Question about Kodak EasyShare LS443 Digital Camera
Camera error E45
Sounds like the motor is struggling to push out the front. Have put in new battery and changed the card.
I have a feeling this is going to cost!
Thanks
Rosie
  • rosiered Oct 07, 2008
    Thanks tried it and broke a fingernail.
    Rosiered
  • rosiered Oct 08, 2008
    It is just as I thought. Thanks for all your help
    Rosiered
    Scholar:
  • 116 Answers
Its a lens assembly error .clear up the jammed part with uzobibe solution which will make it movements free and u will be back to work.
Posted on Oct 07, 2008
  • Kodak Master
  • 1,879 Answers
Try this :
Use a power AC adaptor.
Power it ON facing lens down
Posted on Oct 06, 2008
    Genius:
  • 3,422 Answers
The error E45 is a lens sensor issue.
Either the camera has got very damp or grit has got into the lens.
Now here's the fix which so far has worked for me with many similar canon models.
If your camera is out of warranty give it a good hard slap, canons are notorious for jammed lenses and shutter, being just a thin sliver of plastic any damp tends to make them stick together, hold the camera and bash the edge next to the lens against the palm of you hand as hard as you can, bash your camera against a bit of carpet on the bench.
This iften solves the problem let me know the result.
    Genius:
  • 1,011 Answers
Sir,
It is basically a shutter/ lens error, and all I've heard is that it's expensive. Kodak tells you that it means the camera "requires repair." Most people seem to throw them out rather than repair them with this problem, but definitely call Kodak and at least get a price estimate.
thanks
good luck
  • 6,487 Answers
This can be a mechanical problem already , so it will be better for you to take it to a service center near you and have it fix there, because it may need to replace some parts of this camera...
Hope that helps........
    Genius:
  • 1,550 Answers
This will cost up to $100 .
If the camera is more than 2 years old you can go for new one .
    President:
  • 2,712 Answers
Try a hard reset first - Remove batteries and SD card, wait 5 minutes, and replace everything and see if that helps..
  • Swilin Sampson
    Swilin Sampson Oct 06, 2008
    Likely something is causing the lens not to retract. Pushing on the lens should dislodge it and get your camera
    working again. Or you could try gently pulling the lens out manually. You can also try giving it a good hard slap; hold the camera and bash the edge next to the lens against the palm of you hand as hard as you can. If the lens protrudes out, well and good. Try tightening the lens by twisting it as far as it will go (if possible).
    Should this not work, then I suggest buying a new camera, as the cost of repairs are not justified.
    Hope that helps! Should you have any further questions,
    please post them here.
    If you are satisfied with my solution or have no further queries, please take a
    moment to "Accept" this solution.
    Thank you for using Fixya!
    Cheers!
    IrishDruid
  • Kodak Master
  • 19,396 Answers
Try removing batteries and putting them back in place.
The error is because the lens are stuck an cannot extend. try tapping gently the back of the camera while you turn it on, or helping the lens out with your fingernail.
If you can get the lens to extend, the error should clear.
  • Ginko
    Ginko Oct 07, 2008
    If helping the lens out by slapping gently the back of the camera , or pulling lens mechanism did not help (sorry for your finger nail), then the camera must be taken apart.
    The repairman will disassemble the whole lens mechanism, clean and lubricate the lens gear, and mount the camera back.
    When the simple solution does not work, that is the only way to fix lens error.
    See also Kodak online digital camera Interactive Troubleshooting & Repairs.
    Guru:
  • 1,894 Answers
This may be due to some sand or big dust particles stuck in lens assembly
try cleaning the assembly
have you tried a hard reset?
  • dewan nafees ahmed Oct 06, 2008
    It is basically a shutter/ lens error, and it is expensive.
    If you can hear the motor going, start up the camera and push the lens
    back in. Likely something is causing the lens not to retract (sand or
    something who knows). Pushing on the lens should dislodge it and get
    your camera working again.
    This error is caused due to the failure of lens alignment system.Try following the procedure below..
    it may be the lens contacts or grit in the gears
    open it up on
    the side of the lens you will see a row of thin gold coloured contacts
    that report the lens position back to the cpu sometimes these get dirty
    or bent.on the side of the lens is a motor, look where the gear
    meets the lens and use a pin to flip out any grit that is stuck in the
    teeth.
    Its very unlikely the lens is "out of alignment" this just
    cant happen unless its been dropped or bashed, in which case it may be
    broken.
    originally posted here
    http://www.fixya.com/support/t240817-cam...
    thank you
Error e45
Kodak indicates that the e45 error means that it's time to repair your camera.
But, it could be that your battery no longer has the capacity to adequately power the camera, especially the lens function. Lithium Ion batteries lose capacity over time. If your battery is over 3 years old, a simply replacing the battery may solve the problem.
Nov 15, 2010 | Kodak EasyShare V705 Digital Camera
Getting an error code E 45
Error 45 in your camera clearly indicates it is related to a lens issue. Something has caused the lens to jam or stop working. When it does you get the E45 error you have to update the firmware and the error should go away.
Thank you !!
May 23, 2010 | Kodak EasyShare CX7430 Digital Camera
Camera locked - camera error #E45
Hi
www.Kodak.com says:
"E45" appears on your camera's display when your camera requires service or repair.
I think it is a lens error. They have a page on www.kodak.com called Step-by-Step Solutions and Repair. This is for USA only.
See what they suggest.
I may be cheaper just to get a new camera.
Hope this helps.
Feb 21, 2010 | Kodak EasyShare LS753 Digital Camera
Error #E45
For this problem try the following:
Make sure that you are installing a fresh/ full charge battery
Remove the memory card and the battery
Clean the metal contacts on the battery using a clean cloth
Use the camera w/o the memory card
If problem still persist call the Tech Number
1800 235 6325 op 12 op 2
Hope this will help
Thanks
Byron
Oct 02, 2009 | Kodak EasyShare V610 Digital Camera
When i turn my camera on it says E45 and i look in the book there is no E45 . and makes this werid sound like it is dead basic information
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
If issue persists, call 1.800.235.6325 for repair.
Thanks.
Neerak21
Sep 27, 2009 | Kodak Cameras
E 45
E45 is a lens error.
Here are the steps:
clean cloth.
Thanks.
Neerak21
Sep 25, 2009 | Cameras
Turned off camera, opened hatch to battery and memory card too quickly. Turned on camera Error E45 displayed on screen.
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Apr 18, 2009 | Kodak EasyShare V610 Digital Camera
V610 KODAK ERROR E45
This problem is frequently due to weak/worn out batteries or corroded battery terminals inside the camera. If charging/replacing the batteries does not clear the problem, remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Dec 04, 2008 | Kodak EasyShare V610 Digital Camera
Error #45
Error message appears on EVF/LCD screen
  • Turn the camera off, then on again.
  • Remove memory card from the camera.
  • Remove the battery and wipe the contacts with a clean, dry cloth ( Battery life).
  • Insert a new or charged battery ( Loading the batteries).
  • If all else fails, get customer support help
Jan 04, 2008 | Kodak EasyShare Z740 Digital Camera
Error code E45
can u help me with my camera. its a kodak LS 443. I keep getting a saying that is has a error # E45. the lens are stuck. Can u tell me wat do do or give me advice please
Nov 20, 2007 | Kodak EasyShare LS443 Digital Camera
Kodak EasyShare LS443 Digital Camera Logo
231 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
