Question about GE Profile Harmony DPGT750EC Electric Dryer
DRYER PROBLEM I HAVE A GE PROFILE HARMONY AND IT WILL DRY FOR A WEEK AND THEN FOR 2-3 DAYS IT WON'T DRY. THEN IT WILL START DRYING AGAIN. WHAT COULD THE PROBLEM BE? PLEASE EMAIL ME BACK thunter39440@yahoo.com or call me 601-422-9051
  • gdragonfly Oct 06, 2008
    I have the same problem...it seems to work better on warm days...I say that because its in a room outside the back door and on warm or hot days it works fine but on coold days in wont heat...it will tumble but the heat wont come on...if you can help please...what maybe the problem...Thanks
  • scottmst30 Oct 09, 2008
    GE profile dryer not drying
My dryer shut off one day and will not start up I reset the breaker switch and no luck
Posted on Oct 10, 2009
I have a GE Dryer Profile Harmony. It is several years old. The dryer is not blowing air out the back ventilation so not drying. It is making a quiet odd sound as well. When I troubleshooted I shut the...
You vent is plugged very bad. Disconnect the vent tubing and thoroughly clean it out. It will heat and dry like new afterwards guaranteed. These dryers have sensors that shut the burner off if the exhaust is not venting properly. Once its cleared out it will run perfectly again
Apr 09, 2010 | GE Profile Harmony DPGT750EC Electric...
Problem drying
no, what setting do you have the dryer on? is the dryer getting hot? if it is set correctly and is heating as it should then you need to check the vent hose, it is probably restricted with lint. Be sure and clean it from end to end.
Mar 12, 2010 | GE Profile Harmony DPGT750EC Electric...
My GE Profile Harmony Dryer is no longer Heating
Does it get hot when you turn it on, and then never gets hot again while its running? On my dryer the solenoid broke, when the dryer was cold it worked and the dryer operated properly because the dryer and solenoid were cold and the solenoid wire was closed, when the dryer was hot enough the solenoid opened and the heat would not restart. the solenoid is a coiled wire which is used to open the gas valve.
Dec 28, 2009 | GE Profile Harmony DPGT750EC Electric...
DescrI have a GE profile harmony electric dryer model #dpgt750ec1pl. About 5 minutes into a drying cycle the blower shuts down. There is still heat but no air coming out of the dryer duct. Any suggestions?...
you should not have heat when motor stops there is a switch in the motor to shut the element off....yours is not working(you could burn your house)replace the motor.
PLEASE DO NOT TRY IT AGAIN...can't be lucky all the time
Aug 07, 2009 | GE Profile Harmony DPGT750EC Electric...
Shutting off every 20 minutes
Your thremal fuse is getting hot. OR There are overloads attached to the element housing and one of them is getting hot and automatically resetting itself once it is cooled.
Apr 17, 2009 | GE Profile Harmony DPGT750EC Electric...
Taking long time to dry
An innovative dryer, the General Electric Profile Harmony DPGT750GCW(gas) / DPGT750ECW (electric) has the ability to communicate with its matching washer via the manufacturer's CleanSpeak system. More specifically, this Profile dryer is wired to the Harmony washer, allowing electronic communication between the two. If you're wondering what these two have to talk about, the answer is simple. They talk about your laundry and how to dry it.
CleanSpeak works by transferring information about a wash load to the dryer and setting it automatically so you don't have to make any. Machine-determined optimal settings for each load are selected by the information about each load size and type. Your job is simply to place the wet laundry in the dryer and press start.
That is where the problem begins, when you interrupt the drying cycle. The machine is then rest to small load dependent on when the interruption occurred. The dryer computes the duration of drying time again the wash load. Each time you load the washer, the dryer is computed to using the shorted time. Thus, we have double cycle.
you will need to override the automated settings and enter your own preferences. Doing so can be a bit complicated, as this machine has lots of intricate, detailed controls that may take some getting used to. In fact, we suspect that's why this dryer is designed to be set by the washer. Having individuals set it, with all its options, takes some patience. The good news is that once you have manually set cycles you have found to use often or like, you can enter them in the memory, allowing the machines to set them your way in the future.
Option is to unplug the machine and wait minimum of 2 minutes and plug in the machine, hit power on.
I would recommend unplugging both machines, and rest both to factory default.
good luck
Nov 05, 2008 | GE Profile Harmony DPGT750GC Gas Dryer
GE Profile Harmony DPGT750EC Electric Dryer Logo
540 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
