Question about Maxdata iStarUSA TC-A100B 1U IPC Keyboard and Drawer Keyboard, Mouse
Maxdata keyboard suddenly does not work after two years.  Only the touch pad works
  • 2 more comments
  • Angelica217 Oct 06, 2008
    I forget to add that it is a LAPTOP. Do you have any further solutions?
    Maxdata Pro 650T (332426) PC Notebook --- This is the model.
    Thank you Nick for your help. I did not know I had to do all this. I thought I just pressed a couple keys incorrectly together.
    Thank you again for your help!
    Nick-- Excuse my ignorance, where is the LCD/ tv key?
    I held FN with F4 - because F4 has a picture of a TV on it-- Nothing is happening.
    Sergeant:
    Champion:
  • 334 Answers
On labtop go on ebay for you model labtop and buy new keybord pop off top panel were vol is with screen layed back all way open pop top panel off 2 screws kb out then get replacemnt from ebay or use extrnal mouse and kb for now to u can get the part
Posted on Oct 06, 2008
  • nick helpap
    nick helpap Oct 06, 2008
    well u can couve hit wrong key that fn hold that key hit lcd/tv key to toggle betwwen outoputs if that aint it then yes gotta do the keybord tak eout job ok thx again nick rate me if it helped
  • nick helpap
    on top of keyboard its ok u see were says lcd/tv small key on top one of the f f under that maby hold fn bottem key as u hitthat top lcd key to togle screens ok
  • 661 Answers
Sounds like your keyboard connector has come loose, these eyboard units are actually a seperate keyboard and mouse pad built into one unit, so the mouse's electronics are seperate,
you may also want to check the connector to see if there are any broken/bent pins in the connector (sometimes happens, when accidently unplugged)
hope this helps :)
My mouse touchpad stopped working all of a sudden. I have also enabled the synaptics touch pad in device settings in the control panel. after doing all these also my touch pad is not working.
Check the keyboard it's possible the touchpad has been deactivated. You can toggle fn keys (fn + f2) or any fn key that has touchpad drawn on it. If this doesn't help. Am afraid the touch pad connector has to be checked & replaced in computer repair shop
Jan 27, 2013 | Lenovo Computers & Internet
Touchpad of my dell inspiron 1464 laptop suddenly stopped working when my kid pressed some keys here and there .How can i enable it again?
To enable or disable the touch pad, press the key on the function key row on the keyboard. It is next to the F12 Key.
Hope it helps! Good Luck!
CreativeTECH
Mar 31, 2011 | Dell Inspiron 1464 Notebook
When I type on my keyboard, the pointer skips around. I can be typing on one line and all of a sudden, the typing is in another place.
hello, This happens because you are landing some part your hand (palm) in the touch-pad when you typing. which activates the touch-pad and makes sudden movements in the pointer.
This problems for lot of laptop users, unless you can get use to prevent the hand from touching the touch-pad, the only option is getting a USB keyboard where you can plug in without any drivers and type without any trouble.
Mar 30, 2011 | Dell Inspiron 6000 Laptop Keyboard 0H5639
Laptop Touch Pad will not work
if you plug usb keyboard onto your laptop it will probably turn the touch pad off.
If no other keyboard is attached there is usually a switch to turn off the touch pad.
also if you attach a mouse this may disable the touchpad so you dont move the mouse pointer when you are typing
Jul 10, 2010 | Acer Aspire One PC Notebook
I have an Acer Aspire 5517 and all of a sudden, the keyboard will stop working. The touch pad works fine but nothing on the keyboard (nothing! the letters, numbers, hotkeys) will work. Can anyone explain...
With an Acer, most likely the keyboard went out or the ribbon cable from the motherbaord came loose. The touchpad and keyboard are separate units so will work independent of each other. It's a simple replacement.
Feb 02, 2010 | Acer NSK8458AN Keyboard
I have a Dell XPS M1710 laptop. The touch pad does not work.
Unless it is a hardware fault open the control panel>system>mice and uninstall the touchpad. Then rebott. It should solve the problem.
Jul 23, 2009 | Dell F3534 Touchpad
Acer 6920- keyboard, touch pad and audio stopped working suddenly
Go to the manufacturers website and download/install the BIOS update
Nov 18, 2008 | Acer Aspire 5100 Notebook
Aspire 5100 Kepad and touchpad not working
have k/b and touch pad been disabled in BIOS?
Oct 30, 2008 | Acer Aspire 5100 Notebook
Touch pad not working
If Windows service pack 1 - doesnot all recent drivers and will not recognize your touch pad and even keyboard.
Try to boot on Safemode.
Just press on F8 when your start your computer - and connect an usb mouse and try to install the touch pad drive manually.
Then boot on normal mode and install your other drivers..
It is recommended to update quickly your os to Service pack 2 or 3 for best performance of your computer.
Oct 14, 2008 | Acer Aspire 5100-5022 Notebook
Acerr Aspire 5315-2940
I don't know if you mean that your cursor suddenly moves as you are typing? If so, it is likely your touch pad is too sensitive. I have a mouse w/mouse pad but never disabled the touch pad. So i disabled the touch pad and it solved it for me. If you want to be sure it is the touch pad being over sensitive, then type a paragraph but keep your fingers and palms far away from the touch pad. If the problem improves, like it did for me, then the touchpad is too sensitive. You can go into the settings for the touchpad to change the sensitivity setting to make it less senstive and see if that works and it does not then press Fn +F7 keys to disable the touchpad.
Aug 26, 2008 | Acer NSK8458AN Keyboard
Maxdata iStarUSA TC-A100B 1U IPC Keyboard and Drawer Keyboard, Mouse Logo
521 people viewed this question
Top Maxdata Computers & Internet Experts
Willem.
Willem.
Sulkhan Abesadze
Sulkhan Abesadze
tim brauer
tim brauer
Are you a Maxdata Computer and Internet Expert? Answer questions, earn points and help others
