Question about Car Audio & Video
Key chain button
Need button for 2003 chevy i bought used.
    Genius:
  • 1,011 Answers
Sir,
Put the key in the ignition, and turn forward
all the way just before cranking. Then within
5 seconds, locate, press and hold in the
valet/overide button, until the LED
in your dash area goes on solid,
and the siren chirps once.
This should reset the alarm, and reset
the grounded relay on the starter wire,
allowing you to start the engine.
At this point, the only thing working would
be the keyless entry from the alarm,
if it came equipped that way.
Just Repeat these steps to place it
back to usable armed mode.
You may get 2 chirps, confirming it,
and the lights may flash twice as well.
thanks
good luck
Posted on Oct 06, 2008
    Guru:
  • 1,894 Answers
Need which button?
can you explain the problem in detail?
Is the transfer case in the 2000 chevy 1500 chain driven or gear driven
I don't know for a fact but considering a lot of the smaller Chevies are recycled Vauxhall/Opel designs I guess a chain drive is used.
The small Chevrolets used to be called Daewoo and was dirt cheap to mend until they went bust and General Motors bought them and renamed them, suddenly they got Vauxhall/Opel parts prices.
Feb 04, 2015 | Cars & Trucks
Does 2003 Chevy ecotech motor have a timing belt or chain
It has a timing chain and a balance shaft chain also. My 2003 Cavalier jumped time about 2 months ago and that is what it had in it.
Jan 06, 2012 | 2003 Chevrolet Cavalier
How to remove timing belt for 2003 chevy tahoe
Hi, the 2003 Chevy Tahoe utilzes a non servicable timing chain, and does not have a timing belt. Thanks...Coop
Dec 26, 2010 | 2003 Chevrolet Tahoe
What is the right way to time a 4cyl Chevy S-10 timing chain
1998-2003 To Remove:
  1. Remove or disconnect the following:
    • Crankshaft pulley and hub
    • Timing chain cover and gasket
  2. Install a bolt in the end of the crankshaft CAUTION
    Do not install the crankshaft balancer bolt or a bolt longer than 1 inch or damage to the crankshaft threaded hole will result.
  3. Rotate crankshaft until the number 1 piston is at Top Dead Center of compression stroke.
  4. Make sure that the alignment marks are aligned with the tabs on the timing chain tensioner. gm-03-22-611.gif
  5. Measure distance between hole in bracket and unworn surface of timing chain tensioner shoe. NOTE: If distance between the hole and unworn surface of timing chain tensioner is greater than 0.314 in (8 mm), replace tensioner, timing chain and sprockets.
  6. Remove timing chain tensioner bolts.
  7. Remove the timing chain, timing chain tensioner and camshaft sprocket at the same time.
  8. Remove the crankshaft sprocket using special tool J 22888-20A or equivalent.
  9. Remove crankshaft sprocket alignment key.
NOTE: If any camshaft components are being replaced to correct a noise problem, all camshaft drive components must be replaced.
To Install:
  1. Install the crankshaft sprocket alignment key.
  2. Install the crankshaft sprocket using special tool J 5590 or equivalent. gm-03-22-613.gif
  3. Compress the timing chain tensioner spring and insert a pin into the tensioner hole to retain the tensioner shoe.
  4. Install timing chain and timing chain tensioner (do not tighten tension bolts).
  5. Align the crankshaft and camshaft timing marks with the tab on the timing chain tensioner.
  6. Tighten the timing chain tensioner bolts.
    • Torque to: 18 ft lbs (24 Nm)
  7. Tighten the camshaft sprocket bolt.
    • Torque to: 96 ft lbs (130 Nm)
  8. Remove pin from timing chain tensioner hole.
  9. Remove bolt from end of crankshaft. CAUTION
    Inspect the timing chain cover for warping or damage. Replace if needed.
  10. Clean all timing chain cover mating surfaces.
  11. Install or connect the following:
    • Timing chain cover to the engine block
      1. Ensure that the gasket is installed properly in the groove in the timing chain cover
    • Timing chain cover and make sure it fully seated on the alignment dowel pins
    • Timing chain cover bolts
      1. Torque to: 97 inch lbs (11 Nm)
    • Drive belt tensioner
    • Crankshaft damper hub and the crankshaft pulley
Aug 17, 2010 | 2000 Chevrolet S-10
Does a chevy 5.3 V-8 have a timing belt or chain? My truck just turned 100k and I'm wondering if it needs maintenance or replacing.
Chain. It doesn't need replaced unless it has a problem. Chains don't have a service replacement interval.
Jun 03, 2010 | 2003 Chevrolet Silverado 1500
When dose a timing belt need to be replaced on a 2003 express van?
This van has a timing chain, which should last for the life of the engine. The LS engines, which I'm guessing you have one of the 4.8,5.3,or 6.0L, use a high quality roller timing chain that is long-lasting, and won't give you issues. Also, having roller lifters, the camshaft puts less resistance on the timing chain, so the combination of a strong chain coupled with less resistance, makes for a reliable chain.
May 11, 2010 | 2004 Chevrolet Express
Is there a trunk button for 2001 chevy Impala
look on the dash at the left side or on the left door
Oct 13, 2009 | 2003 Chevrolet Impala
Driver and Passenger auto door locks are inop.
Sounds like bad wiring, or bad door lock actuators. Check for power while locking/unlocking the doors.
Jun 29, 2009 | 2003 Chevrolet Astro
Need to program spare keys for 2003 s-10 and 1997 astro
dealership job.you need a special scanner to reprogram it.
May 02, 2009 | BMW 750 Cars & Trucks
Car Audio & Video Logo
130 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
