solves your problem.
If not i,d suggest running a scandisk or hard-drive diagnostic program, to ensure that you have no Viruses-bad sectors on the hard-drive.
If you need further assistance please don,t hesitate to ask for more help and advice.
Mike @ Compurepair.
Feb 24, 2008 | Acer Aspire 5100-5022 Notebook
HP Pavilion dv6000z Notebook Logo
55 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
