Question about Yamaha RX-V659 Receiver
Yamaha rx-v2500 receiver how to hook up speakers
I only have 5 speakers & 1 sub what connections should i use to just hook these up or do I have to buy more speakers to have what they show in the owners manual thank you John
  • 2 more comments
  • goldwing2 Oct 06, 2008
    I need to know what speaker terminals I should hook my speakers to on my yamaha rx-v2500 receiver there are 1 center 4 other speakers & 1 sub thank you John
    1 answer said my 5 speakers and 1 sub are enough the rest are extra the 2nd answer said I have to buy 2 more what should I do who is right thank you John
    i'm going to hook it up like Ajkill said
  • Anonymous Mar 30, 2014
    Yamaha receiver klipsch speakers
    Sergeant:
    Champion:
  • 298 Answers
Use the one you have.. for 5.1 surround...on the back of the receiver there are outputs for right , left , center , rear left , rear right. and an output for the sub ... once you have all of them hooked up there should be a test tone option to insure that it is done properly. if you have any questions on how to do any of this just let me know.
Posted on Oct 06, 2008
    Scholar:
  • 116 Answers
First--the incoming cable from the wall carries all the channels from the cable company including both analog and digital or HD channels. They may not send the HD channels in a format that your TV can receive, but you can get the analog channels normally using the TV tuner, just as you found. The only way to get the audio to go with the channel on the TV tuner (rather than through the set top box) is to connect the TV audio outputs to an unused audio input of the Yamaha. Then switch to that amp input when watching the analog channels via the TV tuner. The audio will then follow the TV tuner as you change channels.
The Motorola cable box also has a composite video output that you could connect to the TV through the amp using its monitor output (yellow composite video)connection. Just connect the cable box analog output to the TV/Sat video input of the amp. Then just hook up the amp monior output to one of the video inputs of the TV and give it a try. This way you do not need to split the cable or use the TV tuner. Just go to the analog channels using the cable box and switch the TV to the video input. The amp should send video from both the component outputs and the analog composite video output simultaneously. Give this a try and see if this is the case.
Let me know if this works and if not what kind of results you have. Some amps do not send video to both outputs and I am not sure about this Yamaha model.
Hope this helps you. Good luck.
    Genius:
  • 2,035 Answers
You can hook the speaker like this one center speaker , two front right and left speaker,and then rear right and left speaker and one sub speaker in the unit ...
Good luck...
  • Anand Kumar
    Anand Kumar Oct 06, 2008
    You can connect the speaker you have right now , you can later connect the remaining 2 speaker if you wish to add it on your amp later.....
  • 10,594 Answers
If you want di-pole setup, you need 2 more speakers as this option requires 7 speakers.
  • 3 more comments
  • Shahid Electronics
    Shahid Electronics Oct 06, 2008
    I want to know what kind of speaker setting you want? So this will enable me to help you out.
    You can mention user manual page number and speaker setting name as I have one copy of same model.
    Below picture shows speaker terminals in your Yamaha receiver.
    You can hook up 9 speakers depends what surround mode you want.
    You have speaker set A and B, can select both at a time.
    This receiver has outputs for 11 speakers. (front a/b, surround, surround back, center and presence zone-2)
    but it is not necessary to hook all speakers right now. You can add more at later stage because you already have 5 speakers and can enjoy music.
    Genius:
  • 3,422 Answers
HI,
Follow these steps to connect a powered sub woofer to your receiver: You typically have two options when connecting a powered sub woofer. Input (1) on the rear of the sub woofer would be used when connecting the sub woofer to the receiver using speaker wires. You would then connect the main speakers to the opposite end, or output or the sub woofer to the main speakers. Option (2) would be using RCA line level output jacks, input (2) on the rear panel of the sub woofer directly to the single sub woofer output on the back of an AV receiver. yamaha rx-v2500 receiver how to hook up speakers - blank.gif
  • Priya darshan Oct 06, 2008
    I suggest you follow these steps from your manual:
    Put the speaker wire into the Presence/Zone 2 connectors on the right
    side. Pg 60 shows how to turn off the Presence Speaker, although the
    next steps may do it automatically. Pg63 has the instructions on using
    the internal amplifier for Zone 2. Change Zone2 to Internal, Volume
    will be set to Variable (although I was told by the seller that it'd be
    a fixed volume).
    (Sure enough, this step turns off the Presence Speaker, so you can skip
    the Pg 60 instructions). Next is Pg78-80, and it appears you must have
    the remote to do the rest. You have to get the remote in Learn Mode,
    then switch to L:AMP, press ENTER, Enter 2001 on the keypad, then
    ENTER, then LEARN. Then you need to select the Zone like you select a
    component, unfortunately it's not one of the buttons on the remote, so
    hit the Up/Down arrows until you see ZONE2 in the remote window, then
    turn it on by hitting the SYSTEM POWER button. Then select what you
    want to go to Zone2, like TUNER, then bring the volume up to 0.00db.
    That should be it.
    Zone2 are stereo pairs thoughout the house with individual volume
    controls. Keeping the volume at 0db works pretty well this way as the
    sound comes through after one click on the dial.Use the remote to power on and off the receiver...if you power on using main pannel the "zone2 and zone 3" will light up.
    Follow page 68 to use the remote to turn off the "zone2 and 3"
    top right hand of page 68 "AMP library code, (remote control setting)
    2000 is the initial setting put in setting 2001 and after that press
    "Select ^" on the remote and in the display on the remote it should
    show "zone 2" then press "System power" or "power AV "
    Guru:
  • 1,894 Answers
No you can use the speakers you have now
that is enough
those are extra
How to hook up subwoofer for yamaha RX-496 2channels receiver
You need to connect the subwoofer to your receiver using the speaker wire connections on the rear of the receiver. Take the speaker input from the subwoofer to the A or B speaker terminals on the rear of the AV receiver. Then take the speaker outputs from the sub and connect to the main speaker terminals. Really you need to buy a receiver with a sub out to do it properly. Sell this one and buy another.
Mar 02, 2017 | Yamaha Audio Players & Recorders
Tip
How to connect speakers to a Dell computer that has 7.1 intergated sound card....
This applies to: Dell Inspiron 530 and 531
Note if you are just connecting standard stereo speakers (2.0 or 2.1) you will just connect them to the green port. In adddtion if the speakers are 4.0 or 4.1 you would connect the rear speakers into the black port.
In regards to 5.1 speakers you would hook up the above listed connections and then connect the center and sub speakers to the orange port. The picture below shows the ring assignments for the center and sub-woofer connection if you are not using computer speakers.
For the 7.1 configuration you would hook up the above listed connection and then you would connect your side speakers to the white port. Note the side speakers are left/right speakers so the ring assignment is a standard setup with tip being left and the second ring being right.
on Aug 15, 2010 | Computers & Internet
How to get 2 omhs
Look on your speakers to see what ohm they're rated at currently. To get 4 ohm speakers to 2 ohm, simply wire the speakers in series. Meaning that you hook #2 sub to #1 sub and then to the amp. So you will have 1 connection to the amp but you'll be operating 2 subs. Hope this helps
Nov 27, 2013 | Rockford Fosgate PUNCH P1000X5D
I have two kicker cvr 12s how will I hook them up to hit the hardest with a jl audio 500/1
you would want to bridge them you take 2 pieces of speaker wire long enough to reach each sub and connect one side to the box and the other side of wire to the sub then you take your other speaker wire and hook it up to the sub you already hooked it to then run positive and negative to the other sub
Jul 07, 2010 | Audio Players & Recorders
Connect stereo amplifier to powered sub
You can y out from the main out to the sub.This output is post volume control. set level on sub to desired balance of lows feq to highs
Nov 20, 2009 | Yamaha YST-SW015 Subwoofer
I lost paper work
Simple enough,
everythink connects to the sub, so the 2 speakers the volume controll and the computer cable, then the computer cable comes out the sub into the green audio port on your computer :)
Feb 16, 2009 | Bose Companion 3 Computer Speakers
Subwoofer to receiver hookup
In general, there are two ways to hook up your sub-woofer. First using the high level outputs from your receiver ( speaker output from the front R & L speaker terminals ) run a set of wires from the outputs to the speaker inputs on the sub-woofer, you do this in concert with the speaker wires going to the front R & L speakers which you then attach to the R & L speaker outputs on the sub woofer amp. Note that the sub woofer doesn't power your front speakers, the connections from the sub amp are just a pass through connection where the signal needed by the sub is parasitically taken from the inputs.
Second is via a low level output from your receiver / amp to the low level input on your sub amp. This is normally done via a RCA type of patch cable and connected to the sub woofer RCA jack on the rear of the source receiver or amp, Next run the patch cord to the sub amp an into the RCA jack input. IF you have a right and left input, use the Right input.
john
Aug 18, 2008 | Audio Players & Recorders
Hooking up DVC subs
The amp is rated to run a 2 ohm load on each channel. To do this, connect the voice coils of one sub in parallel (tie both "+" on the sub to each other and both "-" on the sub to each other), then connect that sub to one channel of the amp. Repeat this process for the other sub and connect it to the other channel on the amp. The subs will be in stereo and the amp will be outputting it's maximum power.
Mar 09, 2008 | Legacy 2CH 1000W AMP Car Audio Amplifier
Hooking up these speakers with STR-DG810 receiver
ya does need a power sub out from a mini unit big sterios have sub pre outs sends signal only u could use speaker but u may blow them i would buy a kilshpsh set best buy 5.1 299 bucks to tie in sterio rock ya aaway
Jan 16, 2008 | Sony DAV-HDX500 System
Sub hook up to PPI D3000 amp
I'm not familiar with this amplifier but in most cases, if a mono amp has more than one positive speaker terminal and more than one negative speaker terminal, the positives are directly connected and the negatives are directly connected. So  as long as you connect the speaker positive to a positive speaker terminal of the amp and the speaker negative to a negative speaker terminal of the amp, it will work properly.
Oct 12, 2007 | PPI D3000/1 Car Audio Amplifier
Open Questions:
See all Yamaha RX-V659 Receiver Questions
Yamaha RX-V659 Receiver Logo
2,266 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
