Question about Kodak EasyShare Z712 Digital Camera
Battery problem Kodak z712 uses different types of batteries and the one supplied with camera are non-rechargeable lithium type that die down soon. Camera specifications say one can use rechargeable lithium-ion, Klic-8000. Now while replacement klic-8000 are cheaply and abudantly available, is this appropriate to use them in this model? Some say the can leave the camera damaged. I need a solution because I am not getting the original kodak klic8000 in my city.
  • Anonymous Mar 13, 2014
    3.0V Lithium-ion rechargeable battery fix on my zenit nv night vision scope?
  • Anonymous Mar 17, 2014
    How do I recharge the lithium ion battery.The power adapter that came with the camera only has an aperture for a usb connection.Thank you
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
For my Z712 I'm using since one year CRV3 li-ion rechargeable.
No problems until now, few THOUSANDS of photos.
I've buy it from ebay.co.uk .
Regards.
Posted on Oct 14, 2008
I use aa battery's in my camera but they only take 5 to 10 pics at a time.......is this normal or is something wrong like maybe a setting or something? what should i do to fix this?
Digital cameras in general use a lot of battery power; this one in particular is noted for short battery life. When it was new, this camera was supplied with a Lithium Ion battery for longer life; if you're using regular AAs, the battery life will be disappointing. Oh, and cheap batteries from the dollar store might not even work at all!
The most cost effective solution is probably high capacity NiMH rechargeable batteries; get a set of four so that you can have spares on hand. If even that isn't acceptable, look into getting the Lithium Ion one.
If you bought this camera used, the short battery life could easily be the reason the original owner got frustrated with it.
Jan 21, 2011 | Kodak EasyShare Z712 Digital Camera
I Have the Problem with my Easyshare Z712 IS Batteries
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 03, 2009 | Kodak EasyShare Z712 Digital Camera
Won't use rechargeable batteries
It could be due to the fact that some rechargeable batteries are slightly different shapes and the nobbly bit on the + end doesn't reach far enough in, as it is the case with Maplin AA batteries.
In my case I placed a small drop of solder with a soldering iron on the + nipple and now they reach into any device.
Nov 26, 2009 | Kodak EasyShare C633 Digital Camera
My Z812 keeps telling me I need to reset the date/time every time I turn it on, even if I have just done it. Also drawing batteries very quickly (lithium, camera type)
It may only happen enter date and time if you remove the battery in the camera., If your not removing the batteru out of the camera you should not recieved that message, unless battery is out of charge or no power.
You should use this battery Kodak Li-Ion rechargeable battery KLIC-8000. This is a special battery for Z812 camera,
Note: You must also need to purchase a charger for this type of battery.
I guarantee you it will provide stable longer power for on your camera
Nov 20, 2009 | Kodak EasyShare Z812 IS Digital Camera
My Kodak EasyShare C180 Digital camera, came with "Kodak" batteries after those died, I inserted new batteries, and now everytime I try to turn the camera on, it doesn't respond. I have tried Lithium...
hi i just to have silimar problem with old panasonic, kodak and polaroid cameras.
try to use Duracel alkalines, not the cheap ones with out alkaline those are for remotes and clocks. flashlights.
if you are using rechargables make sure they are 2700mha AA NiMH or higher. lower won't work(there is another kind of rechargeables batteries those don't work on it).
for the lithium i never used them. they were kind of expensive compare to alkalines.
If i help. please rate me :)
Oct 08, 2009 | Kodak EasyShare C180 Digital Camera
Battery life of kodak easy share is 2 pictures ... if that
Please check what type of batteries are these.
Z1085 will only work with LITHIUM AA's, Lithium CRV3 (you have to make sure it's not Ni-mh crv3) and a rechargeable KLIC 8000 Lithium-ion battery pack (the blue one). It will not work with any other type of rechargeable battery but KLIC 8000. If you're trying to use ni-mh rechargeables, it will really not work.
Aug 23, 2009 | Kodak EasyShare One Digital Camera
My Kodak EasyShare Z712 IS problem is with the batteries. I'm using the Kodak Digital Batteries and they will only last about 30 minutes..even when I just use the viewfinder instead of the LCD. My son can...
I've had the exact same problem with mine. My wife was ready to buy a new one, but I didn't want to giveup the nice optical zoom on the Z712 IS. Checking out the web and a friend of ours with the same camera, it appears to be a common problem. My last time to try the camera, I took 19 pictures on brand new batteries and they died. The Kodak site doesn't really acknowledge a problem with the camera, but I found the latest firmware (1.06) and just walked around the house taking pictures with flash. At 25 pictures, I'm still going strong. Definitely worth a try to see if it fixes your problem: http://www.kodak.com/global/mul/service/downloads/DownloadFile.jhtml?locsvcsEntryPath=10807&product=EKN033025&operatingSystem=windows_xp&lang=en&type=firmware&downloadId=dln00179_file1&variant=false&pq-path=14091
Jul 12, 2009 | Kodak EasyShare Z712 Digital Camera
Which batteries are the best? Can I use alkaline, lithium or any others with this camera?
Lithium is actually one of the most widely used as it contains a higher charge. As for alkaline batteries they dont hold a high charge and may cause problems with your digital camera.
I hope this has answered your question sufficiently. If you have more questions please post a reply. Thanks.
Sep 22, 2008 | Kodak EasyShare Z712 Digital Camera
Don't know what this red thing is on the screen
There is an option for changing battery types in the menu. The accs that came with my camera where very good Lithium-Mh type. If replaced with ordinary Alkaline non-rechargable, you have to adjust battery settings, probably also if you got the very expensive Lithium-Ion batterys. The thig is that these three types has different voltages; 1.2, 1.5 and 3.2 (I think) respectivly.
Wrong settings could perhaps cause this your problem.
Dec 28, 2007 | Nikon Coolpix 5600 Digital Camera
Types of batteries.
You can use AA disposable batteries (alkaline or lithium) or rechargeable (NiMH or Nicad) batteries. Lithium batteries last much longer, but are generally quite a bit more expensive than alkaline batteries. You should never mix old and new batteries or different types of batteries. If you use Nicad batteries, it is recommended that you use a Nicad conditioning charger to extend the life of the batteries. Note: If you use rechargeable batteries, you will need a battery charger. The camera's AC power supply does not recharge batteries.
Sep 21, 2005 | Polaroid PhotoMax PDC 640 Digital Camera
Kodak EasyShare Z712 Digital Camera Logo
523 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
