Question about Edirol FA-66 Sound Card
How do i get my FA-66 to work via firewire?? please help!!!!!!!
My Edirol FA-66 will not power up through the Firewire setting, only through a mains supply. Do i need to change any settings to do so, if so,how??? cant find anything relating to this in my manual !!
  • 3 Answers
The pcmia FW card option does NOT send power via the firewire cable...I think it has to be straight from the computer; 6 to 6 pin cable. Try changing the power option switch toggle on the rear panel(bus,dc,off selector)
Posted on Dec 03, 2009
U're probably trying to connect it with a 4 to 6 pins firewire cable to your laptop right?
if so, the laptop firewire connection is usually the small type (4 pins). this kind
of connection does not give Power to the firewire device.
u can buy a pcmcia card with 6pin firewire connections and usa a 6 to 6 firewire cable
and that will work. i hope. :)
Posted on May 18, 2009
2 Suggested Answers
  • 3 Answers
SOURCE: Edirol FA 66 firewire
Download/install the drivers from roland/edirol site for PC. For Mac, its plug and play. Just select the edirol in the audio options.
When using Firewire bus to power the sound card my
It's likely that the FireWire bus isn't meeting the power needs of your card. Just use the external supply since there isn't too much you can do.
Jul 13, 2010 | Edirol FA-66 Sound Card
My FA-66 is connected to my MacBook Pro via Firewire. When I plug a secondary display in, it makes lots of extraneous noise, even worse if the PSU is not connected to the MacBook Pro. What is causing this?
Is the noise a constant hum? If it is such a noise, I suspect a faulty or poor performing power supply. Check the power supply that powers Edirol sound card for any improper ground. Another custom made power supply which is properly regulated (voltage) and at a higher ampere rate would be an idea to consider. I think your main issue is grounding because you say the case become worse when the MacBook PSU is not there. Because, you are loosing a ground path when you remove the PSU. Then it solely depends on the Edirol ground path. If that path not a good source of ground, there lies your problem.
Mar 09, 2010 | Edirol FA-66 Sound Card
I'm using the FA-66 sound card with Ableton Live 8.1.1, and keep getting the message 'Failed to open te audio device' when I try to set my audio preferences. I know that everything works, because usually...
this error is usually shown when starting up an audio app while there's a different one already running... before starting up your AL8, check if no other audio programs are running (players such as WMP, Winamp, VLC, editors like Wavelab, ......)
Problem with stereo output on Edirol FA-66
Possibly, your adapter of small to big is not a stereo adapter. Seems like a mono adapter.
Jun 15, 2009 | Edirol FA-66 Sound Card
Edirol fa-66
1.i gained info about the mains supply data (9 volts 2 a, minus pole in the center pole of the plug) which is a quite exotic supply in comparison to standard devices with 12 volts an plus pole in the center pole ...
the fa 66 didn't work , when connected by 4 to 4 or 4 to 6 firewire cable .
my laptop only has a small 4 pole socket.
therefore i suppose that through this 4-pole socket and cable there was no current lead through.
after additionally connecting the fa-66 with mains supply AND 4 to 6 (fa 66 side) cable ... it finally worked.
the manufacturer should print all relevant data directly to the fa 66 device near by the socket und also print "FA-66" onto the supply ... because i own lots of alike-looking supplys and it's a drag to find out which ist good for what...
Mar 23, 2009 | Edirol FA-66 (FA66)
Oct 09, 2008 | Edirol FA-66 Sound Card
Edirol Fa66 Problem
I bought the FA-66 because I use Cakewalk Sonar and they sell this interface on the Cakewalk site with thier name on it. I've had nothing but problems with this unit as described above. I've tried it on two different computer and it does not work on either. I also use an RME Fireface 800 on both these machines, same set up and it works flawlessly. Drop the Edirol/Roland FA-66 and try something else like an RME card or something. That would be my suggestion. It's a shame Cakewalk promots this piece of garbage. I've tried Edirol/Roland technical support and the guy just kept saying the sound card works fine, like it was just my problem.
Jan 06, 2008 | Edirol FA-66 (EDIFA66) Audio Input
Edirol FA-66 Sound Card Logo
449 people viewed this question
Top Edirol Computers & Internet Experts
David
David
Ben Armstrong
Brian Sullivan
Brian Sullivan
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
