Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Blur viewfinder my viewfinder is blur. i've adjust the diopter and nothing happen. what's the problem actually?
  • zalee Oct 14, 2008
    i've send the camera to the technician. it's the diopter problem and already fixed.
  • 34 Answers
are the photos also blurred when they come out? if adjusting the diopter doesnt fix the issue, you might need to have your camera and lens calibrated. why the lens? its because the issue may be isolated to the lens calibration otherwise the technician will only calibrate the body.
Posted on Oct 13, 2008
EVF blurred
Try adjusting the diopter. There's a knob near the upper-right corner of the viewfinder. Turn the knob while looking at the viewfinder.
See the "Diopter adjustment" section on page 39 of the manual.
Jul 17, 2012 | Panasonic Lumix DMC-FZ8 Digital Camera
I have just purchased a Nikon D60 and the viewfinder eyepiece always appear blurry prior to taking a photograph. Yet, when I take the picture it is clear and sharp so the picture is in focus, but prior to...
There's a diopter adjustment control near the right edge of the viewfinder. Look through the viewfinder at a blank wall and adjust this until the focus marks appear sharp.
Jul 20, 2011 | Nikon D60 Digital Camera
I have a Canon EOS 500D and am using a standard 15-85mm lens. The image in my viewfinder appears blurred as do the digital settings you can see when looking through the viewfinder. The camera still...
There's a diopter control just to the right of the viewfinder. Adjust it while looking through the viewfinder until the display is sharp.
Apr 29, 2011 | Canon Cameras
I have a Cannon EOS Rebel xsi SLR camera. When I look through the viewfinder the image is blurred. IT worked fine the last time I used it, but this time it is blurred and I haven;t been able to correct...
Two possible situations. It might be that the lens focusing system isn't working. Try focusing by hand (turn the lens manually) If the image moves through a point of sharp focus, then you have a lens or focus motor problem.
More likely, you have improperly adjusted the diopter. There is a small, circular wheel on the right side of the viewfinder, toward the top corner. It is sometimes covered by the rubber viewfinder hood so you might not notice it. This adjusts the diopter correction in the viewfinder and if it's set wrong, nothing will ever look in focus. The pictures would be fine, but since the diopter is a correction for your eyesight, the viewfinder will be out of focus.
Feb 05, 2011 | Canon Cameras
How can i change the exposure time on my pentax istD digital slr to get motion blur etc.?
OK that was a lame answer up there! If you want to add motion blur to your photographs there are several ways. There are two main motion blurs that can be achieved. One is the background blur to give your subject a fast motion feel while being able to identify your subject, like a race car. The other is subject blur to give a motion effect to your subject. NOW THE FUN PART - Doing it. The first one is the panning technique, set your camera for the proper exposure for your subject, frame your subject, as it passes by shoot and pivot at your waist while following the subject in the viewfinder, avoid up and down movement, with practice you will figure the right exposure and movement to achieve this blur effect. The second is the subject blur, this is simply adjusting your shutter speed and exposure to allow your subject to pass by with the shutter open long enough for it to leave a blurred image.
Oct 04, 2009 | Pentax *ist DS Digital Camera
Model Power Shot S1IS - my view finder is blurred but the photos taken are clear. Did I touch the wrong button??
Next to the eyepiece is a diopter adjustment. This allows you to focus the viewfinder just for your eye. The camera lens is not affected. I can adjust the diopter and shoot without my glasses haveing to be on.
Sep 29, 2009 | Canon Power-shot S1 IS Lens Converter
Canon SX10 IS Viewfinder is Blurry
Adjust the diopter knob. This is located on the left side of the viewfinder. Its a small black knob / wheel. Turn wheel until viewfinder is clear!
May 17, 2009 | Canon PowerShot SX10 IS Digital Camera
Canon EOS 500n 35 mm film camera green display info blurred
Are you able to adjust the camera viewfinder diopter setting. it should be a small wheel or lever near the viewfinder.
Dec 11, 2008 | Canon EOS 500n 35mm Film Camera
Picture on viewfinder is blurred Everything in my viewfinder is blurred, even the numbers and stuff in there. The picture I take isn't blurred.
I think your camera has a diopter adjustment. If it does, it'll be located on the right side of the eyepiece. It's a small wheel with a + and -. Adjust that until the image is clear.
-or-
It's possible that it is in need of cleaning. If you plan to remove the focusing screen, be exceptionally careful not to scratch it. Has it been subjected to extreme moisture conditions?
Aug 31, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Blurred image
The viewfinder image should look sharp & clear, as long as the camera is turned ON. If the camera is OFF, the viewfinder image will blur. At least this is how it works on my C2000z. If your viewfinder is always blurry, I would return the camera for exchange.
Sep 07, 2005 | Olympus Camedia C-3030 Zoom Digital Camera
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
115 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
