Question about Brother Office Equipment & Supplies
HL 5170DN - the red service lite stays on and the orange paper lite is flashing; printer does not initialize
    Guru:
  • 558 Answers
Since when this problem arised, have you install a new cartridge?
Try to unplug the USB connection.
Try to turn off and reinstall the cartridge again. Also shutdown the PC. Then power on PC & then Printer.
Let me know the further status so I can investigate further and fix the problem.
Posted on Oct 06, 2008
  • Puneet Jain
    Puneet Jain Oct 11, 2008
    May be the motor need to replace and the printer need Repair and Service. Check it out and take it to nearest dealer for service. Please vote Helpful or FixYa, otherwise leave the solution as it is.
When we print the green status light changes to red and nothing prints. Sometimes we can open the front of the printer, close it, and then it will print. The speed light is orange and the connection...
I guess the paper is not feed every time. Pull out paper cassette and you have to see paper feed roller he is rubber, just clean it with cloth and water or alcohol.
I hope this help you!
Sep 08, 2011 | Brother HL 5170DN Laser Printer
Tip
Brother HL 5170DN Printer Toner error
Trick Brother HL 5170DN printer into think there is toner left. Rather than run out for a new toner cartridge use a small (.5 x .5 in.) piece of black electrical tape to cover the sensor hole on the non-gear side of the cartridge. By covering the hole the printer is fooled into thinking the hopper is full of toner.
on Feb 01, 2010 | Brother HL 5170DN Laser Printer
Broter hl-5170dn in paper jam drum
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot
remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of
the jammed paper from the paper tray
Jul 07, 2011 | Brother HL 5170DN Laser Printer
Paper jam btother prinnter 5140
Hi justus1229,
Just click on this link and you'll have the step by step procedure on how you'll clear paper jam. This troubleshooting works for HL-5140, HL-5150D, HL-5170DN brother printers.
Hope it helps.
Thank you for using Fixya.
Apr 14, 2011 | Brother HL 5140 Laser Printer
Brother HL-5170DN 4 yellow lights - seems dead
if all the lights are flashing it means there is a physical problem with one of the main parts of the machine, such as the power supply or main board. you can find a technician on their website who would be able to fix it for you
Mar 23, 2010 | Brother HL 5170DN Laser Printer
Brother 5250dn and all light are blinking
That series of lights indicates a main circuit board failure. You will need a shop to replace the main logic PCB. Could be caused by anything, static shock, bad input power from power strip or power failure, just plain CPU failure. If it's under warranty, 1 year since purchase, you need a Brother service center, out of warranty a new printer would cost less than repair.
Feb 02, 2010 | Brother HL 5250DN Laser Printer
My HL 1440 Laser printer does not print The
If your printer have no paper jam inside and paper tray has paper in it, then you need to replace toner cartridge.
Oct 06, 2009 | Brother HL 1440 Laser Printer
Brother hl 5170dn light amber
Open the printer - remove the toner etc. shut the door. Should resolve the problem.
Jun 18, 2009 | Brother HL 5170DN Laser Printer
Extra paper being fed after print job
Try a test page from the control panel, if this works properly you probably have an issue with the software of the printer. Reload the printer as if it was a brand new machine.
Jun 03, 2009 | Brother HL-2070N Laser Printer
Brother laserjet 5170dn
If you see the service call indication above, follow the steps below:
1 Take out the DIMM (Dual Inline Memory Module) from your printer, if you have a DIMM installed.
2 Turn off the power switch, wait a few seconds, and then turn it back on and try to print again.
If you cannot clear the error and see the same service call indication after turning the printer back on,
call your dealer or a Brother authorized service representative.
When you press the Go and the Job Cancel buttons together, the LEDs will light up with one of the
combinations shown in Table 1. See Table 1: LED indications while pressing Go and Job Cancel on page
3-6 to identify the error.
Something has failed that the printer can't recover from.
Apr 18, 2008 | Brother HL 5170DN Laser Printer
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
