Question about Sony Handycam DCR-DVD108 DVD Camcorder
Sony dvd is now showing logo in black and white and will only play dvds in black and white
    Sergeant:
    Champion:
  • 334 Answers
IS COLER OPTION ON THE SONY CAM TURNED ON IS YOUR VIDEO CABLE OK cheak both 1st thx nick
Posted on Oct 06, 2008
Will only play DVDs in Black and White
Onkyo DV-CP706B 6-Disc DVD Player (Black) - Amazon.com
www.amazon.com/Onkyo...Player-Black/.../B001AMS...
Amazon.com, Inc.Color: BlackChange .... It's quieter than it was before, and it plays ALL DVDs, even if you can see some visible damage ..... THere was no color-just black & white.
Onkyo dvd player no color only black white Questions ...
www.fixya.com > Forum > Tags > dvd player no color only black white
Onkyo dvd player no color only black white related problems. Ask your Onkyo dvd player no color only black white questions. Get free help, advice & support ...
Onkyo dvd player plays black white Questions & Answer
Dec 29, 2015 | Onkyo Dr-s2.2 5.1 Dvd Home Theater...
Phillips TV shows black and white only when playing DVD
If the DVD is built into the TV, try and DVD cleaner Disk.
If it is external, try a different DVD player and disk.
May 27, 2014 | Philips Televison & Video
Why is it that some dvds only play in black n white?Is there any way to fix this?
Your solution may be to connect your cables to the front of your tv, instead of the back as found here:
http://www.velocityreviews.com/forums/t699272-problem-solved-for-dvds-showing-in-black-and-white.html
Sony also supports this solution, as found here:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C89600&fes=true
Sony also advises it may be due to a faulty cable or if the signal is being transmitted via a vcr.
As per this site:
http://www.gaiaonline.com/forum/computers-technology/sony-dvd-player-only-plays-in-black-and-white/t.41173519/
if your s-video cable going to your tv is loose or is faulty, then only 2 of the 4 pins are communicating with the tv, thus resulting in a black and white picture.
Jun 28, 2010 | Sony DVP-NS51P DVD Player
All region code for Medion DVD recorder MD84100
Found on another board, tried and it worked on my Medion
P70002 / MD84100 DVD recorder:
Turn on DVD recorder
Press HOME on remote
Go to SETUP in Easy Menu
Move down to padlock icon
Press 0 seven times
Message appears:
Congratulations!
Region Change Free!
YES (press ENTER)
It now plays US and UK as well as Australian (in my case).
Dec 31, 2008 | Electronics - Others
Only black and white
If you are playing different region dvds, they can be of different color formats also
(US = NTSC, Europe = PAL). If your television is not multi-format then non-compatible
DVDs will play black and white. The solution is to purchase a mutli-format TV (accepts
both PAL and NTSC formats)
Aug 31, 2008 | Sony DVP-NS50P DVD Player
Cant read dvd on my sony 18x dual layer dvd writer
go to nero 6.66 and use imation discs, if your os is running ok and you do not suceed whith that i told you, your dvd unit is bad.
Mar 14, 2008 | Sony AW-Q170A-B2 BLACK 18X DOUBLE & DUAL...
Only black and white movies
your tv is posibley on svhs instead of av1 or av2
have a look at the logo that comes on when you chose the channel
Dec 08, 2007 | Sony DVP-NS315 DVD Player
Playing burnt dvds in black and white
Cause: You are trying to play a DVD with NTSC-standard on a PAL-videodevice. Solution: switch your video-device to NTSC-standard or to "AUTO". Explanation: I had this "Black&White" problem after I played a DVD which I downloaded from Internet. My video-device (beamer) was set on PAL and gave black&white pictures, but when I switched it to "NTSC" the problem was solved. Apperently the Sony DAV-DZ100 switches automatically from PAL to NTSC when needed.
Nov 01, 2006 | Sony DAV-DZ100 System
Toshiba MW27F51
It is not clear whether one DVD or all DVDs play in black and white. If it is only one make sure that the format of the DVD is correct. If it is all DVDs, given that the VHS tape and cable play with color, there could be a problem with the chroma circuit in the unit. This is probably something that a technician would need to diagnose. Good luck.
Jun 30, 2006 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Sony Handycam  DCR-DVD108 DVD Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
