Question about E-Machines Computers & Internet
T6520 emachine. when i turn it on the fans start, the keyboard lights flash, the monitor led turns green (getting a signal) and about the time i'd expect to see some display image and/or hear the mobo spkr beep, the monitor led goes to amber (no signal). it had a graphics board - i removed and hooked monitor up to mobo video o/p - same results. i pulled all of the i/o power and data cables - same results. nothing smells burnt - no surge or lightning strikes - just won't reboot??? any suggestions?
    Novelist:
  • 169 Answers
Based on your previous troubleshooting, with both built-in video and alternate video card, I'd guess you have a bad mobo. Anything else that was wrong with it (RAM, CPU, etc) and you'd get beep codes.
Sounds like it's time for a replacement board. If the eMachine is out of warranty, it might make more sense just to go ahead and upgrade now, as they are so inexpensive. If you are capable of replacing the board yourself, that would be the cheaper alternative.
Hope this helps - remember to rate (and great troubleshooting, btw!)
Scott
Posted on Oct 06, 2008
My optima with asus P4VP-MX will not start up. It has been in storage for a long time ,but was working when stored. Fans start,green led on, hard drive clicks, power to mouse, lights flash on keyboard,but...
do a system recovery Asus computers system recovery can be done using the recovery disk that comes with the computer or it can be done by pressing F9 on the computer keyboard upon boot up.
Jul 25, 2010 | ASUS Computers & Internet
My emachine T1742 desktop will not turn on. When plugged in the power supply's fan turns on, cpu fan doesnt start, both hdd/power led's flicker and pressing power button doesnt power on/off system.
Disconnect all the devices from the computer(tower) including keyboard, mouse, monitor(everything)..even the power cable
Now keep on holding down the power button on the computer tower for 15-30 seconds..
Now release the power button, plug in the power cable, monitor, keyboard, mouse and turn on the computer...
If it works, great!!!
Otherwise, take it for repair..
Dec 03, 2009 | E-Machines eMachines Desktop PC
Emachine T6520 Wont Start Up
Check your num lock key status press it on and off if hum lock led is on and off when u pressing then your cpu working fine. so check connectiopn of vga cable cpu to monitor.
Also some times display screeen resolution issue so when u power up press F8 key then enter in enable vga mode then you can chang escreen resolution to 1024*768.
but if num lock key is not on and offf then open the cabinet of cpu then find cmos cell on mother bord and pull it for 14 minutes then check .
Jul 04, 2009 | E-Machines eMachines Desktop PC
When I turn on my pc I an see the hard drive light working and flashing, indicating that it is loading up, but my monitor does not receive any video signal,so I hooked my pc to my freinds monitor and I got...
Sounds like your video card is bad. You will need to purchase a new one. On some machines there is 2 video connectors -like 1 on the motherboard and 1 other mounted in a slot just verify that you have tried both connectors if you have them before buying a new card.
NOTE: Usually the slot mounted video card will over-ride the motherboard video by default.
Good Luck!
Rich
Jan 30, 2009 | E-Machines eMachines Desktop PC
Powering up problems.
Try using another monitor that you know works. Then try another video card. The fans are running because the computer is running ---but the monitor is not. Green to Amber means monitor is not on.
A lot can go wrong with loose wires that shouldn't be loose.
But I would try this first.
Jul 22, 2008 | E-Machines eMachines Desktop PC
Unit will not Boot up
Make sure your monitor is plugged in and try again
Jul 07, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
185 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
